330ci323cidrifte46
  • TkuhnT
    TkuhnT
    Tkuhn
    So the first order of business was to get the M52tu and that boat anchor of an auto trans out.
    Then came getting all the dirt and grime cleaned up, the bay will be getting all the seams stitch welded and some of the holes filled as well. Then a fresh coat of paint and the bay is pretty much done. ABS is removed and I will be installing the ChaseBays brake bias valve with my own set up of brake lines rather than using the soft lines that the kit is available with. 20171117171313.jpg20171117202731.jpg20171118190223.jpg
    Thats about it for now until the bay is ready for stitch welding and etc.
    Super pleased with how well the bay cleaned up after seeing all that grease and grime originally.
    SIDE NOTE: Not sure if anyone here has swapped a m54b30 into a 323 but I know I will need to convert the shell to throttle by wire or the manifold to throttle by cable. Has anyone ever had experiences with this?  ALSO whats the deal with the fuel systems here? The 323 has a feed and return line where the 330 has only a feed. Can I run the fuel rain from the m52tu and my m54b30 injectors? Or is there more to it than that? Thanks in advance if anyone has any insight!
      Nice!!!! I wish I could give you pointers, but im empty handed on the subject. Looks like you are on the right track though.
        This is awesome!  I can't wait to see more!
        • stealthbimmerS
          stealthbimmerS
          stealthbimmer
          What's your plan for the m52tu? I need one for an e39 I bought with a blown hg.
          1997 328ic
            I had actually told him about you needing one=)
            • TkuhnT
              TkuhnT
              Tkuhn
              Part of the deal for the car was my buddy got the engine back. Let me message him and see what his plan was for it and I'll let you know!
              • TkuhnT
                TkuhnT
                Tkuhn
                Scratch that earl beat me to asking him haha
                • stealthbimmerS
                  stealthbimmerS
                  stealthbimmer
                  Well,let me know. Sorry for hijacking your thread.
                  Sounds like an interesting build. Someday I'll have the spare funds to build a track rat.
                  *EDIT* Scratch that...wrong engine. Didnt notice it was a 323 at first. I need a 2.8
                  1997 328ic
                    I would guess the mounting bracket/pedal would bolt right into the 323 shell, but I think the wiring is part of the body harness. I figure you could probably either strip the necessary wires/plugs from the harness or swap the whole body harness. Not sure how all the CAN bus stuff will cross over on the 323 harness though. If you don't care about having a check engine light and a million trouble codes, the engine will run perfectly fine without all it's CAN buddies as long as it has the bare essentials.
                    The fuel pressure regulator on the m52tu is most likely part of the fuel rail like on the m50/52/etc if there is a feed and return line going to the fuel rail. On the M54, fuel pressure regulator is attached to the fuel filter, so the return line is down underneath the car and is part of the filter assembly, only one line goes up to the fuel rail. M54 fuel filter:
                    I assume the e46 323ci has the filter more towards the engine similar to an e36, so just swapping to the correct filter/FPR is probably your best/cleanest bet. If the filter is near the fuel tank like on an e30 with the feed/return lines running up to the front of the car, you can use an s54 FPR housing with an m54 FPR (lower pressure, 3.5 bar instead of 5 bar) to retain the original filter location. This housing has a threaded piece that attaches to the fuel filter that you can replace with a barbed fitting for a 'remote mount'. This is how I am doing it on my swap.
                    • TkuhnT
                      TkuhnT
                      Tkuhn
                      All good! Haha
                      • TkuhnT
                        TkuhnT
                        Tkuhn
                        @m42b32
                        I looked at the setup of my buddies 330i and it has the fpr on the filter as shown. The 323ci has the regulator separate after the filter still under the car tho. So I'm going to get a 330 filter and possibly the feed line to the rail and the returns and feeds pre filter look like they should line up. Thanks for the insight!
                        Also I'm waiting to hear back from Jordan at RK...... Lol but I'd assume wiring the pedal in shouldn't be a big deal, I don't think the entire car is can bus considering how many wires are in the thing. I thought the can bus was only to communicate dme to cluster. I could be wrong. I do a bit of can bus trouble shooting at work so I'm not completely blind on the subject but I have yet to hear back from my tuner on the subject, alot of other stuff going on before I really have to worry about it haha
                        • TkuhnT
                          TkuhnT
                          Tkuhn
                          More progress from over the weekend 😄
                          I guess I never mentioned this but the bay is getting cleaned up for stitch welding to help stiffen up all of those spot welded panels. Some of the holes are going to be filled and shaved as well. Not going too crazy like on my civic as this car is being built for street/track but this is definitely where I planned to bring some of my own, possibly unconventional flare to the car.
