  4. Dd e21
Dd e21
39 Posts 13 Posters 0 Views 1 Watching
  • Ryan...R
    Ryan...R
    Ryan...
    An e21 with s50/m50 swap would be tits... a real sleeper!
      Turbo cis FTW!!!! :P
        Hey guys! I just finished my century turbo kit installation yesterday. Here is a list of what I did as well ...
        Century Turbo Kit
        Volvo 240 Turbo AFM
        Volvo 240 Turbo FD
        Volvo 240 Turbo WUR
        VW Braided SS Injector Lines
        I was having issues starting the car yesterday. It would start, idle up to 1100 rpm and then die. Eventually it was to the point that it would just crank and crank and wouldnt fire. Sagaris came over this morning and we messed around with it some more. We noticed that a puff of smoke came from around the cold start injector on the manifold, so we figured there had to be a vacuum leak there. Sure enough there was. I got a new o-ring and studs and reinstalled it. When cranking this time, we turned the dizzy until she fired up and idled. WOOHOO were we excited!!
        Once we got it running, we then fine tuned the timing and the air/fuel ratio. All seemed to be perfect, smooth acceleration and everything. Until we shut it off.
        We shut the car off, let it cool a little, and topped off the fluids for a test drive. When I went to start it up again, crank, crank, crank, crank, ... no fire! GAAAHHH!!!!! We had it! I guess thats the joys of k-jet. Lol.
        We started messing with the air/fuel adjustment and timing again with no luck. Just keeps cranking and no firing. After a good half hour of fiddling, I noticed that the fuel pump wasnt buzzing anymore for a couple seconds after cranking. Something wasnt triggering the fuel pump to come on anymore. Pulled an injector and cranked the engine over, no fuel. We then jumpered the fuel pump and fuel came spraying out of the injector. So, the pump is good, the wiring or something that tells pump to come on when ranking wasnt right. we tested the pulse sender for continuity incase it shorted out somehow, but that was good. We came back from the e30 et together and tried it one more time. Low and behold, the fuel pump was buzzing again. How does this happen, i dont know. All I can think of is that the impulse sender plug came loose from turning the dizzy. So now its back to square one with air/fuel adjustment and timing.
        Sorry for the long rant, just thought I would fill everyone in on whats going on.
        Posted Image
        Posted Image
        Posted Image
        Posted Image
          SO CLOSE!!!! I bet that fuel pump relay got extremely pissed off from all the on/off action. Hopefully you are just a few turns of the allen-key away from getting it going again.
            SHE RUNS!!! I put some new spark plugs in since the old ones were mighty roasted and cranked the fuel adjustment screw on the fuel distributor/airflow meter about 12 turns to the lean side and she finally started. Idles at 900 rpm, afr hovering around 14.7, and vacuum at 19 at idle. Couldnt ask for anything better. Today I got the timing dialed in and I took it for a little test drive. Its loud (downpipe only for now), stinky, and AWESOME!! I didnt hammer on it too much, since I didnt wanna lose my hearing. Hopefully this week I can get it to the exhaust shop to finish up that and she should be ready for some fine tuning. Turbo k-jet FTW!! :P
              Exhaust was done this past tuesday and sounds awesome! Its a 2.5" downpipe made from an 09 Dodge Challenger exhaust:p that mates up to a flex pipe. From there its 2.5" all the way back to a Vibrant stealth muffler tuckedback a bit. This thing pulls way harder than I ever thought it would. I'm currently running at 9psi with an open wastegate that screams under boost. Might throw on the wastegate silencer that came with the kit. Lol. I am real happy with the outcome. Especially since its turbo kjet that everyone shys away from.
              Definitely have to make a shout out to Brian for all the help he gave me while doing the work. Big Thanks!!!
                Congrats! Looking forward to seeing this car around
                  I wanna see this bad boy! Another turbo'd car! -2.9i HKS 35R Turbo'd E30 :0
                    Thanks guys! Sure does mean a lot to get some love for an old e21. :D Cant wait to bring her out to the next meet now thats shes finally running again. :)
                      This car is a lot of fun! Makes me want a turbo M10 car
                      • need4speed1299N
                        need4speed1299N
                        need4speed1299
                        Good to hear its alive once again! I still miss the car.
                        • mystere30M
                          mystere30M
                          mystere30
                          ZOMG!! too many good times in that beast. i love that car
                            That explains the prophylactic rubber under the seat :eek:
                            • mystere30M
                              mystere30M
                              mystere30
                              lolz...nuh uhhhhhhh...
                                ^^^^ HAHA!!! ^^^^
                                So i recently received some coilover sleeves and springs in the mail as well as installed a new-to-me front valance and alpina front spoiler. Check it out!! *terminator voice*
                                Valance and Spoiler waiting for paint
                                Posted Image
                                Coilover Sleeves and Springs
                                Posted Image
                                • need4speed1299N
                                  need4speed1299N
                                  need4speed1299
                                  Lol. I thought she wanted my babies all these years.
                                  • kyletime666K
                                    kyletime666K
                                    kyletime666
                                    Bassboy3313 said:
                                    ^^^^ HAHA!!! ^^^^
                                    Posted Image
                                    Posted Image
                                    did you install the springs and sleeves yet. Wondering how well that works and the process of installing them.
                                      I have not installed them yet. The guy I got them from runs a set on his e21 and said they are great. I will let you know how everything goes when I install them hopefully over the winter.
                                        OR SOMETIME THIS WEEK
                                        Posted Image
                                          Or tomorrow. I'll even help.
                                          With your input, this post could be even better đź’—
