  4. E30 M52
E30 M52
    That was awesome!
      That's sweet. It reminds me of this CNC tubing bender.
        Awesome! You could make some wild headers on something like that
          DANGIT, BOBBY!
          I am installing my brake master cylinder right now and the charcoal canister wont fit anymore and needs to come out (okay, its out) and as im installing the two nuts that hold the master cylinder on, one of them is just spinning. 🤯
          So I am inside cooling down so I dont rage and just stick an impact gun on it out of spite.
          Im going to assume it is splined like a wheel stud and will try pulling the stud towards the front of the car before cursing up a storm and pulling the manifold and booster out.
          *serenity now*
            Jb weld
              I cut the spinning nut off with a dremel and ground away some paint for a tack weld. I believe I should have enough clearance for a small tack since the master cylinder has voids.
              • JeffJ
                JeffJ
                Jeff
                Depends on if the taaack weld you lay on there matches or has a smaller radius then the chamfer on the master cylinder. I suggest you get a set or these to make sure.
                1976 530i e12
                1990 325ix e30
                1992 325i e36
                1995 740il e38
                2001 330xi e46
                ^More to come :)
                  also, aren't there meltable things inside the booster? Like a big diaphragm? Don't put a hole in it with a piece of weld spatter.
                     Between a reman. booster (not a 36 year old used one)
                    A 36 year old used one is probably sounding pretty good right about now eh?
                    Looks like a bit of weld should help, or JB Weld!
                      Right.
                      I squished a small bead of JB putty on this morning so we will see if that holds tonight when I try again.
                        Have you ever tried the steel stik stuff? Like JB weld putty it seems.
                          Right.
                          hmm...
                            That is pretty much all I ever use. It is nicer to grind and smooth out
                            Back in the pre-Megasquirt era, the AFM to cone filter adapters I could find had a very poor transition between the round tube and the rectangular afm entry. The air simply runs into a wall. So I packed JB putty in the corners to make a radius, then ground and sanded it smooth as glass after it hardened.
                            I keep a stick of it in the car tool kit as it can patch an aluminum oil pan
                              Good news: The micro bead of JB putty worked. The master cylinder is installed
                              Stupid News: its dark and everything is covered in humidity juice.
                              List of things you can do on a 24v swapped e30 without removing the intake manifold:
                              - install master cylinder
                              - change spark plugs
                              - change injectors
                              - rotate tires
                              - complain
                                It's a joy removing the manifold, you will get good at it.  The extra joy in an e36 coupe is removing the wipers, cowl plastic, and blower motor cover firewall thingy so you can get the manifold lifted off of the studs.
                                • stealthbimmerS
                                  stealthbimmerS
                                  stealthbimmer
                                  Thats why I love the e34 platform....so much more room for activities.
                                  1997 328ic
                                    Progress this week: I popped the beauty cover nut covers in place then went inside.
                                    I was trying to generate some excitement and motivation by reading up on some peoples experiences with modded  M52 E30s :
                                    Here's to lowered expectations :D
                                      The user name just made me think of this again.
                                      But for real, it'll be fun.
                                      It won't match an m20 turbo, no, but the m52 alone results in a very respectable e30 power plant.
                                        it'll be fun!
                                        you'll have a working, reliable e30.
                                        that's pretty much all you need for a happy life.
                                        a family is cool, too, I guess.
                                        and beer.
                                        don't forget the beer.
                                          I hate this E21 brake booster.
                                          It sits closer to the firewall than stock and as i went to attach the clutch feed hose at the reservoir and start bleeding the system, i realized the clutch feed hose is slightly pinched behind the booster where it comes through the firewall.
                                          As i loosened the brake booster to see what other angles i might try routing the hose, one of the studs on the interior side of the booster started spinning. I used blue loctite on the nut during install and I think that is a contributing factor. Regardless, the studs shouldnt be this prone to spinning....
                                          I dont have a solution for that yet and I dont know if theres enough room to cut the nut off with a dremel like i had to do for the brake master cylinder mounting nut.
                                          I ordered 3 feet of new clutch MC feed hose and im going to route the hose through the firewall through a rubber blank near the strut tower. The clutch MC feed hose is old anyways. The pedal area just isnt anyones favorite place to wrench.
                                          I made some minuscule progress in other areas but its not worth mentioning.
                                          I replaced the belts and noisy idlers on my nissan flagship sedan so at least there was that success