                          It seems like not many e46 guys shave bays, or do anything to them for that matter lol. Luckily at our shop myself and fellow wibimmers member nick are both doing close to the same thing so we had a few plates lazer cut to the exact size of the holes we are filling.
                          Also got all the wiring pulled back into the cabin to be sorted through. Going to be getting rid of all the unnecessary things like ABS, SAI, washer fluid and etc. The interior is going to be partially stripped but I am still playing with ideas on exactly how to execute it and make the interior what I want.
                          One thing I will be doing is swapping in my black dash from the sedan, will also be looking for some black door cards along with re-wrapping the headliner and A pillars.
                          Also was able to get all of the leftover tape residue off both the driver and passenger side which was from the windows being taped up while it sat outside for 3 years lol
                          Pretty happy with the results, here's a little before and after of the passenger side.
                          • TkuhnT
                            TkuhnT
                            Tkuhn
                            UPDATE!
                            More progress over the weekend!
                            First and foremost one of the things that was on top of my list to figure out was getting the wiring figured out for the accelerator pedal. After lots of researching and running through diagrams we were able to figure out the wiring.
                            What we ended up doing was stripping down the chassis harness from my sedan and completely removing the pedal wiring from the pedal connector to X-600004 on the DME where I was able to de-pin it. We also pulled the wiring for the clutch switch completely out of the old sedan harness, also de-pinning it from the ews connector as well as the DME plug. All of the wiring was then installed into the coupe harness. Unfortunatly I forgot to take a photo but I was able to completely wire the 2 harnesses into the chassis harness as if they were there from the factory, most people seem to just wire the clutch sensor to the brake wires but I wanted to get as clean of an install as I could. Proably more proud of it than i should be but whatever haha.
                            Enough rambling about that though, another larger step was getting both the driver and passenger side harnesses that run through the bay uncovered all the way back. I then sorted through the wiring that was not necessary and removed it from the harness as far back as possible and capping all the wires with sealing shrink wrap.
                            I have some tech flex along with a few connectors on order that will hopefully arrive before the weekend.
                            Another large step was also started on the bay. Last week I was able to get the bay completely prepped for my buddy to stitch weld the seams along with start welding in the delete plates.
                            Then came some grinding. Im going to be leaving all of the stitch welds and painting over them but all of the filled holes need to be ground flat and then a bit of filler will be needed.
                            A bit more welding needs to be done but its coming along nicely!
                              Looking good!
                                The M54 is going to be awesome! One honest question though:  you mentioned that you are doing the swap into the 323i chassis because it is nicer. you also mention that you participate in skid racing. When I imagine skid racing, I imagine inevitable carnage. So from way over here in my armchair I get a little worried for you thinking about all that swap and cleanup work when the original 330i chassis was still "good"
                                I know im missing something here so please correct/enlighten me, or maybe your skid racing venues aren't as treacherous as my imagination would make them out to be.
                                Loving the updates, keep em coming!
                                  Holy crap, you are really digging into this thing!
                                  Looks like you're doing good work, keep up the pace and you'll be done sooner than anyone else here!
                                    I see a very bright future. Way to hammer on!
                                    • TkuhnT
                                      TkuhnT
                                      Tkuhn
                                      @Snap
                                      Understandable statement lol. So that's the thing, when most people think drifting they assume a bunch of piles of shit that smash into walls and eachother but that's not necessarily the whole case. It's more fun to get close while in tandem and not hit. Although I still have alot to learn and seat time to be had I can tell you that for sure. It's really all in a person's style, which is all drifting is based around, style. While it may happen someday that the bumper drags a wall or there's some contact with another car, I'm completely aware that cars can get thrashed while sliding. The idea behind this car is it's a rust free and unmolested chassis. My goals are a street car that I take to the track on the weekends as well as probably do some dumb shit in the streets (when it is safe) and also to build it to be presentable at any show. I mean when it comes down to it some people like smashing things and having shitty cars haha I'd like to have a nice car that is a looker and still performs well. I hope that makes some sense atleast haha
                                      • TkuhnT
                                        TkuhnT
                                        Tkuhn
                                        @GunMetalGrey
                                        Thanks! I'm definatly trying to bring a bit of the style from what I learned over 7 years on my civic to this chassis. The plan is to have this first version of the build done before automotion 2018 in May. Because it's more important to me to get seat time and more enjoyable to have the car done and on the road then tear into it over the next winter to make improvements and build onto what I already have.
                                          nice work on the wiring! i don't have the patience for that haha
