  4. Exhaust Leak
Exhaust Leak
19 Posts 10 Posters 0 Views 1 Watching
  • AlpineE30A
    AlpineE30A
    AlpineE30
    unless you have a moral obligation towards our environment, then don't bother with the catalytic converter. but if its still on the car, i'd leave it. if the car is lacking one completely and the PO replaced it with straight pipes, I'd go with a resonator instead - it will make the car sound better. resonators will take some the 'harshness' or 'rasp' out, although the m20 doesnt have a lot of that to begin with.
    you didnt explain what is on the car - what did the PO modify?
    Exhaust leaks are 100% the reason your car doesn't sound good. 1st thing I'd try is just drop the exhaust and weld up any holes. If you still don't like the sound, add a resonator like Dan said. It will have the same (if not better) effect as a cat and will cost a lot less.
    Currently it has aftermarket header with straight pipes back to the stock(?) muffler. I plan on welding up the holes, but don't want to have to drop the exhaust twice.  I hadn't looked into resonators.  Thanks for the tips, I may just weld the leaks this weekend and see how it sounds.
      try wrapping the holes with exhaust wrap to see how it sounds. you wont have to drop it for that. (if they are accessible)
      • AlpineE30A
        AlpineE30A
        AlpineE30
        That's what I was going to do originally, but it is too tight to the undercarriage to get above it.  I'll drop/weld it this weekend and let y'all know how it goes.
          The exhausts are really easy to drop on these cars, although I don't know what your header setup looks like. Wouldn't be a bad idea to drop it all and make sure the exhaust manifold gaskets weren't reused and part of the current problem.
          • AlpineE30A
            AlpineE30A
            AlpineE30
            Good Call. I'm planning on doing some work on it tomorrow.  I keep y'all updated.
              They scrap them because of the valuable metals inside.
              This. There was a local guy who would advertise on CL, business name was Competitive Core, and would pay well for the older larger cats like from an e30 (Snap remember "catman"?).
              There was also a problem a while back or maybe it was urban myth about folks coming out to their lifted pickups/SUVs and finding the cats cut out of the exhaust. Easy to crawl underneath with a cordless sawzall, make a couple quick cuts, and sell to a less than scrupulous scrap dealer.
                I remember catman. Sold him my e30 cat. He then decided to throw certain objects at folks and went to prison
                  Catman fell from grace
                    Catman do...throw a dildo or two
                    • AlpineE30A
                      AlpineE30A
                      AlpineE30
                      Didn't have time to drop the exhaust and do the weld. I was able to get the car jacked up and threw some Permatex Puddy. It does sound a little better, but still has a ratty tone to it. Looks like I'll be picking up a cat or a resonator to clean up the sound all the way.
