  4. E30 M52
E30 M52
    I enjoy coming to this thread and seeing updates!
    Keep up the good work!
      Fall meet or bust!!
        Bust meat or fall!
          bust meat or fall!  hahaha!
          The forum has felt a little bit slow lately so I'm glad to know the thread has some traffic.
          I was on Joe's case to make it to the picnic and now I'm in the hot seat.
          It's going to be mighty close
            the summertime boom in a Midwest town. gotta get all the activities in.
            lovin the updates.
              Between a kid's birthday party out in bum-fudge land and a dinner date all I got done was a few finishing touches on the brake booster. My revised tune did arrive though. 7100 soft limit, 7250 hard limit instead of the 7400 limit before, stock is 6500, also set for 93 octane instead of 91 as it was mistakenly set for before.
                Keep it up!
                  The brake hard line retainer needed some modifying in order for the E21 booster to sit flat on the firewall since it does not stand off as far as the E30 booster does. It looks like this may not be an issue if all the firewall insulation was removed but I like my firewall insulation.
                  There are two spaces for the hard line to snap into and one of them simply gets cut off with a dremel.
                  The firewall gasket is either NLA or im not seeing it on RealOEM. I gave it a go making my own gasket with some gasket material but ended up just running a small bead of clear silicone that wont bond the booster to the firewall
                  The booster is in and connected but I will leave the kick panels off until I can find a clutch return spring.
                  When I did my manual swap I dont think I had the clutch return spring, and it isnt really needed except to pull up a 1/4" of dead travel in the pedal when its disengaged. I find myself instinctively lifting the backside of the clutch pedal with my left foot. It isnt hurting anything but my subconscious mind obviously cares about it so I better install a return spring for it.
                  Its also possible that the automatic pedal box didnt have the provision for the spring attachment or something. I forget.
                    More progress! I like this. I had no idea your car was originally an auto. Intradusting!
                      Time for my daily micro update with almost negligible progress!
                      I received some more gaskets and seals in the mail. I cleaned up the crustaceans inside and outside of the water flange on the rear of the head, replaced the gasket, I dont care that it has a small bead of embedded silicone, im adding my small slather of gray RTV anyways.
                      I started working on the rear main seal
                      We have a nice little groove here. I will install the new seal with maybe 1-1.5mm protrusion so it rides on a clean surface and doesnt hang up on the groove when being installed.
                      Should work like a charm. If I ever need to mess with it again I will do a speedi-sleeve
                        DUDE
                        THE DAMN LAST 1/4" OF PEDAL TRAVEL
                        My car was also manual swapped at some point in it's life.
                        I cannot stress how often I pull the pedal up with the top of my foot.
                        Drives my OCD insane
                          And I thought I was the only one [emoji16]
                            Tonight I installed the rear main seal into its carrier, protruding 1.5mm. I will wait until I install the E34 oil pan to install the carrier/seal onto the block.
                            Out of my own curiosity, I wanted to overlay all the BMW 2.5L engines: M20B25, M50NV, M50TU, M52B25, M54B25, N52B25 and see how the torque curve flattened over time with all the technology advancements. Instead I lost interest and threw the modded M52 data over some data for
                            a stock M20B25 vs. an M52B28, M50 manifold, S52 cams, intake, exhaust, stock ex. manifolds, and tune.
                            I remember having fun with my stock M20 so it appears there is a little more fun in store with the M52. Next week will for sure see some significant progress as I will have some extra time, but I will keep nibbling away at things this week like I have been doing.
                              When the vanos hits!!  In all seriousness though it is interesting that the the hp and torque curves have a similar profile between the two engines.
                                I noticed that as well. The M50 manifold and S52 cams sacrifice the low end, but definitely make up for it in the higher revs
                                  Hello turd.
                                  Last night I replaced the clutch hardline that had rounded hardware, scrubbed the engine bay, and cut off the intercooler mounts I had welded on.
                                  Tonight: more scrubbing and paint touchup in the engine bay. Nothing worth taking pictures of, but all necessary tasks to make me feel some level of satisfaction with my efforts.
                                    "You'll never get the crank bolt without the locking pin or at least the engine in the car"
                                    "Nobody ever gets the jesus bolt loose at home, its red-loctited from the factory"
                                    "Harbor freight tools are garbage"
                                    "Electric impact guns are inferior to a traditional air impact"
                                    Rubbish.
                                    This is the 4th BMW crank bolt I have removed with this 6 year old HF electric impact gun.
                                      And that same impact got my rear axle nuts loose on my trailing arms after they were already off the car. *thumbs up*
                                        Why not just get an OBD1 timing cover and avoid the JB welding massacre that will be installing the coolant pipe.
                                        Unless that won't work
                                          Im only removing them to check the chain guides, replace the seals, and clean them up. The covers should be milled with the head/block to keep from being too high/low so i will keep these since they match the engine
