887 Posts 52 Posters 12.4k Views 4 Watching
    My buddy came over and finished pulling the motor on Friday night. I removed the twin turbos on Saturday morning to be shipped to their new owner. Sad, because they had less than 500 miles on them.
    Then my finger slipped...
      Glad the twins sold. What are the specs on the clutch?
        Me too, and I got a good price for them. Now I have a 50% less chance of my turbo(s) breaking.
        As far as the clutch; less than 1,000 miles on a SPEC Stage 3+.
        http://my1series.com/2017/06/26/bmw-n54-clutch-upgrade-spec-stage-3-with-mfactory-smfw/
          Jake I’m sure you mentioned it earlier, but was the failure on this engine?
            I'm assuming you meant to ask "what was", but if not, correct me.
            Low compression on cylinder #3. Ran fine, but had a slight miss to it. Dumped a tablespoon of oil down the hatch of #3 and compression went back up. Assuming it's a cracked ring or ringland. Don't have it ripped apart.
              Yes that’s what I meant lol, I don’t use my phone well.
              Tune issue then?
                Tune issue then?
                I was having ignition issues, and I think the motor was getting tired at 120k. It'd been pushed very hard since 80k.
                  Glad to see motivation returned to this thread. Where did I set my popcorn now....
                    Agreed!
                      Something was left on my doorstep today! I'm honestly blown away by the quality and craftsmanship of this kit. The attention-to-detail is crazy. I've dealt with a lot of vendors on this platform and this was probably the nicest overall experience I've had. It shipped on time, came complete, and was packaged VERY nicely. I can't say the same about my previous expensive purchases. Super excited to get this installed for spring!
                        What is the brand on that manifold?  DUCKFACE?  UUCRACE?
                          What is the brand on that downpipe?  DUCKFACE?  UUCRACE?
                          It's on the manifold. DOCRACE. The lighting makes it difficult to read, but looks really nice in person.
                            Yeah that stuff looks awesome!
                            is this single aimed at just simplicity and reliability or for even more than the 600 or whatever HP you were making?
                              Since someone asked me "why go single now, after having upgraded twins" on another forum, I figured I'd post the answer here as well.
                              The biggest reason is because I don't want to have to do all of this work ever again. If one of the twins took a shit, I'd have to drop the subframe to remove everything and replace it. Now I'll have one turbo that can go bad, instead of two... and it'll be a lot easier to access if it does go bad. Aftermarket N54 twins aren't known to be reliable anyways. They also pile in torque down low. While it feels awesome, it's tough on the motor. I don't want to replace another motor. A larger single turbo should be a little easier on the motor.
                              I wasn't "wowed" by the twins. They were definitely faster, but it wasn't "OMG CRAZY". I know I'll be sacrificing some spool time, but when the boost hits it's going to feel great. If you're after linear power with modest goals, I think twins are a good choice. But I don't want to be pushing twins to their absolute limit just to achieve my goals. I'd rather put a larger single on and give it a lighter workout. I would still recommend the MMP twins, but I think I'll enjoy the single more. Plus, who doesn't like the look and sound?
                                I've ridden in an xi with I think a Precision 6467 and wow is the only response.  There is so much power when the boost builds, which is really quick, it's intense.  I rode in it when he was targeting slightly over 20PSI and I think he had run it up around 28 PSI at one point which was maybe around 750ish HP.  I don't know how it would even be driveable without AWD to get it to the ground.
                                Are you running a spacer with port injection?  What is your goal with the 6266?
                                  Ease of wrenching is HIGH on my list of priorities. Your reasoning is 100% sound
                                    Nice! I had MMP Stage 3 twins at 28psi before this, which was probably about 625whp. I could get tire spin in 3rd, so I'm sure it'll be the same case with this new setup. Eventually I need to upgrade from my 265 PSS to something stickier.
                                    I am running a port injection kit with two Walbro 450s and a larger fuel line. The goal is 700whp, but I'll probably tone it back to about 650whp for my everyday map.
                                      Are you running corn juice with this setup?
                                        I'm still in for a tubbed rear end.
                                        • IceddragonI
                                          IceddragonI
                                          Iceddragon
                                          Really excited for you!
                                          My current end goal is still around mid 500s, would you recommend sticking with twins for that level? I didn't realize the aftermarket stuff was fragile as well, I guess I haven't done that much research yet.
