  4. M52/S52 oil recommendation
20 Posts 11 Posters 214 Views 1 Watching
  • JeffJ
    JeffJ
    Jeff
    I run mobil1 15w-50 because whatever
    I run the same oil full synthetic 15w-50
    1976 530i e12
    1990 325ix e30
    1992 325i e36
    1995 740il e38
    2001 330xi e46
    ^More to come :)
      Between bobistheoilguy and assorted oil threads on bmw forums this is path down a deep deep rabbit hole. Take the recommendations here and if you have or just to ease concerns do periodic Blackstone Labs oil analyses to make sure all is well.
        To piggyback off of what @Boris3 said, When I've had customers ask me I tell them as long as they're using a name brand oil and changing at regular intervals then they'll be fine.  That's all it comes down to, don't ignore your oil changes and use quality products.
        • MorzadaM
          MorzadaM
          Morzada
          I ran mobil 1 0w40 in both of my e36's and neither blew up.
          I run this in my e36 M3 and my e91 328.  It used to be a BMW approved oil, but BMW has since pulled all the non-BMW oils from their approved list.
          Switching to this weight/manufacturer in my e91 cut my oil consumption from about a quart per 7000 miles (my change interval) to near zero.
          Why can't the Maples just be happy in their shade?
            I was running it in my e90 335i as well and had no issues.  I switched to Liquimoly only because I got some for free from work.
              I have the owners manual for my e36 in the glove box, I'll get a pic of the recommended oil weight page after work. That being said, I run whatever name brand synthetic is on sale (usually either Mobil 1, Castrol, or LiquiMoly) in 15w50 in the summer and 5w40 in the winter and haven't had any issues.
                This is a pretty great comparison I found for my infiniti (VQ35) to show how not all high quality synthetic oils are created equal/how some oils should be used with a particular engine and others probably shouldnt
                  Stop it.  Just stop it.  Put oil in and change it regularly.  What this doesn't show is how any of this effects engine life and a rate of failure based on a certain brand.  This doesn't tell you if any of it matters.
                    And the sample size is well below what is acceptable to develop any kind of parameters.
                      I use Royal Purple HPS, it's not even API approved, boom!  And I even use 5w30 in my m50.  Another factor into the equation of oil recommendations is that these engines are 20 plus years old, engine oils have changed in that time.  There was no 0w40 and great synthetics then.  I'm not concerned to use a lighter oil (of a high quality) as long as the oil pressure is still in spec.  More pressure means lower flow rate.  The oil pressure is not what prevents metal contact.
                      I'm not a Diehard Royal Purple fanboy, There are other oils that are great as well.  I can get HPS from my local race shop for just over 8$/quart.  I have used it in all of my vehicles for several years and it seems to keep engine internals nice and clean.  If your engine is ancient like my LandCruiser though it can clean too much and expose seals that would leak other than years of grime slowing down the leakage.  That is where the myth that synthetics cause leaks comes from.
                        a4824769fe98085be879b04bbdda7398.jpg.
                        Royal Purple is on sale
                          Cheap!  I will try that next time.
                            Brian lives for analysis paralysis though, so it's right on track!
                            • 6
                              6inarowmakesitgo
                              I beat the daylights out of my M30 and blew it up, spun a rod bearing on cyl.5. always ran Valvoline 20-50 with ZDDP additive.
                              Rebuild with all new components, still running 20-50, BUT I use Liqui-Moly MoS2 (Molybdenum Disulfide) additive and if it is ever below 40 degrees I have a 100W oil pan heater to help cold starts. This was 140,000 miles ago and she has a strong 150-160 PSI across all six with minimal leak down.
                              • JeffJ
                                JeffJ
                                Jeff
                                +1 Great advice
                                I would like to add a picture of oil changes done regularly at 10k miles like recommended by the dealer. No matter the brand it all breaks down in the end. Oil still collects dirt and no engine filter will ever filter it all out.
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                • 6
                                  6inarowmakesitgo
                                  Jeff said:
                                  +1 Great advice
                                  10K oil changes are BS. Been working on machinery and vehicles for along time and my dad/mentor/teacher has been ASE certified master tech for longer than I have been alive; German cars= 5K max OCI.
