  4. chit chat thread
chit chat thread
    I was totally being sarcastic about buying new, you crazy person
      what toe and camber settings do you run?
      Can you guess which control arm probably got bent from the last good bump I hit?
      • andyhundleyA
        andyhundleyA
        andyhundley
        I wish my rear specs looked that good on my e30. My right rear trailing arm is pretty far out of spec. I am hoping a bushing replacement will do the trick. Also how fast do you guys go through rear tires? I am only able to get a 1.2 summer seasons out of my rears running Yokohama S- Drives.
          i like rake, so my e30s were not very low in the back, so I never had strange wear in the back, even with old bushings.
            I have never driven it long enough to go through a set of tires lol.
            My 300 tread wear BFG's still look new and that is the set I had on there the longest.ย
            Sounds like you may have something going on back there.ย
            I'm a bit concerned that my subframe riser bushings will take out too much camber, so here's to hoping that doesn't happen!
            • andyhundleyA
              andyhundleyA
              andyhundley
              My bushings are mush anyways so we'll see in spring if it resolves anything.
                I have 500/600 miles, and an autox on my re71r. And a broken axle.
                Before that I had some neo nittogens that wouldn't die for 4 years
                  Like space? Download Space Engine
                  http://en.spaceengine.org/
                    โ€‹
                        Crank, but no start. No spark. No fuel. This e34 is the least reliable vehicle I have ever owned.
                        I blame Earl. ๐Ÿ˜†๐Ÿ˜
                          Crank position sensor or main relay
                            Tried jumping the relay. Crank sensor already ordered.
                              It literally never left me stranded besides a dead battery lol
                              • JeffJ
                                JeffJ
                                Jeff
                                I blame Earl. :lol::angry:
                                Earl should give you free rides until he fixes it.
                                1976 530i e12
                                1990 325ix e30
                                1992 325i e36
                                1995 740il e38
                                2001 330xi e46
                                ^More to come :)
                                    lol
                                      Only 6 stitches, still annoying. Nail stopped the knife fortunately. 3 hours at the clinic because it wouldn't stop bleeding long enough to get it sewn up. This just means I don't have to work on the Miata for a week or so, silver linings I guess.
                                        Anyone else feel spring approaching rather quickly?ย Applying sealant to my new wheels for my X3. Hopefully this helps to keep them looking nice. Can't wait to get these and the H&R springs on.
                                          those are amazing. what do you seal them with?
                                          With your input, this post could be even better ๐Ÿ’—
