  4. Lifted E30 V2
Lifted E30 V2
    Forgive my ignorance, but what is the large bulge on the valve cover for?
      Thats a good question, I am now wondering the same thing!
        Tis a vacuum pump!
        Since a diesel engine doesn't create any vacuum in the intake, there needs to be a source for brakes. Many diesels use hydroboost (power steering pump) for brakes, as do e28's, even the gassers. Some run a vacuum pump on a belt, but this one has one that runs on a cam lobe on the main cam.
        Nifty stuff.
          Learning is fun
            Googling e28 gasser did not give the results I was hoping for. I might have to do something about that... that would confuse the hell out of people.
              @AsparagusMike showed up Friday and watched me try to get air out of my fuel system for about 5 hours, I'm sure it was amusing seeing it still not start.
              I went back Saturday and loosened the fuel outlet on the back of the pump for one injector and suddenly is was moving fuel (after raising the fuel cell above the pump).
              @HipMF sat and watched in amusement as I tried to get all the air out, while sucking in air bubbles and such, then tried to start it with no avail. I had vast amounts of homework to do so it had to be left for later.
              It turns out that it blows perfect smoke rings out of the exhaust most of the time so that was cool.
              Hopefully will have it running some night this week.
                Post pics of smoke rings I wanna see!!!!
                Image result for exhaust smoke rings gif
                  I see my member title has changed.
                  I approve of this change, and shall continue to ensure the most bro content possible. I do have something planned that will greatly increase my bro level.
                    Image result for cars tractor tipping gif
                      Is that the movie where Mater gets it up in the middle of the night?
                        Yea and then Sally let's Lightning come in her Cone.
                          just watch out for donald glover and dave matthews CDs.
                            Whips?
                            CB?
                            4 inch tips?
                              Whip?
                              There is also one of those laying around for it if the bro level is not over 9000.
                                Is this Dave Matthews?
                                  So I was really hoping to post some sweet pictures of this thing out in the insane snow storm we got this weekend, but apparently that was too much to ask for.
                                  Got it running but something wasn't right, it would change revs on its own, there was a lot of air moving through the fuel system even though there was no air being pulled into the pump, and things in general were just being odd. at some point it was realized there was fuel dripping out of a banjo bolt that was open, as I believed it had been on the old one. I double checked for sanity and found that the old one indeed never had that port plugged or plumbed, as I thought it was a vent port.
                                  Well it is, and it should never have diesel seeping out there. Here is a nifty cutaway to show you what port. (10)
                                  Pump cutaway
                                  That area shouldn't really have much fuel in it to begin with, and it certainly shouldn't have fuel on the underside of the boost compensation diaphragm.
                                  Pump is coming out and going to the diesel shop that did my injectors, along with the parts pile that is my old pump. I hope to sweet baby jesus that they can make the "new" one work with either purchased parts or ideally parts from my old pump.
                                  Can this just work please?
                                    What a headache. One more piece to this jigsaw of a fuel system.....
                                      Oh, I also still had coolant leaking from the floor/frame rail.
                                      If it's the heater valve I may just roll the car outside and throw a match in it.
                                        Dropped the fuel pump off at the diesel shop today.
                                        I told him what was going on and he immediately had an assumption of what was wrong, and figured it was just an o -ring inside the pump. So that's cool to hear.
                                        I asked him to do what he needed to do to make it work, and test it, so that when I put it in the car I know it will work.
                                          I should have known this would happen, but guys, for real. Avoid diesel BMW stuff at any cost.
                                          Repairing and testing the pump cost more than the pump itself.
                                          I have an $1,100 fuel pump, and it doesn't even look that cool.
