276 Posts 17 Posters 0 Views 1 Watching
    So it's time to turd polish this thing??
      You're damn right it is. Time to stock up on buffing compound and buffing wheels.
      As a matter of fact, I bought a new fuel filter, plugs, cap and rotor, air filter, and sway bar end links already today.
        Awesome. Have you checked out body shop supply off of fish hatch? Finally went in there and they have everything at wholesale price and they carry Cook's stuff from over in Milwaukee.
        Ive forgotten to mention this to you too but pull the valve cover and check the oil spray bar, car needs a valve adjustment probably too. it's a common problem for M30's to starve the valve train of oil between the banjo bolts backing out and the poorly designed spray bar. Most guys do this mod to pinch the bar for better pressure.
        http://www.e9coupe.com/tech/spray_bar_fix/70590.html
          @YoungCRReally good information to know, I will have to do that once parts start showing up. I haven't dug that far into it yet as I have only been trouble shooting the electrical gremlins. I was impressed with the fact that is doesn't leak anything yet *(knocks on wood)* so I haven't touched anything that needed a gasket.
            A livery would peel off so you're not hurting the cars potential worth=P
              And I can hook you up with the livery too 😁
                Yous guys are really killing me. I really want to leave the car completely stock if I can control myself. I just bought this shirt which is self inflicting pain of possible modifications.
                Soo...........
                I tried to drive this two weeks ago and was highly disappointed when it developed the famous start and stall syndrome. No idea what was going on I started with thinking the cats were probably clogged from all the rodents that were living in the engine bay prior to my owner ship. So I did the fastest thing I could think of to solve the problem.
                I cut the exhaust off.
                A nice little pile of rodent home making supplies that fell out of the rotten muffler..
                .....And after all that, it still had the same issue, just louder. So I moved on to the intake side of things. These M30's have a flapper door for an Air Flow Sensor which is the predecessor to the MAF's that some cars still use today. I thought for sure this was my problem. I have this amazing write up from a gentleman that has saved me more than any Bentley manual could ever do. So I follow his step by step and tested the AFS.
                  With the ignition on you should see the following voltage
                • Terminal 1, blank,
                • Terminal 2, Zero volts, - I also had Zero here
                • Terminal 3, 4.0-5.0 volts, - I had 12 volts here!! uh oh
                • Terminal 4, 2.0-4.0 MILLIVOLTS - .8 milivolts here?!?!
                • Terminal 5, 4.0-5.0 volts.  - and 4.8 volts here
                So according to his guide, there was no reference to what you should do if you are getting more voltage than what you should. only suggestions if you are getting 0 volt  readings. I pondered and read further that there should be a relay that triggers the AFS on startup. I went over and tested the relay and it seems to work okay. So then I decided to test the harness. Doing so I found my problem. I have the main relay and the fuel pump relay powered with jumper harnesses to remove them as failures from the car starting. Doing so I only had 1 wire instead of two powering the fuel pump relay terminals. Because of this, I was not sending power to the AFS relay on start up.
                I made a new jumper and BOOM! Car started up and idled great. With that, I hopped in and finally drove it.
                IMG_3860.MOV
                It seems to have a stutter or misfire yet and the 1980's tires and worn suspension is obviously apparent. But man it felt great to finally have this thing moving under its own power 😁
                  This is fantastic to hear! Keep it up!
                    This just in!!!
                    New O2 sensor and Oil filter from the brown delivery gods. I failed and should have ordered a valve cover gasket too. 😦
                      You are a mad scientist, my friend! Vacuum leaks are always the go-to for those kinds of problems but they are always tedious to track down. Check the throttle position switch to make sure it is showing the ecu the proper throttle position during idle.
                        From what I have read according to the Internets (AKA my mad scientist kit) vacuum leaks will indeed cause this thing to run awful. Its the first on the list of the DIY guide I have been following, so I have already replaced the smaller vacuum lines, but have yet to move onto the larger valve cover breather lines and the brake booster lines. Those are to be replaced next as they seem really hard and brittle.
                          Well, I completed more work on this last night. I drove it a little further and it seems to drive much better when its cold vs. warm. Besides that it drives fairly well but the steering components really need some attention. I put it on the lift and took another gander.
                          • Control arm ball joint
                          • Tie rod center joint
                          • Tie rod support joint
                          • Out side tie rod assembly
                          • Front springs are still broken
                          • Strut bellows
                          Are all bad.
                          I did install new sway bar links up front as it was obvious they were bad.
                          After that I removed as many vaccum hoses as I could find, and scrubbed them with brushes and degreaser to inspect them for cracks and rotting. I was hoping to just replace some hoses to aid with the vacuum leaks, but it seems most of the hoses are specialty hoses so I had to order those that needed to be replaced. Surprisingly there was only one that had an obvious leak.
                          After all of this, I felt like the car needed its first bath in many years. I did a double wash, but the paint is in dire need of a cut and buff, so that will be next on the agenda.
                            Honestly with the grilles painted trim black and the front end put on, this thing would still look great as is=)
                              I need to get the grills off so I can paint them. They have studs molded onto the back side and they are spinning inside of the grills because the nuts are rusted to them. On top of that there is no room to cut them off without destroying the grills. So I keep putting this off, but I want to do it soooo bad.
                                You should be able to just drill out the screws. IF its the same style as the e28 grills those Phillips just screw into a plastic tab that goes into the core support. That or the screws themselves are plastic too. Double check the parts diagram haha.
                                  So no rack and pinion steering?! If so, today I learned something new
                                  V8 E39s dont have it either
                                    steering box ftw. E34's don't have a rack and pinion either.
                                      Looks like you learned something and so did I!! I had no idea about E39 v8's. E24's use a gearbox and linkage system.
                                      Well...... My e30 is like your describing, and so is this. BUT it also has ONE stud on the backside along with the screws. Here you can see someone also had the same issue highlighted in red...
                                        Well I was wrong. There are two studs on the backside that attach to the corner light buckets, not the grills. I removed them with impact driver, spinning them really fast, heating the studs up to the point plastic would giveaway and I could pull out the corner lights.
                                        I then removed the grills and the kidneys, which unfortunately will have to be replaced instead of repainted for two reasons. One is that the kidneys are dented and I rather save time and replace them vs. sanding and using filler to fix them. The other reason is that there is polished trim on the grills that has been painted over, and the amount of work to successfully strip that paint isn't worth it. Bigcoupe has a bunch of ppl parting out 6er's so I don't think I will have a hard time finding cheap replacements.
                                        Besides that, I also buffed the bumper and cleaned all of the trim that goes with it and remounted it to the car. To buff it I screwed it to a wooden table off of the car and went to town with some polish. I really wanted to tuck the bumpers on this thing, but now I am thinking Im just going to leave them because they are so ridiculous its kind of awesome.
                                        Mounting the bumper I also found that I'm missing brackets, and/or the entire lower valance that the Zender lip bolts to. Also the brakets I have, someone used the shittiest hardware ever, so they are all rusted so bad they are just rust blobs.So if anyone know of an E24 sitting in a salvage yard, or getting parted, let me know.
                                          I Also started clay baring and buffing the paint, but I need a lot harsher compound that what I was using. 😦
                                          This picture is kind of bad, but half is buffed and half isn't. It shows you what a difference even a light buff can do though.
                                          And some over all pics as it sits.
