  4. E30 M52
E30 M52
    Want me to get you one?
    https://catuned.com/catuned-clock-e30-bmw-rare-euro
    I have been fighting whether to put a nice 6 button OBC back in that spot, a clock, or a blank plate (booo)
    let me know what you can get them for. I may be interested, I think it would need to have a harness pigtail too
      Shakedown run:
      Coolant temp on VDO=GOOD! temp stayed between 190-200F, given it wasnt a hot day and it wasnt a hard drive, but im not concerned with it anymore until a hard run on a hot day I guess.
      The bad news: that cutting out issue happened and kept getting worse and is now debilitating. It stalled the car while driving once, gave me zero throttle response multiple times with a light lean pop out the exhaust, and I had to pull over twice until I had enough luck for it to start responding again.
      It wouldnt accelerate anymore and I had to pop the hood and disconnect the MAF sensor to regain enough response to get the car back home.
      Its not a mechanical issue because it runs perfectly when its not doing this.
      My guess is that the used MAF I picked up is no good.
      I have a spare TPS to try and Saturday I will try another testfahrt with the other TPS. (Im not expecting it to be the TPS but its a quick thing I can try)
      Once it starts refusing to have throttle response I will unplug the O2 sensor and see how that goes. I honestly dont remember what car I bought it for (95 M3? 95 325i?) they really shouldnt be different.
      Does anyone have a spare E36 OBD1 MAF I can try?
      Im also going to email Sssquid and verify the MAF curve on this tune.
        That certainly sounds like a MAF issues, especially if unplugging it allowed you to drive home.
        It's super hard to drive a car with bad MAF lol, I've done it once, not fun!
        I don't think I have a stock MAF, but I'll browse the parts shelf.
          I wonder though, because wouldnt a bad MAF manifest itself pretty much constantly regardless of temperature?
          So far the car has run perfectly for a few minutes while cold and the problem seems to rear its head as the car warms up and enters closed loop which would point strongly towards the new oxygen sensor.
          Who knows.. maybe the header coating fouled it as it was baking in, maybe my 3 foot extension harness sucks (Im pretty sure I checked resistance afterwards for good measure.... Regardless, I want a spare MAF so I will be on the hunt for a good deal on a new one or a known good used one.
          I double-checked the part numbers for the MAF and the O2 sensor. both fit 92-95 M3/325i and are the correct parts.
          I dont have a physical check engine light but I intended to wire it up once I pull the cluster again so in the meantime I cant do a stomp test.
            Glad to hear the cooling system is working properly!
              you can borrow my MAF for diagnosis, its currently off the car. check your potato phone.
                Guarantee it's the maf, all obd1 m5x cars I've owned the mafs went bad then the second hand ones didn't last long. I have one from Napa that runs the car alright but will randomly die at idle. Have an o2 sensor if swapping it gives you that warm fuzzy feeling.
                  I borrowed @straight6pwr ‘s MAF and the car behaved the same way. I pulled over and unplugged the O2 sensor and all is well. It was a new Bosch unit too... so that will be my next purchase.
                  Here’s a 2nd gear acceleration to verify that there aren’t any breakups in the rev range.
                  https://youtu.be/G_Jk3xQ0zHU
                    My next check will be to see if the O2 heater relay is working. I’d much rather replace the relay than a new sensor.
                    Fingers crossed
                      buttery! 7k+ 😍
                        O2 Heater relay circuit is not working. I can only get 12V at the sensor by jumpering  pins 87 and 30 on the relay harness. Tomorrow I will run the trigger wire from the fuel pump relay to also trigger the O2 heater circuit. I’d imagine this is my issue and hopefully last thing to iron out before I start really driving it.
                        Gravity kicked in and suddenly i need a new lens for my drivers side headlight. My drill fell off the shelf and smashed it 😬
                          I'm assuming the lenses are different left to right? I have a passenger side US ellipsoid with a broken frame, lenses are in great shape.
                            ah bummer. I bought one off ebay yesterday in an attempt to get the headlights back to normal ASAP. As long as the relay wiring fixes my closed loop stumbling, the headlight should be the last thing holding me up.
                              the glass lenses are identical left and right. the plastic buckets are not.
                                Bled a little more air out of the cooling system. Its a steady stream into the overflow so lets hope im done.
                                the o2 heater relay circuit is repaired but the car still falls on its face and doesnt run when warm unless the o2 is unplugged.
                                I suspect the solution will be found in one of these:
                                -new o2 sensor
                                -new DME
                                -ensure there are no upstream air leaks.
                                This exhaust system is the biggest pile of crap ever and the guy that did it sucks. I didnt know how poor of a job he did until i got home and took a better look underneath. Im living with it for now and have only scraped on my driveway entrance when i cant take it at an angle. Tonight it caught and pulled the band clamped portion of the system off the headers. Based on how stupid this exhaust system is I would not be surprised if an upstream air leak was throwing the o2 sensor off.
                                its a little too loud for my tastes and at some point tonight i need to crawl under the car and re-attach it.
                                My wife will not permit me to spend the money to have someone competent do the job and she is running out of patience with the car.
                                Its entirely possible to make this exhaust system work great but it will take someone who does quality work, and of course... money.
                                I feel like im at a bit of a stalemate
                                Voices inside my head tell me to list it on R3V for $7500 and be done with it
                                It drives so well with the o2 unplugged though
                                  -new o2 sensor
                                  -new DME
                                  This exhaust system is the biggest pile of shit ever and the guy that did it sucks. I didnt know how poor of a job he did until i got home and took a better look underneath. Im living with it for now and have only scraped on my driveway entrance when i cant take it at an angle. Tonight it caught and pulled the band clamped portion of the system off the headers. Based on how stupid this exhaust system is I would not be surprised if an upstream air leak was throwing the o2 sensor off.
                                  Sidepipes! Or a fender exit!
                                  On a serious note, please don’t sell it. You’re too close to give up now. Seriously. Ill start another GoFundMe.
                                    Meh, leave the o2 unplugged, just giver.  It will just run conservatively.  An exhaust leak could likely be a problem.
                                      hah! I just noticed the 24V to 24V swap in your sig.
                                      I will get there,  just thought I should have been "there" by now.
                                        i believe i have a spare used o2 sensor around, if you want one. i think dom said he had one too. free stuff to get you one step closer!
                                          I will probably take you up on the spare sensor.
                                          Just to start covering my bases I began going through the suite of sensor tests in the E36 Bentley to check the resistance and reference voltage on the following sensors:
                                          Throtte Position Sensor
                                          Coolant Temp Sensor
                                          Intake Temp Sensor
                                          Mass Airflow Sensor (voltage and ground test)
                                          Everything checks out good with those. Tomorrow I will start on the oxygen sensor +related wiring testing procedures.
