chit chat thread
Oh how I hate the quick deterioration of sub par steel and coatings. I know good things are possible, my Volvo was a WI car its whole life, 13 years and almost 200k miles and there is barely surface rust on the cast suspension parts, and the body still looks perfect. I wish e36s were like that...
Just found out there is a Lemons rally that isn't on either coast, in fact it's right here. This would be a lot of fun
That would be a blast
Made this video today. Anyone else have it, and love it?
Probably until your battery dies. LOL
It's interesting how a feature starts at the top end cars like 7 series and over time trickles down. I worked on an e32 740iL that had an aux electric water pump so that you could continue circulating coolant and heating the interior for a while after shutting the car off.
Thats very cool! So does it just keep the blower running while the car is off until the heater blower temp matches the interior temp?
Criteria to run REST is as follows:
- Ignition switch off
- Ambient temp less than 59f*
- Left heater core temp is greater than 158f*
- Battery voltage is at least 11.4 volts
- The time elapsed since the ignition was turned off is less than 15 minutes
Once the function is activated, the REST button LED illuminates, the blower runs at medium speed, the auxiliary coolant pump runs, the air distribution flaps are positioned to provide maximum heating. Blower speed, flaps positions, and desired temperatures cannot be changed while REST is active.
The system runs until any one of the following occurs:
- Ignition switched on
- Battery voltage drops below 11.4 volts
- Coolant temperature drops below 86f*
- The REST button is pushed again 15 minutes pass
It won't work if your battery is low, and I know that from personal experience, lol.
Ya know, I used that one time and it didn’t seem like it did much. I guess it wasn’t ice cold but didn’t seem that warm
Really? That's weird. Mine is always toasty warm! Might help to set the dial to maximum hotness before using it.
I thought it was a 2006+ feature, but someone commented saying they have it in their E39! I was surprised and amazed at the same time.
