  4. E30 M52
E30 M52
    Not too many unknowns, but a lot of little things.
    The shift linkage and shift carrier (maybe, need to see how this fits in the car) need to be cut and rotated 10-12 degrees. Im not sure if my E30 power steering lines will work with this mystery E36 PS pump im using.
    I will need to make a bracket for the oil dipstick tube, weld in the skidplate, blast and coat the headers, trim the oil pan if the flywheel rubs on it, install a new master cylinder, install new control arms with my new lollipops (mostly for exhaust clearance), finishing the exhaust system, buying a silicone intake elbow, buying and installing an electric fan, rethreading my e30 gauge cluster temp sensor, finding the correct OBD1 ecu coolant temp sensor (part number shows up as NLA but that cant be right) and identifying all the harness connectors since they are all very similar and unlabelled.
      If you need custom lines made, Hartland service does real good work for real cheap.
        UUC makes a swap DSSR now that corrects the offset. Garagistic also copied it.
          **Carrier does not need to be cut or rotated as it will rotate with the trans (rear mount it round)
          Linkage can just be heated and bent if you don't want to get crazy.
          Stock E30 PS lines have always worked fine for me, including mounting the res. to the motor mount arm with the e36 bracket.**
          Any Blue temp sensor from an E36 will fly, less a 318.
            I had looked at that, but I already have a regular UUC DSSR so modifying it may be the best way to go.
            Unless somebody on here wants to buy mine for $80 that is.....
              Thanks, Jammin Ben!
                I always wonder how much you cringe when you see me posting in here. I think I usually complain about your weird way of doing things lol.
                  What length?
                    • The shift linkage and shift carrier (maybe, need to see how this fits in the car) need to be cut and rotated 10-12 degrees. Im not sure if my E30 power steering lines will work with this mystery E36 PS pump im using. Carrier does not need to be cut or rotated as it will rotate with the trans (rear mount it round)
                      Linkage can just be heated and bent if you don't want to get crazy. Stock E30 PS lines have always worked fine for me, including mounting the res. to the motor mount arm with the e36 bracket.
                    • I will need to make a bracket for the oil dipstick tube
                    • weld in the skidplate
                    • blast and coat the headers
                    • trim the oil pan if the flywheel rubs on it
                    • install a new master cylinder
                    • install new control arms with my new lollipops (mostly for exhaust clearance)
                    • finishing the exhaust system
                    • buying a silicone intake elbow
                    • buying and installing an electric fan
                    • rethreading my e30 gauge cluster temp sensor
                    • finding the correct OBD1 ecu coolant temp sensor (part number shows up as NLA but that cant be right)  Any Blue temp sensor from an E36 will fly, less a 318.
                    • identifying all the harness connectors since they are all very similar and unlabelled
                    I felt like I was ready a poorly listed craiglist ad. I fix dis for yew-
                      I dont cringe, but it can be frustrating when you tell the entire nation that you did not have sessual relations with that woman and they still dont believe you.
                        The valve cover gasket I received is for a non vanos engine.
                        I first started trimming off these locating pegs from the gasket, passing it off as a small difference between X50 and X52 cylinder heads. Then after laying down a nice bead of RTV I lay the thing on and it doesnt clear the vanos unit 🤦🏻‍♂️
                        The header flange openings match up pretty well with the exhaust ports on the head. Since the gasket is large enough, I decided to radius the edge of the port to help with flow
                          Curse BMW and their silly plastic power transmission components
                          I have aluminum pulleys to replace them with. I just thought it was important to draw attention to these plastic abominations before they hit the trash
                            I will need to do that to my headers. Thanks for the reminder!
                              I looked at the project timeline I slated for this project and it should have been done by this week. I hadn't foreseen the Helicoil conundrum, but had that not been an issue I would have been pretty close.
                              I am a fan of making a goal and mentioning it to people so it gives me some accountability. I rarely hit the intended goal but I am sure I wouldn't make as much progress otherwise.
                              With that said, the new goal is to have the engine in the car and fired up by the Saturday after Halloween.
                              This week's goals are:
                              -Cleanup and install PS pump (the one I originally had for it doesn't fit)
                              -Blast the headers, order ceramic coating
                              -Modify shift linkage
                              -Replace trans input shaft seal (I don't think I recessed the seal far enough onto the shaft last time so I had some drops inside the bellhousing)
                              -Clean up and identify all connectors on wiring harness
                              -Mount wiring harness to engine
                              -Modify and install oil pan once and for all
                              -Install new rear main seal, flywheel, clutch, PP, and trans
                              Reasons why It wont be complete before Halloween:
                              -New control arms, resonator, Y-pipe, e-fan, and new master cylinder haven't been ordered.
                              -Still have not  renewed the registration. Going with a Hobbyist plate this time.
                              -Needs exhaust welding
                              -Needs alignment
                              -Needs a few small odds and ends and probably a new battery.
                                Hobbyist plate. Very good idea.
                                I like that you devise a timeline. I do that in my head hoping its realistic but it rarely is.
                                • JeffJ
                                  JeffJ
                                  Jeff
                                  Hobbyist plates are awesome!! I need to get one on the 740il next year
                                  1976 530i e12
                                  1990 325ix e30
                                  1992 325i e36
                                  1995 740il e38
                                  2001 330xi e46
                                  ^More to come :)
                                    Is hobbyist plate one time fee? Is it like a collector plate, just for modified cars?
                                      That's how I understand it
                                        Ok, I like to tell people at my work about my car plans, because they tend to ask you consistently why you aren't driving that car to work.
                                          Im getting more acquainted with my ground-based spaghetti monster (as opposed to the flying variety).
                                          Off the top of my head I think all I have left to identify are the connectors for the:
                                          -Vanos solenoid
                                          -oil pressure switch
                                          -TPS
                                          Aaaaand a whole bunch of ring terminals, grounds, and things I may wrongly identify as grounds which will fry something.
                                          (Halp!)
