ILC's E46 wagon
Picked up the car last week and it was a top driving it off the lot. Made it home, drove it around some more, and when I left for soccer that evening, CEL came on for exhaust side vanos, lol. Idle shot up to 800 rpm, loss of power, etc. I had to laugh because I literally had my E46 for all of 6 hours before a fucking vanos issue popped up. I don't know how more cliche it can get.
There was oil in the sensor housing for the exhaust side cam position sensor, and the entire sensor assembly was caked in it. I'm sure that fried it and is why I got the CEL. The oring must have failed. Despite that, in addition to replacing the sensor, I'm redoing the vanos seals with the Beisan replacement kit, and I'm glad for it because popping the valve cover off revealed the VCG had completely baked around the spark plug cylinders. Cylinder 3 plug was nearly submerged in oil. So I got new spark plugs, and new VCG as well.
Still waiting on a couple parts from Turner but everything is out and ready to be re-installed once the rest of my replacement washers and orings arrive.
looks good to me
looks good to me
EDIT: Dammit Snapsby
DUDE LOL
That looks like an S54 I tore down once that had a lifetime of the BMW-recommended 20k miles/oil change intervals. Although I think they changed the official interval now to be lower, it's still asinine.
Was this photo one of your cars?
I don't know who's fucking with you (SNAP) but that was the last photo you posted yesterday. I assumed it was slipped in as a joke but that was definitely in your post yesterday.
I must've been too busy paying attention to other things to notice
Dammit it's not even April Fool's yet, shitfuckers!!
So, updates on my autotragic shifting daily:
I finished replacing the vanos seals, slapped the new exhaust CPS on, new spark plugs/VCG, then started the car and still had the same CEL as before - P0014. So assuming the new sensor was good (I ponied up for OE, not the cheap China reps that fail immediately), and the fact that I didn't fuck up the vanos seal install (no new codes about anything being stuck open), the next thing was to check solenoids. I don't have the fancy schmancy 36mm specialty deep socket for the solenoids, and couldn't find my vicegrips so at this point I called TJ over. So we swapped the intake and exhaust side first obviously - same result, P0014 exhaust side. The car needed an oil change anyway so that was next to check as amazingly some people have resolved this code with an oil change which seems crazy to me but whatever. Well, somehow that actually did help. The code didn't come back right away but still persisted after a few more shut off/turn on cycles.
That was a clue though - so we took both solenoids off and tried to remove the pistons/spring assemblies that the solenoids compress. The intake side was springy and came right out. The exhaust side, however, was completely stuck for some reason. Couldn't compress it and had a bitch of a time pulling it out. Once they were both out, everything looked identical and nothing was broken, spring tension was good. Reseated everything and the exhaust side felt normal again. Buttoned things back up and the CEL was gone for good, car was idling normally, and so on. I have no idea how that piston got seized but that was the root of the problem all along it would seem.
It wasn't wasted effort as it certainly can't hurt that I put new vanos seals in a 155k mile E46.
Following that, I had Kummrow do the messy business of swapping the trans filter/fluid, transfer case fluid, and fluid in both diffs.
Moving on to suspension - the rear driver spring was cracked (no surprise), rear driver wheel bearing was worn, both half shafts were leaking (also no surprise), and front control arms needed replacing. So replacing all that including some H&R sport springs, the car feels like new again. I just need to clean up the undercarriage because there's still gear oil everywhere from the leaks and it fucking reeks of sulfur in the cabin while driving.
The coolant expansion tank is hissing at the neck and the place I bought the car from put non-BMW coolant in the car, so I figure that's a good excuse to replace the expansion tank anyway just to be safe. So I have a new one in the trunk that I will install sometime this week.
Last step is taking the car over to TJ's friends for body work estimate on repairing the crease in the front fender, and the crack in the bumper.
I'm so excited that I will soon be able to focus on the far more important things like bags, vape vents, and Minions stuffies.
Alright friends, the time has come to employ your assistance.
I listed my E46 for sale yesterday but I'm regretting that right now given that it's a rust-free sport wagon and I've already R&R'ed so much other stuff - all it really needs is a manual transmission to be 100% perfect as a year-round daily in Wisconsin.
So I think I'm gonna swap it and keep the car. I'm either gonna do it before winter, or first thing next Spring. I'm more inclined right now to just track down a decent transmission, harness and maybe pedal assembly. The rest is all off the shelf and can be bought at any time.
I have watched all the ShopLife vids that detail this swap end-to-end on a RWD which isn't terribly different. It's actually easier on the AWD models because you can reuse the entire driveshaft for AWD. If I can source a transmission from another touring AWD (unlikely) it would preserve the current diff of 3.46. If I get any other AWD manual, it's a 3.23 - oh well. The biggest difference between RWD and AWD swap is just how many more bolts you need to remove to get all the AWD crap off.
By my estimation, the parts needed are as follows:
- manual 5sp trans and transfer case from a 325xi (possibly 330xi? not sure if that fits yet but i've heard it does)
- new clutch/FW
- new guibo and probably center support bearing
- shifter assembly (uuc dssr probably absolutely)
- pedal assembly
- clutch lines
- transmission wiring harness
- new engine mounts and transmission mounts
- new rear main seal
- ZHP shift knob obviouslyand I've got people to do the coding when it's all done.
So, if anyone has any beats on a 325xi manual transmission (and ideally a transfer case as well with mounting plate) - send it my way.
I'm currently looking at potentially buying the following assembly but I haven't done enough market research yet to know if it's a good deal or not: http://www.ebay.com/itm/142465262971
ok spent more time researching it last night and while the swap itself isn't that bad, in order to do everything right, I think parts are gonna cost more than I originally had hoped. Probably around $2500. Factoring in that my time is worth a lot, it does really seem like my best bet is to cross off the AWD idea for my daily and just get a RWD wagon with stick and m-sport and put snow tires on it for winter.
One of my old tenants lives in Austin now and works for one of those supercar driving experience outfits. He is a wagon bigot like me and finds good shit all the time so I've sent him on a mission to find me a rust-free example (not hard down there obviously) and I'll just keep driving my current e46 in the meantime until it sells.
I ran across this if it's of any help or if you change your mind:
https://madison.craigslist.org/pts/d/03-bmw-330xi-manual/6274783392.html
Come say hi when you grab this!
not gonna lie, i just texted the guy. That's a great price if everything is in working order, thanks
ok fuck it we're doing this. The guy agreed to take 250 for the transmission which is at least $300 less than what ebay was gonna hit me for. Good job Spence.
@YoungCR i'm literally heading over to pick this up right after i make coffee and surf the web for a few more parts. So I'll likely be out that way by late morning maybe 10:30 or 11
now i need a pedal assembly. Find me one of those plz k thx
The rest of the stuff like clutch, shifter hardware, etc. i'll just buy brand new
Air lockers for rock crawling mode
Nice clean transmission
What is the air line for?
Shame on BMV for still having the single shear shift rod design
pretty sure it's a vac line for the shift sensor but i haven't fully gone over everything yet
