  4. chit chat thread
chit chat thread
    They can't be that much noticeably stiffer than a solid delrin bushing. I just don't see the value other than the longtube debate.
      what toe and camber settings do you run?
      I'll check my sheet tonight.
        -2.5 camber
        0* toe
        ^is what I run currently
          Anyone ever have door glass that has a heavy cloudy build up of dirt where the glass meets the window seals? My new passenger window for the compact has this and I am trying to figure out the best way to remove it as soap and water didn't do the trick
            Regular green Scotch Brite would probably take it off, and won't damage the glass.  I've used it on glass before for super stubborn dried on bug splats because I don't wash often enough.
              Like the green scouring pad on kitchen sponges or the industrial stuff?
              3m2288CountScotch-BriteHeavyDutyS
                Also happened across this DIY and laughed at the first few pics
                http://www.bimmerboard.com/members/calypso750/chromeline.htm
                  Use 0000 steel wool. It'll easily remove that grime without scratching the glass.
                    I will grab some after work=) Do I remove it in straight or circular motions, or does it not matter?
                      Doesn't matter.
                        Is it on the surface or is it actually in between sheets of the glass?  You could try a product called Bar Keepers Friend.  I've used it on the glass top of my stove and house windows and it works miracles!
                          I would hope it is on the surface=( I will give that a try too if the steel wool doesn't work
                            I'd try Bar Keepers Friend before an abrasive like steel wool!
                              Both of those options sound super risky. Just buy new stuff from the dealer
                                For what I got charged for this used one I should have bought a new pane. A new window is only $156. The guy was supposed to send me bumper shocks and the window for $120 but then he threw away the shocks and sent me the window saying, "Shipping was a lot more than I figured and the studs on the bumper shocks had more rust than you wanted."
                                I just watched a guy clean windows with the steel wool like TJ suggested and it was phenomenal😎
                                  #0000 grade steel wool won't scratch the glass, it will clean the dirt out of scratches though sometimes making them more visible. Also this dosent work with tint or rear window heaters on the inside as it will scratch.
                                    Yea, I didn't see any of the posts ahead of me before I posted that...
                                      I was totally being sarcastic about buying new, you crazy person
                                        Can you guess which control arm probably got bent from the last good bump I hit?
                                        • andyhundleyA
                                          andyhundleyA
                                          andyhundley
                                          I wish my rear specs looked that good on my e30. My right rear trailing arm is pretty far out of spec. I am hoping a bushing replacement will do the trick. Also how fast do you guys go through rear tires? I am only able to get a 1.2 summer seasons out of my rears running Yokohama S- Drives.
