  4. chit chat thread
chit chat thread
    Where's my shit? Haha kind of excited
      Started parting the coupe tonight=/ Sad but the goodies will be spread among a few members here=P The car in stockish form is actually also going to a member
      Why?
        Easy way to free up money and shift my priorities back onto the compact instead of constantly worrying about fixing the coupe. Plus who can say no to 40mpg's when they're used to 25mpg's haha
          Corolla S as a replacement?
            Honda Del Sol Si!
              Honda Del Sol Si!
              I saw you asking for parts for that.....wow, what a down grade, but you knew that.  You are 100% correct in that it will keep your focus on the compaqut which is nice!
                Soul sucking front wheel drive...
                  Started it on daily duty today and it is actually surprisingly fun to drive=)
                    Speaking of super fun practical cars... It looks like I will be learning how to rebuild a U151F automatic transmission from my Sienna van.  It was working better after cleaning the valve body but still has problems when it gets hot.  It just seems to totally disengage.  When cold it actually works pretty good.  Too much fluid leaking around spools in the valve body?  I have no idea but I am going to take it out and disassembly, I found FSM documentation of the disassembly/assembly procedure and specs for clutch pack clearances so it can't be that hard...
                    No matter what I won't really trust it not to leave my wife stranded until I fix it properly.  I tried the easy stuff already (Lucas trans doctor) and the medium stuff (take the valve body apart and clean it).
                      On as scale from 1 to snorting Brake Cleaner: How awful is transmission removal on a Sienna?
                        Probably about 6 cans worth of snorting.  It appears that it is possible to get it out without dropping the cradle/engine/trans assembly together but it looks easier to drop it all together.
                        To take this in a different direction it appears that an e153 transmission used in Camry's bolts to the 3mz engine...  Cross referencing axle shafts it appears that the splines are the same and the dimensions are almost identical between Auto and manual transmissions.  And the splines and critical dimensions of the 2nd gen Sienna driveshafts are the same, just the outboard part is longer because the vehicles got wider.  So that would lead me at this point to think I could use my existing axle shafts.  I need to do a little more research on that but it doesn't appear to kill the idea.
                        Other problems I am not worried about: routing shifter cables, fabricate shifter in the console, clutch pedal and master cylinder.
                        Problems I AM worried about: ECU freaking out with no auto transmission.  I have seen solutions (none in a sienna) ranging from ground a certain pin, presumably telling the ECU that the transmission is in neutral, to using a 1MZ ECU/electronics/intake manifold (that loses the VVTi)  I saw some swaps of the 3MZ and e153 transmission into MR2s which would be pretty awesome.
                        Why would I manual swap a Sienna?  I am crazy.
                        This van is an '04 with 172k, I got it for $2200 because the transmission didn't work.  It's an XLE Limited with every option including AWD which would be lost but I don't care about that.
                          My 3MZ is rather unrefined and coarse at higher rpm. The 2MZ non-vanos in my 99 sienna was a lot more smooth. How is yours?
                            Like any other Toyota, also like the VQ30 that was in my Maxima, Not bad but definitely Meh...  It's sure no BMW.
                            I lol'd at "non vanos"  Pretty sure that would be a 1MZ.  The 2MZ was a 2.5l and not in Siennas here.  Yours would have the 3.0.
                              Right you are, Ken!
                                does the fluid on the dipstick look foamy/ bubbly when hot?
                                  No, it looks fine, other than being dark. I changed about half of it with redline d4.
                                    Yeah clutch packs are probably cashed out.
                                      A manual sienna sounds miserable.  It's bad enough driving a mini van let alone having to actually be cognizant and conscious while doing so. They're the most practical thing a human can own but they're soul sucking mobiles.
                                        They did make the Previa with a manual trans, but those were rwd
                                          Yup, I will take it apart and see what it looks like.  Used ones are expensive, I will try my hand at rebuilding it myself.  Individual friction and steel discs are available, it can't be that bad.
                                          Eh, I am crazy, I'd rather shift it myself.  Yes it is still a soul sucking vehicle, I won't be driving it much thankfully.
                                          Bad news though, TCU and ECU are integrated as one unit.  That kills my chance of swapping.  I am not going to go through that much work to figure out ECU programming.
