    suspenceful said:
    Thanks man! I'm not quite sure what you mean by murder box in the passenger seat though 😕
    I've also been trying to figure out what it could be...
    Did Ben get a temp gun yet? If so, borrow Ben's temp gun
    What's a temp gun?
      I need both of you to please watch Death Proof.  Basically, Kurt Russel plays a murderous stuntman who builds cars to intentionally crash and kill either the passenger or others while he remains alive.  If you have any interest in Tarantino you'll like it.
        I got the oil pan cleaned up and re-installed with a new gasket. Having an industrial parts washer at my work helps. I also washed the subframe.
        Then I began to swap all the lines over to the new turbos but ran into a bit of an issue. While it was my own fault, I feel like I should share for any other MMP3 owners. As Mauricio notes, you must use small washers on the bolts when reattaching the oil feed and coolant lines to the new turbos. Otherwise you will bottom out the bolt and pull the welds off that hold the mount on. Ask me how fun it is to find out the hard way.
        Luckily I had a buddy who helped me weld the stainless mount back to the cast cartridge housing. It looks like it should hold just fine, but I haven't re-mounted the line yet. I might have to re-clock the turbos first. More progress tonight.
        Also, if anyone wants to watch a 10 minute vlog-style video of the first day I worked on the car, check this out. My buddy @SteelBlue put it together for fun. We're curious to hear some feedback on it or if we should scrap the idea. Not a whole lot of "useful" content, but I thought it was interesting.
          That subframe is indeed many times cleaner compared to when it came off!
          She's looking good, and you're on the install portion already!
            that must have been an intense moment of fear and frustration when that weld broke free but I'm glad to see its already resolved
              I took the long 4th of July weekend off, spent it relaxing with friends and family.
              I'm officially on the back half of this install. Yesterday I got back underneath the car and mounted both turbos, gaskets, lines and torqued everything to spec. The rear inlet elbow is on (PITA), but I know I'll still have a heck of a time shoving the aluminum pipe in from up top.
              Hopefully I can get back at it tonight and get the outlets, water pump, inlets, and power steering pump installed.
                I just sat and marveled at all that design and packaging for a few minutes. do you see a light at the end of the tunnel yet?
                  Have you looked at the center mount turbo v8 setups before? It's a thing of beauty.
                  Looking good! Glad to see the turbos mounted up!
                    It's definitely overwhelming, and you can only see half of it. Pretty crazy how someone (probably more than one person) designed all of this.
                    I see a light, but it's still pretty far away.
                      Larger inlets and outlets are on. Coolant pipe, water pump, thermostat reinstalled with new hoses. Power steering pump and intercooler reinstalled. Downpipes attached and O2 sensors connected. Subframe secured with new motor mounts. Hoping to connect vacuum lines and tidy up some loose ends tonight. Should be able to start it after adding oil, coolant and power steering fluid.
                        After getting some help from my girlfriend, I was able to start the car! 😉
                        I was able to put on about 200 miles this weekend without a hitch. It was a great feeling being able to start the car and drive it without a single issue. I don't have the upgraded fuel system installed yet so I'm limited to low boost, but I'm okay with that because I want to break in the clutch before cranking it up to 30PSI.
                        These things are loud! Constant spooling noises.
                        I was also able to finally weigh my car: 3260lbs with a full tank of gas. No exhaust or backseats (how I typically drive it anyways).
                        Here's what I've replaced (off the top of my head):
                        • Ceramic coated MMP turbos with all new gaskets and o-rings
                        • Inlets and outlets, both wrapped with heat-resistant tape
                        • Oil pan gasket and bolts
                        • Oil filter housing gaskets
                        • Water pump and related rubber coolant hoses
                        • Both motor mounts
                        • Downpipe v-band clamps with new gaskets
                        • Deleted vacuum canisters, ran new vacuum line
                        • Power steering fluid, coolant, oil
                        • SPEC Stage 3+ clutch, throwout bearing, clutch fork
                        • Poly transmission mounts
                        • Aluminum bellhousing bolts
                        • Rear pinion seal
                        • Rear differential fluid
                        • Shifter bushings
                        Stay tuned - fuel system going in soon, then dyno time.
                          Nice!!
                            You work quickly!
                            I'm looking forward to hearing about how hard it pulls after the fuel system is up to snuff
                              "Stay tuned"
                              PUNS
                                Epic! What are you thinking for numbers once you get on the Dyno? 600+?
                                  Thanks guys!
                                  Yeah, hoping for 650whp. Anything more than that and I'll be very happy!
                                    That already seems like too much. I hope you pull a wheelie and get video of it. 😁
                                      No wheelies will be had 😆 but thanks!
                                        Boooooo. Well I rather see burnout videos anyways.
                                        • i_love_carsI
                                          i_love_carsI
                                          i_love_cars
                                          hustle, son. I'd be taking vacation days and just driving around nonstop to finish breaking that clutch in.
                                          I'm going to find a good coffee shop in Appleton to do a workday at once you have everything sorted so I can see this thing with the new turbskeez.
                                          2007 Z4MR
                                          2003 E39 M5
                                          2002 E46 M3
                                          2021 X5 40i
