  4. E30 M52
E30 M52
    I’ve had a few valve cover gaskets and head gaskets delivered to my house in the past few years. My wife is catching on:
    DED. HAHAHHAHAA.
    Also I like the new title of your thread.
      Many thanks to JC and Kaiser for the pics they sent last night!  The alternator and starter wires were identified as well as the ABS unit power wire which is needed for a 24V swap. There is still a mystery 2 pin connector in the same loom as the O2 sensor connector which could possibly be for the reverse light switch? but it seems strange for that to be caught up in the engine harness instead of one of the chassis harnesses.
      I stand a much better chance of getting the engine fired up without having to troubleshoot things now. I will take one last look at the remaining connections and see what I can make of them, install the harness on the engine and move on to the clutch and trans tomorrow.
        What year is your chassis?
          1991
            Even though we already spoke. This ones for the lurkers
              That explains why I've never dealt with the ABS wiring!
                After about 6 hours of working on it, its complete. Everything accounted for and labelled, degreased, rewrapped in new sleeving, a few new wires run, a few wires terminated, all ring terminals replaced, and all pins cleaned up.
                  Want to do mine? 😆
                    Looks good dude!
                    The small 1/8th wrap is quite annoying to split haha
                      Rear main seal installed. BMW brand with no garter spring. Black rtv on the gasket, 7 ft lb on the 6mm hardware, 16 ft lb on the 8mm hardware.
                      All of the appropriate brackets are installed (Roses are black violets are black, everything is black)Its a bit of a puzzle doing the OBD1 swap and not being familiar with 24V engines. I had some things bolted up on the wrong holes until i realized things werent lining up. There are 1 or 2 6mm holes on the elec. harness bracket that need to be opened up to 8mm
                      the front knock sensor needs to be angled slightly to clear the bracket and the rear portion of the bracket needs to be bent slightly to clear the original M52 lifting bracket
                      I will wait until the trans is on to put the wiring harness in place since i dont want it to be flopping around in the way while trying to stab the trans.
                        Looking good!
                          Looks quite good.
                          Don’t buy crappy ICV hoses. They crack and the blow up and you hunt for idle all over the place and then your gf is convinced she broke your car.
                          I bought slicone ones from maximum psi. Overpriced for what they are, but knowing they’ll never need to be replaced sure is nice
                            Post irrelevant: I dont have a gf
                            The ICV hose i bought is “URO” brand which is probably junk, but i will keep an eye on it once im running
                              URO is usually junk, but also cheap.  Expect one summer before crackage.
                                One summer may be optimistic.
                                  One summer of driving would be amazing
                                  • JeffJ
                                    JeffJ
                                    Jeff
                                    I’d 2nd that!
                                    I don’t think I have ever replaced my ICV hose probably the same one it came with. I did how ever have an issue with the fitting in the back of the intake popping out, falling off, or whatever decided to keep happening. I did however solve this issue with an epoxy called plastic bond.
                                    1976 530i e12
                                    1990 325ix e30
                                    1992 325i e36
                                    1995 740il e38
                                    2001 330xi e46
                                    ^More to come :)
                                      Seriously throw it away
                                      The URO brand I had lasted maybe 1500 miles before it split in half
                                        I’d 2nd that!
                                        However there is no provision for the small vac line that runs from the valve cover PCV to that clip (as we know in stock config there is a nipple there for it)
                                        • JeffJ
                                          JeffJ
                                          Jeff
                                          Now that is cool, wish I would have known about this 5 years ago.
                                          1976 530i e12
                                          1990 325ix e30
                                          1992 325i e36
                                          1995 740il e38
                                          2001 330xi e46
                                          ^More to come :)
