  4. 5 speeds, 4 cylinders, 3 doors, 2 wheel drive, and 1 loose nut behind the wheel
60 Posts 17 Posters 1.1k Views 1 Watching
    Nice purchase! What are your long term plans for it? Keep it stock but then decide to tear it completely apart and replace ever nut/bolt/seal/gasket? 😒👀
      FYI, e46 seats will bolt in directly. I've seen quite a few decent deals on sport seats. Much more comfortable than any e30 or e36 seat. I've got a set of e46 m3 seats that will be for sale that have all of the electronics sorted for plug and play already. Not sure that you'd want to spend that kind of money, however.
        very cool. ice racing this beast?
        Leaning towards yes, but not sure. Will probably hold on to the e34 for a while. Hoping the e34 wheels will fit on the TI so that I can use the same set of snows on either car.
        I have some black e30 sport seats that are taking up room in my garage...
        Interested. PM me some pics (of the seats...)
        Long term I'd like to do a 2.8 or 3 liter swap. First priority is still working on the e21, so I probably won't even touch this thing until after the snow flies.
          The wheels from the e34 will fit just fine😁
            Awesome!! Looks like it's in pretty great shape too!
              Those would probably look more at home in there than the e30 seats. I might see if I can find one to try out. Is there any difference between the M3 seats and "regular" sport seats?
              These look pretty nice, but it looks like the guy doesn't really do them anymore:
              https://www.r3vlimited.com/board/showthread.php?t=359721
              I do kind of prefer cloth. Mechanical adjustment is also a big bonus over electric for me.
              Hadn't noticed that the price of e30 sport seats has gone completely insane on ebay. I could probably find another pair of e21 Recaros for less 😆
              ...or a brand-new pair of GTS-IIs for that matter.
                I'll have to look again but I saw some E46 sport seats (black) for sale somewhere for something in the area of $200 and they were in good shape.
                  I found a pair here for $275. Might be okay after a thorough cleaning.
                  https://minneapolis.craigslist.org/ank/pts/d/2005-bmw-330xi-parts-car-or/6252890049.html
                  Hasn't turned up much for me yet, but this is an interesting resource:
                  https://en.wikipedia.org/wiki/Recaro#Cars_with_OEM-installed_Recaro_seats
                    You'll want to find coupe seats so you can flip them forward
                      Cheap e36 sport seats https://eauclaire.craigslist.org/pts/d/e36-bmw-black-seats/6291827708.html
                      30 mins from me.
                        That's what the hatch is for
                          I've had to crawl in through the hatch before. It wasn't too fun lol
                            So... nüb question here. My check engine light is on; what's the easiest way to pull the codes on these things (early '96 model)? I'm assuming the good ol stomp test doesn't work anymore?
                            This OBD-II life is new to me. It's different, and I don't like it.
                              Need an obd2 scanner
                                ^ditto lol
                                  I have an ultra-gauge for my M3 and its been an awesome purchase. Gives you a live readout of a lot of the sensor data used by the ECU including engine coolant temp, intake temp, throttle position, O2 sensor voltages, etc. You can set audible alarms for things as well which is super useful for keeping an eye on your coolant temps. More improtantly, it can also read and clear check engine lights!
                                  http://www.ultra-gauge.com/ultragauge/
                                    You can even go to any auto store and have them scan it for free
                                      This is really sweet for the price!
                                        Yeah! Its not the most quality construction (housing is a little flimsy and the buttons on the back arent great) but it works really well and you definitely can't complain at that price. I would 11/10 buy another without thinking twice.
                                        They occasionally have sales (at least they did when I got mine two-ish years ago, not sure now) for 5-10 off too
                                          Finally got the car registered and did some driving. It did pretty well, but the chassis isn't exactly confidence-inspiring with bad subframe bushings. Also had some shimmy through the steering wheel and vibration that feels like a wheel out of balance.
                                          Got the car up in the air at the shop and was still really impressed with how clean the undercarriage is. No rust surprises at all. Giubo looked great. Fuel filter has definitely been changed and looked relatively new. Exhaust is solid, although seems to be missing a hanger somewhere (no support at all between the header and the rear subframe). Trans-mount bushings are super soft and need to be replaced.  Insulation in the front of the tunnel is drooping and wore the paint off the driveshaft. All-in-all, not bad at all.
                                          Also did a quick alignment using the string method. Had almost 3/8" of toe-in on the front. Dialed it back to about 1/3rd that amount. That took care of about 80% of the shimmy and the car feels less dart-y now. There's still definitely something amiss in the rear. So far, I like the car and am hoping to have it far a few years, so I'm currently planing on dropping the subframe and doing all-of-the-things "while I'm in there".
