  4. Lifted E30 V2
Lifted E30 V2
670 Posts 25 Posters 1 Views 1 Watching
    Reference for later
      To rule out another simple thing, temp gun just to make sure the gauge reading of overheating is in fact correct. Gun is cheap, under $20 at HF.
      You're still using the stock temp gauge? That was my issue when I was chasing an overheating problem on the m42. Pulled the cluster and tightened the nut on the back of the gauge. No more "overheating". If you tap the temp gauge when it reads high does it jump/move? Another symptom of the loose nut.
        Get a temp gun dude
          I would get a temp gun or an aftermarket temp gauge and see what your readings are.
          I am also going to back up Boris mentioning checking the OEM gauge.
          Also, not to say you are an idiot, as I have done the same thing before😴, but are you sure the T-stat is facing the right direction?
            guys, he tried without the t-stat and had the same problem. its not the t-stat.
              I've kept my cool (pun intended) but mentally am getting annoyed at that question.
              Thank you for being the one to point it out lol.
              Car is back in from its time out, and will be looked at tonight.
              Yes, I do have the thermostat in the correct orientation.
                Hey Ben.
                Do you have a temp gun
                  i think you need a post along the lines of
                    and then when it turns out it's actually in backwards...
                      So did you look at it? I am sorry for bringing out the T-stat again. I am back to voting for a blocked coolant passage somewheres.
                        Ha, I don't get offended by that kind of stuff. Sometimes it's simple stuff like that.
                        Didn't really do much other than pull the hood off and steal the washer fluid pump.
                          Did you buy a temp gun yet
                          • andyhundleyA
                            andyhundleyA
                            andyhundley
                                      Hey guys.
                                      Guess what I bought.
                                        Hey Ben. I have a temp gun you can borrow
                                          Singing Elsa doll from Frozen
