  • AsparagusMikeA
    AsparagusMikeA
    AsparagusMike
    Ugh... that looks like a good one too. The only problem is the fact that it's in woodruff and the only time I could make a drive like that would be next weekend Saturday, doubt it'll still be available by then.
      Ask him if you can paypal him to hold it or meet you closer.
        Yeah no kidding, woodruff is quite far away!
        Sucks that the white shows through the flocking. Looks nice other than that!
        • AsparagusMikeA
          AsparagusMikeA
          AsparagusMike
          So just got off the phone with "just flock it". According to the lady I talked to its not uncommon for people to flock their dash twice in order to cover everything completely. They said to simply paint right over what i have on there. I do have enough paint glue from them to cover the dash again but not enough fibers, I would have to order more fibers which will run me another 42 dollars. I should also add that she can't confirm this will work to solve the bondo seeing through issue, its just what other people swear by doing. So now I'm down to two choices... Possibly keep digging myself a grave flocking the dash again not knowing if its gonna work or see if I can get my hands on this crack free one in wood ruff.
            Crack free dash will just crack a month after install
              agreed, crack free original dashes are a scam. The problem is it will still crack because it's the same materials. I had a dash crack on a e30 while in heated storage! I'd spend another $42 to either repaint and reflock, or add to your existing work. To have a properly OEM refinished dash from justdashes.com is around $1200.
              • AsparagusMikeA
                AsparagusMikeA
                AsparagusMike
                So last weekend I started cracking down on getting the gas tank cleaned up, prepped, and repainted. Was going along just fine and dandy until I noticed this on one of the lines welded to the top of the tank...
                After assessing the other parts of the tank like the edges and dents underneath I decided its time for her to retire
                So I started searching around and found my self on amazon looking at this aftermarket gas tank made by spectra premium. After reading the 6 positive reviews it had on it I was convinced to give it a try. Tank should be arriving today sometime hopefully.
                So while I wait for the tank I turned my attention to the other things needed to get done
                new fuel lines bent up...
                I also want to throw out there that this copper nickel line is so nice to work with and bends very nicely. Took me about a hour to get the feed and return line all fab'd up.
                Sense I don't have the tool to make the special looking flare on the end of the factory fuel lines I just threw a shallow bubble flare on both ends, I suppose its better then leaving it straight...
                Pulled the fuel filter housing apart plus some heat shield brackets off the gas tank, very rusty indeed.
                I can fix that
                Two problems I ran into now... First off the new tank does not come with a new connection pipe on the gas tank and while attempting to remove mine I ended up kinking it. Was just gonna order a new one until I looked it up by part number on the intranet and found that they want close to $170 for a new one (that's almost what I payed for the tank!), and there's no aftermarket options for it.
                If anyone has a parts car that still has this pipe on it and can be removed without destroying like I did to mine and is not in need of it please let me know as now I am on the hunt for a replacement without paying an arm and a leg for it..
                Also, when removing my axle to diff bolts I rounded the inside Allen head part of two of them. For some reason they changed up the design of the bolt so that now its a socket type bolt instead of allen head and I am unable to find new versions of the Allen type. Does anyone else have these type of bolts laying around or on a parts car that they aren't using anymore? I could just get 2 of the other kind of bolts but then they wouldn't be all the same and I just can't have that, lol. Thanks!
                • AsparagusMikeA
                  AsparagusMikeA
                  AsparagusMike
                  Sorry, one correction I need to make... the diff bolts were torx head not socket type or "hex head"
                  • stealthbimmerS
                    stealthbimmerS
                    stealthbimmer
                    Just get all the new type of bolts...they are better and you wont have that problem again if you have to remove them again
                    1997 328ic
                      I have a couple spare socket head axle screws (laymans terms: bolts that use an allen wrench)
                      Whatever you do, make sure the axle bolt holes dont grease up the threads when installing them, and do use blue loctite. It is common for axle bolts to back themselves out due to greasy threads
                      • AsparagusMikeA
                        AsparagusMikeA
                        AsparagusMike
                        Awesome! Ya no doubt gonna be using clean threads and loc-tite.
                          I have some of both types if you don't get a hold of any.  Cant help you on that tank line though. Cant you just make your own?
                          • AsparagusMikeA
                            AsparagusMikeA
                            AsparagusMike
                            I suppose I could. Only thing I have a question with is what the purpose of its shape is. Why not just have it be straight? Other thing is figuring out how I would make that flare on the end so that the fitting seals when tightened down.
                              You might have a really hard time finding one of those lines, since any that could be removed from a gas tank are likely attached to a good condition tank. If you can figure out what kind of fittings they are, it might not be too hard to make one.
                              • AsparagusMikeA
                                AsparagusMikeA
                                AsparagusMike
                                Click to choose files Received the tank last night. Overall seems like it is pretty well made. It is made of ni-terne steel (which is pretty much a steel with a plated coating over the top of it to protect it from rust and corrosion, the coating is made of 92% lead 8% tin), I think that's pretty much what all new gas tanks are being made of now. I did notice right away that one of the tabs had bent over, probably from shipping would be my guess. Not to worried about it though as throwing it in a vise and straightening it out would be much easier then having to go through the hassle of sending it back and then get another one sent over. My plan is to paint the tank in por-15 to make it fit in better underneath the car as well as giving it a even better rust protection. As the surface is very smooth, most of the time I would scuff it up with some sand paper or scotch-brite before painting but I think that would be unwise being that it would release the lead content into the air which of course would mean me breathing it and probably dying. Right now I'm gonna try cleaning the tank down with some lacquer thinner and then apply the por-15 on the top side to see how it adheres. I did read somewhere that paint and lead adheres together pretty well so we will see. how that goes.
                                Few pics of it out of the box...
                                Things happening in the next week:
                                Got stainless lines ordered from CSS as well as a bunch of little misc. stuff from fcp. Hoping to see everything next week so I can get the lines installed, then the tank and maybe start on getting the rear axle assembly back in. This means the main goal is finishing up the under body this weekend hopefully.
                                Stay tuned!
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  Contact amazon and send em the damaged pic. They will likely give you some money back. I had a window a.c. come with a big dent in it. Damage didn't affect the function so I was ok with it, they refunded me like $60 if I remember correctly.
                                  1997 328ic
                                    You could always pick up a lead specific respirator too, that'd probably work if all you're doing is scuffing it up a little. Do it outside so that it doesn't get thrown into the air in the shop/settle on anything and you'll be good.
                                      Do you have a link for that tank?
                                      • AsparagusMikeA
                                        AsparagusMikeA
                                        AsparagusMike
                                        Just sent out an email to them, we'll see what happens. Thanks for the info!
                                        Gonna look into that. I like the idea of having a ruff surface so that's there an edge for the paint to grab to.
                                        https://www.amazon.com/gp/product/B000C7RZ36/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1#customerReviews
                                          I can tell you from experience you will have a hard time getting por-15 to adhere to a painted or semi smooth surface EVEN after you scuff it. I made the "por" decision to scuff an entire engine bay and used por-15 to paint it and it all flaked off in a few short months. I could have done a "por" job of prepping the surface, as I was inexperienced at the time, but I just want to give you a heads up. It did work great on my rusty truck frame though!
                                          From a Hotrodding site:
                                          "best applied to minor surface rust to get bite. When you completely take out the rust it doesn't seem to adhere as well and it comes off in sheets or flakes." -tech69
