1.8k Posts 58 Posters 19.2k Views 5 Watching
    225/45r17. On Borbet wheels, I don't know specs on them, they were on the car when I got it.
    Do those have spacers or is the offset that aggressive? I don't know how someone managed to shape your rear arches like that. My coupe has 17x11's in the back with 245/40's and probably rubs less than what you have lol.
      No spacers. there is a bunch of Bondo on the top of the arch.  The arches look terrible, it is pulled out but they didn't remove the seam sealer and flatten the edge.
      I don't stance much, not sure if I can take it much longer.  Do people take the bumper off and move the mounts wider so it holds the bumper wider?  It doesn't rub the metal arch, just the inside of the bumper.  It is creating it's own clearance lol.
      I will see what the wheel specs are this weekend.
        I don't think people usually run a meaty tire that touches the bumper when lowered. Mine are nowhere near the bumper on either of my cars lol. On my coupe, the seam sealer was removed and then the quarters were just rolled .I don't really have a pull or anything. I wouldn't even really say that car is "stanced". I see no tire stretch and it isn't even all that low (I don't see much of any tire tuck). I also see next to no camber. It just looks like someone put too large of tires on wheels with too low of offset. Being cut stock springs they have to be pretty soft and not help much either.
          Yeah you must have some low offset, I'm rocking 255 in the back and moving up to 265.
            I found a set of latches in decent shape and cleaned them up as best as I could.
            Now I can finish assembling the drivers side door. The passenger side needs to be resprayed so it will probably stay apart this far.
              A++++ restoration job would click thread again!
                God damn I never thought I'd get excited over a door latch. Great work Earl!
                  Recleaned the door one last time
                  Played with some butyl tape
                  and voila
                    Wow, that looks so nice.  My cars are all so old that everything like that has disappeared.
                      The ones originally in the car were pretty worse for wear from someone changing the window regulators. I got super lucky having one of the few compacts without self tapping screws being drove through the door panel to hold it on haha
                        " one last time "
                          I removed the clips from my old inner window seal and installed them on the new one as they are NLA
                          Installed the door card next. Really happy with how it came together. I just need to find my mirror switch and order new mirror covers.
                          I also got a blower motor cover and removed the insulation. I will be smoothing it out and modifying it a bit as well.
                            Finally had my new bumper trim so I threw it on to get an idea of how the rear will look when "finished"
                              Yuss!
                                That looks good.  It changes the whole look to have the exhaust cutout eliminated.
                                  "finished"
                                  LOL.......
                                  Butt man, that looks great!!!
                                    Test fit my new carpets. I should be able to start on the false floor frame shortly
                                      What goes in that cubby space, a wheelbarrow tire?
                                        That is where the compact tool kit usually goes. The donut spare is usually mounted to the underside of the car.
                                          Like a pickup. Weird.
