  4. 91 318 Nostalgia
91 318 Nostalgia
89 Posts 16 Posters 0 Views 1 Watching
    Now to tackle the blower motor. Only works on 4 and sounds bad, which usually means that one of the covers is hitting the blades.
    If it only works on 4, chances are its the blower motor resistor, as 4 is the only speed that bypasses the resistor.
      Agreed, though due to the noise it makes I need to do further investigation.
        The fan noise could be a couple things: some debris got into the housing, the metal clip holding the motor in place came loose so the motor isn't seated properly, or the plastic fan blades/ hamster cages have partially disintegrated with age.
          I haven't seen the motor clip coming loose before.
          The last one I did the plastic had warped enough that it was sitting against the fan blades. That was a nice easy fix!
          Just transferred the title, and picked up plates for this. Daily duty may start tonight.
            Good deal!
            Not sure if it was a track concrete gator issue or the earlier wall tag, but when I opened up the housing on the track car the metal clip holding the blower motor was still in place but the motor itself had been slightly knocked out of the normal housing seat position and was rotated about 1/4" backwards towards the firewall.
            One more reason to keep yours a daily driver.
              I look forward to replacing the front suspension and tie rods on this. Driving home last night on the highway with wind, grooved road, snow tires, and worn ball joints was quite a bit of work!
              Trying to slide in this in the snow is different. It lacks the power that I prefer, but lift off over-steers quite well. I could certainly do without the beehive power plant!
              It's been doing me well though, and is certainly more enjoyable (even in mediocre condition) to drive than the Mazda!
                Where did the e46 ever go? lol
                And I really wonder how a lot of guys in the UK slide compacts with m42's and have zero issues doing it lol. I wonder if the e36 m42 has that much more torque to make the difference...I doubt it but it just amazes me
                  Crappy tires, lots of handbrake/clutch kicks, and a gas pedal that might as well be welded to the floor haha
                    proper weight distribution and driving the car near the limit. no e-brake or clutch-kicks required.
                      I got rid of that this past spring, it was starting to be a lot more headache than it was worth. I picked up a 2010 Mazda 3s Hatch 6 spd on kind of a whim so I could transport bikes and gear for summer.
                        I guess this is part of my problem, I think the car is kind of loud to be flying around neighborhoods past 4k RPM due to the beehive that is clearly angry under the hood.
                        I will say that the power level isn't quite as disappointing as I remember.
                          Get some awesome rubber and go faster
                            Got to work on cars this weekend! It has been far too long since that happened!
                            Got the lowering springs in (thanks Mitch!)
                            Also put in new tie rods (inner and outer with new boots), sway bar end links as the old ones were destroyed, and new strut tops.
                            The PO had told me it leaked oil because the drain plug was stripped out and he just used silicon to seal it, and it leaked. I grabbed a new lower pan and found that someone decided to use whatever shit they had laying around for the rear bolts that hold the lower pan to the upper. This includes, but was not limited to, giant machine screws, what appeared to be some sort of massive wood screw, screws with flats ground in them to cut threads, and various other sized hardware. Someone also punched through the upper pan with a drill when making these new "threads" so I JB Welded that shut.
                            Next steps are to do some interior work and get some fog lights, a front lip, and put the brake ducts back in.
                            I'm also trying to source some ellipsoids.
                              The effort some people put into doing things wrong amazes me 😂
                                On that note...
                                Last night I checked the fuses for the high beams as they weren't functioning. One was blown so I replaced it. While I was looking at the fuses I saw way too many 20 and 30 amp fuses. I grabbed the Bentley to check the proper values and found that the majority of fuses had been replaced with 20 or 30 amp fuses.
                                Why are people so dumb?!
                                I also got the interior lights working again which is a nice touch!
                                • i_love_carsI
                                  i_love_carsI
                                  i_love_cars
                                  for fuck's sake the things that people do that they think are good ideas is astonishing. How could someone not be troubled to just simply order proper new hardware? This car was headed for an early grave if it hadn't been saved by you
                                  2007 Z4MR
                                  2003 E39 M5
                                  2002 E46 M3
                                  2021 X5 40i
                                    Wow. Such much Dumb.
                                    Welcome to the club though, My e36 has a block of wood screwed to the firewall to mount a gas pedal that is certainly not BMW material among 20 other things I can mention right off the top of my head.
                                    SMH some should just not reproduce.
                                      I may need to shift some assets around soon and unfortunately this car is the first one that would need to go.
                                      With that said I may be looking to sell this car soon, and if anyone is interested or knows anyone that may be interested please let me know.
                                      Thanks.
                                        Car has been sold. Guy dove up 3 hours after a 5 min conversation on the phone Sunday, and left with it.
                                        I ended up making out quite well on it and seeing it go was bittersweet.
                                        4 cars was too many, and having fixed that was nice!
                                          fare thee well, e30!
