  4. new to me, 98 M3
new to me, 98 M3
173 Posts 18 Posters 3.3k Views 1 Watching
    Pull the vac line off the FPR and see if it has fuel in it. Easy way to check if it is leaking internally.
    Is it possible that you tee'd into the return line instead of the feed line?
    • C
      C
      cpandrewschmidt
      ok I'll try that today.  Only 1 line coming out of my fuel pump.  The return lines are in a separate spot on my car (rear driver side of the tank)
        It's been a while but I think the pump is on the right. One side has the return line and a sending unit and the other side has the pump and other sending unit. 2 electrical plugs on the pump, just 1 on the sender side.
        • C
          C
          cpandrewschmidt
          yep, i for sure had the pump, i pulled it to inspect it as well to make sure the filter wasnt dirty.
          I just pulled the vacuum line on the FPR and it was dry.  Is there any way to check for leaking injectors?  I think I'm down to that as being the only thing I haven't checked.  Other thing I could think of would be my CCV but that seems OK.  when I googled symptoms of that being bad they said open the oil fill on the valve cover and your car would start sounding like Chewbacca.  Mine checked out fine for that.
          ugh...refuse to take it to a shop
            My only experience with leaking injectors is when the car has a hard-start condition after sitting overnight. The problem injectors revealed themselves by pulling the plugs and watching one or two jets of fuel spray out of one or more cylinders while cranking (the fuel that pooled up being pushed out)
            • C
              C
              cpandrewschmidt
              hmm, yeah i don't have that symptom.
                Contact the company that makes the supercharger kit and see if they have any insite on your issue, see if they will do a retune? Worth a shot
                • C
                  C
                  cpandrewschmidt
                  At idle with my foot off the gas my '99 M3 sits at 17%/18% throttle. Not sure on the rest of the numbers though. When I get back from my trip I can see what my car reads for the rest of the parameters you posted to compare
                  Company that made the Eurosport SC isn't around anymore.  TRM tuning in GA installed it, not sure if they do actual programming to customize the tune or if Eurosport gave them the tune.
                  I'd think it's still something with the car as it was fine for a little while.  Plus it's only showing the out of wack short term fuel trim number on bank 1.  I think I'll swap 1-3 injectors next to see if fuel trims move to bank 2.  At least that's free to try.  If that doesn't show anything I'm stuck.  I suppose professional smoke test next just to be sure, but I'm almost positive I don't have any leaks.
                  • C
                    C
                    cpandrewschmidt
                    small update.  Took car into Crestwood Auto clinic in Madison for diagnostics.  They hooked it up to their machine.  Codes ran a little deeper than I could get with my scanner.
                    227, 228 Mixture Deviation Cylinders, 1-3,3-6
                    202 O2 Bank 1 control limit
                    242, 243 Misfire Cylinder 5,6
                    They said car is actually running fine under OEM bmw specs and wouldn't trip the CEL if it weren't for the SC, injectors, etc.  I kind of suspected that.  They said the tune likely needs to be redone.  I perhaps lost it unplugging the battery?  I've reached out to three tuners around here to see what they think and pricing for a new tune.  Accumoto in Waunakee, Capitol Tuning, Performence Engine in Middleton if anyone has experience with any of them.
                      I would be surprised if any of them can do it.
                      https://sites.google.com/site/openms41/romraider/how-to-get-started-tuning-your-m52-s52-with-romraider
                      here is a helpful link if you want to tune it yourself or have the programs so they can tune it.
                        Haven't personally had work done at Accumoto but know people who have and haven't heard anything bad. Kelly Moss Road and Race in Fitchburg is another one to call too.
                          Does anyone know if you can make live adjustments on OBD2 Motronic? I know for OBD1 and previous versions of Motronic it requires removing the EPROM, plugging it into a chip reader/writer and not being able to do it live.
                          I'd definitely have a shop do a dyno tune if possible, would be well worth the money.
                            Ms41 can be rewritten in the car but not while running, you have to jump some wires on the 20 pin connector to power the ecu.
                            however testo datalogger is extremely good and free (donations excepted)
                            • C
                              C
                              cpandrewschmidt
                              yeah, all that coding stuff is completely foreign to me.
                              One companies response was " There are two steps to this, well three possibly. First I would like to take a look at the car (@1 hour) then if all checks out I would put it on the dyno and see how the tune is. At that point we make decisions and if you have or can get the software I can tune it if needed. "
                              I don't know what software he's talking about.  I thought they did that and that was the whole point of the tune?  Still waiting on the other two companies to respond.
                                Software like Daggerty linked.
                                Romraider, TunerPro, etc. something that can interface with the stock ecu
                                  If things get desperate you can download Testo datalogging software and do some datalogging as well as send me the factory tune file I and I can help you tune it remotely. Hopefully a dyno shop can get you taken care of though
                                  • C
                                    C
                                    cpandrewschmidt
                                    Thanks Snap for that offer, hopefully don't need to take you up on that, but maybe.  Here's an update.
                                    Picked up a fuel pressure guage, if you remember I couldn't get the one from Orileys to work.  Grabbed one at Harbor Freight, hooked it up to the schrader valve at the fuel rail.  Here's my results, im not 100% sure I did this properly.
                                    First, i put ignition on but didn't start the car.  Pressure went up to 42ish psi, and started dropping reasoably quick, down to about 30 psi after 2 or 3 mins with ignition still on.  This is probably a clue for something.  Did this each time with the vacuum line going into the fuel pressure regulator on or off.
                                    Another test, started car this time.  Pressure with vacuum line attached at FPR 41/42 ish. Took vacuum line off it jumps to 51/52 psi.  I believe that is spec for the S52 engine.  I also gave it solid rpm of 2500 and held steady at 41/42 with FPR attached.  When giving quick bursts of gas it did just a quick spike.
                                    I also noticed while FPR was plugged and unplugged with car running it would bog down a bit, so I believe that is working properly.
                                    What has me concerned is i read I should be holding steady pressure with just the ignition on, correct?  It's definitely dropping.  Injectors or something with fuel pump?  Again I'm running a bit rich it appears from my fuel trim numbers.
                                    Thanks again experts!
                                      51 psi is 3.5 BAR which is correct.
                                      The pressure bleeding off with the engine off means either your top injector o-ring leaks, or the injectors themselves leak.
                                      It would be in your best interests to pull the rail and injectors and see which ones are leaking since an injector that bleeds fuel into a cylinder during a high rpm shift or at the rev limiter can cause detonation
                                      Your injectors are firing against 14.7psi of ambient air pressure,
                                      • C
                                        C
                                        cpandrewschmidt
                                        probably a stupid question.  Can I pull the rail with injectors attached and pressurize the system (not start car) to see if any leak?  Not sure if there's a side effect that could harm anything I'm not thinking of.
                                          Yep, that would be the way to go.
                                          You dont need the electrical connectors attached so that gives you a little more flexibility to work with. Put something down to catch any fuel that may leak then just prime the fuel pump by turning the key to "On" You can also jumper the fuel pump relay to let it run continuously. This doesnt hurt anything.
