  4. E39 M5
E39 M5
76 Posts 18 Posters 0 Views 1 Watching
  • TehRaydarloverT
    TehRaydarloverT
    TehRaydarlover
    Pulled the lower oil sump pan and oil pump(s). The two electric oil pumps were a pain in the dick to get out, oil everywhere when the do finally come haha. Found a few broken pieces of plastic in the pan. Along with the wear on the oil pump chain tensioner, I'm glad I trailered it home from Arkansas! Next I need to pull the suspension and drop the subframe to be able to pull the upper sump pan.
      Very cool!  I helped a friend in Norther IL install an evolve supercharger kit on the exact same color combo e39 M5.
      Good luck with the maintenance.
      • TehRaydarloverT
        TehRaydarloverT
        TehRaydarlover
        Nice, I was looking at different kits for the s62. Would be pretty cool to do, maybe if I decide to keep it for longer haha.
        • i_love_carsI
          i_love_carsI
          i_love_cars
          Fuck that is awesome. I have been away from the forums for a few weeks and missed this post. Awesome car. Easily my favorite M5 in terms of holistically pleasing cars - good engine note because #justV8things, nice interior and very aesthetically pleasing. This car has a very classic BMW appeal to it.
          2007 Z4MR
          2003 E39 M5
          2002 E46 M3
          2021 X5 40i
          • TehRaydarloverT
            TehRaydarloverT
            TehRaydarlover
            Small update! The timing chain guides are done, just about to drop the front sub frame to do the rod bearings. It was a pretty scary sight as I pulled the timing chain covers. The plastic cover on the center guide was broken up and completely gone. The chain was riding on the aluminum base of the guide and actually contacting the lower timing cover.  Luckily it doesn't look like it was running like that for very long, probably the majority was me test driving it and pulling it on/off the trailer. All of the guides, tensioners, chains, and seals have now been replaced and the top end is pretty much back together. It should be interesting to see what the old rod bearings look like after 150k. They'll be replaced with WPC treated bearings and new rod bolts, hopefully then I can get this thing back on the road and enjoy it!
            • TehRaydarloverT
              TehRaydarloverT
              TehRaydarlover
              Subframe and upper oil sump came off yesterday ...what a pain in the ass. I got the first 4 rod bearings out last night. When I pulled the first two I was regretting doing this job because they looked perfect for 150k, but after cylinders 2 and 6 I was glad. The top half shells are pretty worn but the crank journal looks great! 😄
              I'm going to pull the remaining 4 today at some point. Also cracked rods are pretty cool, instead of being made out of two pieces the rods are made from one and cracked at the joint giving you an extremely precise fit.
              • TehRaydarloverT
                TehRaydarloverT
                TehRaydarlover
                Old bearings are all out and new WPC treated ones are in 🖒
                Cylinder 8 bearing definitely looks the worst, but minus the first two cylinders they all look pretty worn, very glad I decided to change them.
                  What's left on the to do list after the bottom end is back together?
                  • TehRaydarloverT
                    TehRaydarloverT
                    TehRaydarlover
                    It should be drivable once the bottom end is back together but at some point I also need to replace the rear view mirror, fix the 3rd brake light, replace the shift knob, and try to figure out the sat nav, also maybe bleed the clutch and get some new tires on it. We'll see, I want to put some miles on it haha.
                      Nice progress!  I should hired you to come do my timing guides....at least inspect them.
                      • TehRaydarloverT
                        TehRaydarloverT
                        TehRaydarlover
                        I could probably do it haha. The guides weren't too bad, just time consuming. Dropping the K member to do the rod bearings was a pita.
                        • i_love_carsI
                          i_love_carsI
                          i_love_cars
                          hopefully this will be ready for spring. I would like to see it at a meet
                          2007 Z4MR
                          2003 E39 M5
                          2002 E46 M3
                          2021 X5 40i
                          • BMWbenB
                            BMWbenB
                            BMWben
                            I am late to this thread but how amazingly clean is that car? I got my e34 540 from Texas and I can't believe how clean it is. That state mummifies cars. I'd buy every car I ever own from that state if I could.
                            BMWCCA #499464
                              I'll be dropping the K-member/subframe for some welding and powdercoating anyway.  If interested in the job(s) PM me with what you are thinking.  Car is on a lift in a heated/cooled shed with good lighting.
                              • TehRaydarloverT
                                TehRaydarloverT
                                TehRaydarlover
                                It's been going back together lately, the top end is buttoned up and I got the upper oil pan on tonight. I've got another parts order to make, but it's coming along.
                                It's stupid clean haha, even the exhaust is rust free. It's a nice change of pace from my beater haha. I was hosing it off today with a garden hose after work, and blew a golf ball sized hole threw the passengers door lmao.
                                • TehRaydarloverT
                                  TehRaydarloverT
                                  TehRaydarlover
                                  So here is where all of the little pieces of timing chain guide went... that's pretty f@cking terrifying. Really hoping this screen and the oil filter have done their jobs lol.
                                  • i_love_carsI
                                    i_love_carsI
                                    i_love_cars
                                    holy shit. I don't have a better response for that image lol
                                    2007 Z4MR
                                    2003 E39 M5
                                    2002 E46 M3
                                    2021 X5 40i
                                      Were there any loose bolts on the pump too?
                                      • TehRaydarloverT
                                        TehRaydarloverT
                                        TehRaydarlover
                                        The bolts that hold the pump itself together? Or that hold the pump to the engine? Either way they were all tight.
                                        I think I'll be doing an oil change after the first 50 miles just to try and get any left over pieces out, or at least a filter change.
                                        • damnboy037D
                                          damnboy037D
                                          damnboy037
                                          Nice work, looking forward for more updates.
                                          99 M3 320rwhp @ 6psi
                                          95 M3 s50b32
