    Bassboy3313 said:
    imo, I would narrow it down to the same width as the roof. Looks great tho.
    Yeah, Thats what I am thinking too, and it seems like the mass majority agrees. Ughh more welding 😐
    Can I ride on that rack whilst you do donuts?
    Hell yeah you can. We will have to strap a couch up there first though so you have a place to sit. With a newspaper and cup of tea in hand, you will be the perfect candidate. 😁
      I would be 100% down for that haha
        So... I broke something. I have yet to take it apart and inspect what it might have been, but y guess is that its a lifter or a bent pushrod. Luckily I have an extra set of GT40P heads, so if the carnage is really awesome, I have parts to fix it. Till my E30 is on the road, this car isnt going to move for awhile.
        *note to self, let the car warm up longer before beating the piss tits out of it. 😕
        IMG_2428.mov
        • IMG_2428.mov
          At least it did a burnout.  Silly Ford engine couldn't handle it.
            Did multiple burnouts, donuts, etc. Someone brings a camera out, damn thing gets shy and breaks. 😒
              I have such a NASCAR feeling right now. Bravo!
                Nascar in 1994 right after the apocalypse?  Also should I remove said muffler because there are no noise regulations in the future? I was thinking right out the center once I build the diffuser. I have a lead on some nice aluminum for pennies on the dollar.....
                kinda like so:
                Image result for Center exit exhaust diffuser BMW
                  The blur of white lettering on tires with a V8 soundtrack is what Daytona victory laps are made of
                    Every time I hear the word FORD I imagine its pronounced like Bobby Hacker does: "FOERD"
                    ( FYI NOT WORK APPROPRIATE)     http://www.funnyordie.com/videos/5468/cars-from-bobby-hacker
                      Well carnage is assumed to take place above the drivers side head with in the confines of a valve cover. I looked at parts pricing today anticipating the worst only to find that a whole gasket set is a mere $14 and lifters, push-rods, and all that jazz can be had for the cost of misc pocket change found on the floorboards. I will probably tear into this thing sooner than I should, but I really feel like it will be a simple fix.
                      With that said, I anticipate working really late on all of my projects tonight in hopes to have some type of progress in a drive-able form by this weekend.
                          Opened the hood this weekend, then shut it. ughhh. 😦
                            Well... for starters I didn't take any more pictures, but trust me I will.
                            I did however pull the intake manifold and all of the components attached to it. I then proceeded to pull the valve cover off and look for some carnage. No broken parts was a very good sign, but then it was obvious; all the rockers and push-rods were nice and snug except for lucky cylinder #7. There is a about a good 1/2" of play in the rocker so I removed that as well as the push rod. From here I assumed that I collapsed the lifter or flattened the cam but no parts stores sell a lifter tool anymore.
                            With that I decided to make my own tool only to fail finding out that the lifter may have mushroomed on the back side preventing it from coming out. SO.. now I have 1 of 2 options.
                            1. I can remove the heads and access the lifters that way. This would obviously mean that I need to basically take 60% of the motor apart BUT also install the GT40 heads I have sitting here for more power. This does also mean I will have to get the GT40 heads machined and the car will be down for awhile.
                            OR.......
                                  2. I can remove the radiator and all of the accessories to get access to the cam. Then I can pull the cam out, and drop each lift into the cam valley one at a time. This might be           the faster easier route, but the amount of sludge and dirty oil I have found so far means leaving the motor as is, is also risky business.  Good thing I can get a whole new               motor on C-list for $200.
                            So what do I do here? Any thoughts from the grandstands?
                            Here is what I assume happened( the arrow is the direction I would need to remove it through the head and am unable to 😞
                              Well since everyone has been so helpful in providing an opinion on what I should do here, I think I am going to tear into the Intake manifold valley and see if I can get the lifter out that way. If I find any evidence of more than just a single lifter, I am buying a hot cam and roller lifters and sending the heads to get machined. Fix all the things!
                                well that's unfordunate.
                                i vote for quick and dirty and get her back on the road.
                                  I can't imagine taking anything apart in that engine and not throwing a cam in it...
                                    ^ this
                                      I see what you did there. And I also agree with quick and dirty.
                                      ^ this
                                      I mean, it is afFORDable
                                        Throw the cam in that FORD, it probably isn't making a lot of power if it is stock.
                                          Just get some upgraded heads they are probably like 20 dollars.
