E30 M52
There comes a time in every man’s build when he has to break out the zip ties.....
Kaiser and JC have been very helpful in sending pictures and info about wiring harness routing. There is at least one bracket im missing that helps with retaining the clump of wires and I cannot find it on RealOEM. Thats okay. Its not the end of the world. The wiring covers I installed jumbled up the natural lay of the wires so it isnt how it would have come from the factory but I feel I have routed wires as safely as possible to minimize rubbing, pinching, or possible electrical interference on the shielded wires.
Enter: zipties
For comparison purposes I am posting the mess under the manifold before and after. Im not really trying to show it off but i cant see both images side by side on my phone so here they are for comparison.
So here it is
OBD2
OBD1
Engine is installed.
I still have a long way to go before it gets fired up or drives but I have freed up the other side of the garage so the family truckster can park inside and avoid the snow.
The feeling of accomplishment from hitting this milestone will give me some fresh motivation to take care of the numerous smaller tasks remaining
Dave, you are the man! Thanks for your help yet again.
Dang that’s fresh!!!
ICV hum present??
OHHH YEAHHHHH. Leaps and bounds you are making in very little time. Keep cranking away!
I see what you did there. And I like it!
So don't get your hopes up for any rage drift footage anytime soon. Based on my to-do list I should be able to fire the car up around thanksgiving and maybe drive it in January.
I am replacing the control arms, master cylinder, and hopefully the brake calipers, pads and rotors "while I'm in there" (these ones have about 20,000 hard miles) BUT my female counterpart is watching purchases like a hawk so I really need to liquidate some of my remaining parts stash items to justify buying some last odds and ends.
wish me luck n stuff..
this also assumes that my mechanical work, wiring, or vanos/timing aren't dickered so having a massive backfire through the intake, blowing a hole through the precious plastic m50 manifold is still a possibility when I finally get around to running it.
I assume you turned the motor over a few times on the stand to ensure that timing stayed in place, if so your timing work is on point!
I have yet to see anything go through one of the manifolds, but it would be kind of cool if you did?Keep on truckin'!
I turned the motor over 1/4 turn and it was jammed, heard a metallic thunk, so i turned it back to tdc and used a mini-sledge to get the cam thinger back on. It kinda rounded the corners on the cam blocks but the vanos will makeup for it lololol
Jk if its somehow not perfectly timed then i quit engines
Electric motors are the future!
"then i quit engines"
You already tried this and we didn't allow you to, what makes you think this time would be any different.
Update
Today I will be receiving my Spal fan, control arms, a non Uro brand ICV hose and a couple other small bits. A silicone intake boot is on its way and Mitch has the fuel hoses under the intake that I need to get those connections finished.
What I have left to order is an new brake master cylinder (just because), and oil distribution block for my oil pressure sender, water temp gauge (to replace my vacant boost gauge spot), new front sway bar links since AFAIK they are original. I never upgraded them when I replaced the sway bars since I wanted to do it right with the correct length/adjustable links. I also plan on overhauling the brakes since these ones are on year 7 (a couple years of not driving of course -___-)aaaand last but not least, re-welding the shift linkage that I rotated the wrong direction, installing the driveshaft, welding in the skid plate and finishing the exhaust system. This involves fitting a y-pipe with an o2 bung installed, adding a 2nd resonator, and finishing the connection over the subframe to the muffler.
Thanksgiving weekend I will attempt first startup in all its open header oxygen sensorless glory. There's no reason it shouldn't just fire right up apart from the fact that the whole thing has been tampered with.
Early January still looks good for a maiden voyage so long as there is a day with dry roads not plastered with salt dust.
PS: Don't "like" this post. there is nothing exciting about it.
