    I think his plan is to see if he can slow down the rotation of the earth.
      Lol 😆
      No progress yet. Still waiting on the last two batches of parts to come in. Trying to have it back on the road by July.
        Stock vs. not stock.
          Probably a bit of a heavy assembly. Is it a difficult to reach area for install? I had enough fun with my M20 stuff and there was a lot of room
          • i_love_carsI
            i_love_carsI
            i_love_cars
            It's best not to think about it. Even with the subframe dropped there isn't much room to work with in the N5x turbo-side of the engine bay. The problem is only amplified by having a larger turbo housing.
            Shop time calls for roughly 11.5 hours +/- to replace/swap turbos on these cars.
            2007 Z4MR
            2003 E39 M5
            2002 E46 M3
            2021 X5 40i
              Bringing this over to the next page, just because.
              As Jordan said, this job sucks. I wish I could say that I already got my stock turbos removed, but the ones in the picture above are from my friends N54.
                Top mount makes install so much easier. Bottom mount + no lift = workout
                  Finally cleaned the white car this weekend and filled in some small paint chips.
                    Update on the 135i:
                    I had a BMW technician friend do some work to the car. I didn't want to deal with dropping the transmission while laying on my back on the floor of my garage. I just wanted to concentrate on the turbo install, so he did the following:
                    • Replaced upgraded clutch with an even more upgraded clutch (Spec Stage 3+, kept my MFactory SMFW in there)
                    • New bellhousing bolts, throwout bearing and clutch fork
                    • Replaced transmission mounts with poly upgraded mounts
                    • Replaced shifter bushings with upgraded parts
                    • Replaced rear pinion seal and flush/fill the differential
                    I picked up the car and expected the clutch to be a pain to drive. Surprisingly it isn't much worse than the OEM 335is/550i clutch. Definitely daily driveable! The shifter feels tighter and notchier, I'm very happy. I put about 30 miles on the clutch and brought the car home to get started on the turbo install. I put the car in the air and took off the front bumper right away.
                    I don't have the most tools in the world, but I managed to get the subframe and steering rack out in about 4 hours. Another 2 hours and I had the fan, engine mount, downpipes, intercooler, inlets, outlets, water pump, and coolant lines out of the car.
                    I felt pretty accomplished after all of this. I discovered what coolant tastes like and was covered in grime, but knew I was making good progress. I decided to call it a night and clean up the garage so I could get a fresh start after work tonight again. Next step is to remove the oil pan and replace that gasket, and then remove the stock turbos.
                      Nice work=) Have you don't any suspension upgrades or a refresh on this yet? I can't imagine how original bushings would feel with all of this power
                        Nope, all stock. It's lowered on springs, but that's the only "upgrade". I plan to do rear subframe inserts soon because people say really good things about them. A full suspension overhaul is definitely something I want to do, but probably won't happen for another year or two.
                          Were the bushings ever done before you? I can't see them being in all that good of shape now if not
                            Green coolant tastes rather nice.
                            Those pictures scare me, but my ideal car would have 6 feet of clearance on every side of every fastener.
                            Nice work digging in there!
                              Any plans for an LSD?
                                Not that I'm aware of. I'm sure the car could definitely use a refresh...
                                Sadly, this was the blue stuff. Doesn't taste nearly as good, but thanks!
                                Eventually, yes. I'm sure it will need one. Probably a winter project - I'm tapped for funds right now.
                                  I'm really surprised the one series don't have a factory LSD besides the 1M? Is it available as a factory option at least?
                                    It really needs one, even in stock form. But they had to do something to set the 1M apart since it has the same motor 😒
                                    I'm not sure if it's a factory option, I doubt it because I've never seen anyone post about having one.
                                      Made a little more progress last night. Got the turbos out and all oil/coolant lines off. Unbolting the manifolds was the easy part. Removing the coolant and oil lines from the block and from the turbos was a painful, tedious process since I planned on re-using the lines.
                                      I started to remove the PS pump/pulley so I could remove the oil pan, but didn't have a large enough torx bit to loosen the tension on the belt. I'll grab one today and get back after it tonight. I'd like to drop the oil pan and clean everything up while replacing the gasket. Then I'll do the oil filter housing gaskets and start putting things back together!
                                      • i_love_carsI
                                        i_love_carsI
                                        i_love_cars
                                        Never re-use those oil and coolant lines. They are cheap shitty rubber. Replace all of them, especially at your high mileage, and especially while you still have the turbos out and hopefully haven't re-installed everything yet.
                                        Once you have the car back together, in case you do not know the proper priming process for turbo replacements on N5x cars: (Assuming you have relieved fuel pressure and disconnected the fuel pump fuse and ran the car until it died prior to starting this project like you should have) - crank the engine (push the start/stop button) 7 times for 7 seconds each time to prime the turbo with oil. Reconnect the fuel pump fuse. Then run the car for 2 minutes at idle, giving it no revs at all, then shut it off and let it cool. Once cool, start again for 15 minutes, again at idle with no revs. Shut it off and let it cool. Once cool, do a final run at 30 minutes, at idle, no revs.
                                        2007 Z4MR
                                        2003 E39 M5
                                        2002 E46 M3
                                        2021 X5 40i
                                          Once you have the car back together, in case you do not know the proper priming process for turbo replacements on N5x cars: (Assuming you have relieved fuel pressure and disconnected the fuel pump fuse and ran the car until it died prior to starting this project like you should have) - crank the engine (push the start/stop button) 7 times for 7 seconds each time to prime the turbo with oil. Reconnect the fuel pump fuse. Then run the car at WOT for 20 minutes before hopping on the highway and challenging everyone to a 60 roll.
