E30 M52
I looked at the project timeline I slated for this project and it should have been done by this week. I hadn't foreseen the Helicoil conundrum, but had that not been an issue I would have been pretty close.
I am a fan of making a goal and mentioning it to people so it gives me some accountability. I rarely hit the intended goal but I am sure I wouldn't make as much progress otherwise.
With that said, the new goal is to have the engine in the car and fired up by the Saturday after Halloween.
This week's goals are:
-Cleanup and install PS pump (the one I originally had for it doesn't fit)
-Blast the headers, order ceramic coating
-Modify shift linkage
-Replace trans input shaft seal (I don't think I recessed the seal far enough onto the shaft last time so I had some drops inside the bellhousing)
-Clean up and identify all connectors on wiring harness
-Mount wiring harness to engine
-Modify and install oil pan once and for all
-Install new rear main seal, flywheel, clutch, PP, and trans
Reasons why It wont be complete before Halloween:
-New control arms, resonator, Y-pipe, e-fan, and new master cylinder haven't been ordered.-Still have not renewed the registration. Going with a Hobbyist plate this time.
-Needs exhaust welding
-Needs alignment
-Needs a few small odds and ends and probably a new battery.
Im getting more acquainted with my ground-based spaghetti monster (as opposed to the flying variety).
Off the top of my head I think all I have left to identify are the connectors for the:
-Vanos solenoid
-oil pressure switch
-TPS
Aaaaand a whole bunch of ring terminals, grounds, and things I may wrongly identify as grounds which will fry something.
(Halp!)
Cam sensor is 3 prong
Vanos solenoid is 2 prong
CPS is 3 prong
Intake mani is 2 prong
Oil pressure is 1 prong
TPS is 3 prong
ICV is 3 prong
E36 coolant temp sensor for ecu 2 prong
M20 coolant temp sensor for cluster is 1 prong, but the harness has a 2 prong connector
Knock sensors are 2 prong (3 spaces though)
Purge valve solenoid guy is 2 prong
I forgot to look at my e34 pan for the level sensor- don’t think my harness has a provision for it though (haven’t seen any stray Bosch style connectors)
I am pretty sure it is the oil level sender, which leaves one connector with two pins that is wired into the X20 connector, and all the +/- ring terminals. I just cant trust that all the black wires are grounds and all the red wires go to the battery block so I will spend tonight tracing those all back to the connectors. There are also a couple connectors that clip into the harness bracket under the manifold. I need to find out which connectors fit into those spots (on the M20 it was the crank position sensor and the cylinder reference sensor) and get an idea of how the harness is supposed to lay/mount in the bracket. If anyone has or can find a good photo of an M50/S50 under the intake manifold it would be much appreciated. I'm just seeing a lot of pictures that are OBD2 or are obscured by the spidey hose
The wiring harness sleeves are a little tedious but very satisfying, thanks to Mitch for introducing them to me. I picked it up from Pegasus
The knock sensor connectors are secured into a bracket and oppose one another. Right under the icv. The other connectors that “slide” into brackets are the crank sensor and maybe the vanos solenoid wire? And cam sensor maybe?
I have the worst memory known to man. I didn't take a pic of the power block, text me tonight and I can take a picture of my other e36 engine that is sitting in the garage on a furniture dolly, it will be easy to see where the harness goes. I pulled it with the harness attached. So it is laying in the tray like it is supposed to be. Mine won't have the oil level switch but otherwise should be just like yours.
The only ground wire that ends in an eyelet is the one that is part of the diagnostics connector. The other wire is red under the sheathing, and as thus goes to the positive terminal, along with the cable from the starter. This is per my memory so I would verify.
E36 or E34 Harness? I need to stop at the shop tonight and can verify a couple connections if need be. If you have connectors in question just check continuity from pins on the ecu to find what they are, easiest way in my opinion.
