  4. Let's see where the magic happens *garage photos*
shopgaragespaceworkstorage
247 Posts 42 Posters 4.6k Views 1 Watching
    Dream garage right there. What would be better than 3 e36s?
    4!
      No e36 disrespect intended but given the space and the existing rides I'd vote for a two or four post lift as next step. Maybe more than one.
      Hey if I'm going to be living vicariously through someone else's dream setup let's go big.
        wasnt m3 said:
        The reality of this still hasn't fully set in yet. Hoping to finish the portion of the garage that hasn't been insulated yet this spring. Lots of cleaning before the barn is more useable.
        Maybe it's just me, but I'm having a really hard time visualizing this space. Is that garage front the barn on the back?
          Separate buildings.
            A lift is definitely in the works, a bit out though. The last e36 is a parts car and will be in the barn as soon as the ground dries up.
              Any plans with the shell as it is rare to have a slicktop?
                  ___
                    I dont understand the slicktop circlejerk unless you are a behemoth like myself and need the headroom
                      Behemoth and tall torso folks....
                      That aside it's an added weight of the sunroof and carrier issue compared to roof skin, at least on a track car you want weight placed low rather than high.
                        It's the stiffest one 4 door dicktop
                          Same thing with the ti looks like a shittier version of the x6
                              i don't even like e36s that much, and thats a low blow. the TI is 100x better than the abomination of a car they call an x6. (pronounced "times 6" because its 6 times uglier than everything)
                                Glad you were the one to say it instead of me=P
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  AlpineE30 said:
                                  Do you have plans for that shelving/bench. Or could you snap some more pics of how its built.
                                  I want to build something like that along my back wall.
                                  1997 328ic
                                  • AlpineE30A
                                    AlpineE30A
                                    AlpineE30
                                    Definitely! It was in the house when I moved in.
                                    I do have some advice... don't use nails to build it.  The previous owner used nails on it and with some weight on the other side it collapsed.  I got it all put back together using screws and it's solid now.
                                    • stealthbimmerS
                                      stealthbimmerS
                                      stealthbimmer
                                      I can't remember the last time I used nails for anything. I have to redo my deck this year because whoever built it was a dumbass and used nails.
                                      1997 328ic
                                      • AlpineE30A
                                        AlpineE30A
                                        AlpineE30
                                        Yes. There was definitely a profanity laced tirade against the previous homeowner and his total ineptitude.
                                        Anyways, here are some pics.  I haven't reinforced this side yet, so excuse the nails. Hahaha
                                          If you look closely you won’t see any e30
                                          With your input, this post could be even better đź’—
