Lifted E30 V2
Did some digging last night.
I was impressed by the amount of time that isn't required to pull a head on one of these things. This is clearly due to not needing to pull the cam and various timing components. It took 45 minutes from start to finish to get the head off with the help of a friend, neither of us having done it before.I was very surprised to see how clean the pistons were, and that though the cylinder walls are pretty smooth you can still see some crosshatching. This thing has around 250k miles, so that's always amusing. It also looks like someone had a little valve to piston contact at some point in its life.
I don't see any super obvious signs of HG failure, but all of the symptoms are there.
Misfiring (cold and hot lol)
Long crank times
Touch of white smoke
OverheatingPictures of stuff. White exhaust valves and all. (probably due to my lack of exhaust most of its life)
The really dark part of the HG between the pistons is odd, and something that I have not seen before.
I'm torn between swapping head gaskets or replacing the motor with on of Mr. Young's spares.
If you don't see any cracks and it is all pretty level I would say just throw a head gasket in and see if it fixes your issues. Not much else internally besides your water pump scenario would make sense. Plus you save the time of swapping the motor again and who knows how the inside of the other motor looks. This way you have peace of mind on that
My guess would be that dark portion could be carbon deposits from a bad gasket? In the past I have seen cylinders connect before and cause all kinds of weird issues, and normally there is a path of discoloration between the two.
If I was you, I would check the head and make sure its square, and just toss a new gasket on it VS swapping the motor.
Also where do you see the valve and piston contact, would it be possible you have a bent valve? I would check into that as well.
PS- We are all still waiting to see rear flares.
I pulled the water pump and it was A-Okay.
I will closely inspect the exhaust to coolant passage area on the head to ensure there are no cracks.
I think I will end up ordering stuff to do the HG as it will cost a bit less than replacing the motor, and be less work. If that doesn't fix it then I shall take more drastic routes.
I will be taking the head in to have it decked / checked as I am assuming it is no longer straight.
I should start on that soon.
But then I come up with other really bad ideas and want to try those first
Dropped the head off at the machine shop last night. Guy pulled the plugs (I forgot to) and looked at them and said, oh yeah, this head gasket has been bad for quite awhile. I never mentioned the head gasket being bad.
This amuses me. -
Head gasket and head bolts have been received.
Waiting on the head to come back from the machine shop and then it's reassembly time.I'm still hoping to ice race this weekend if the event isn't cancelled.
$60
That sounds like a great deal=) Wasn't the place you used for your exhaust manifold was it?
Hahaha, nope! I won't set foot in that place again.
It's a local guy that has always done my motor work, and does it at a good cost and his work is always great. -
Shiny head!
I got it all assembled and it still overheated, so either I'm bad at bleeding m20 cooling systems or something is wonky.
I took the thermostat out and it still started creeping past 1/2 at idle, so I replaced the clutch fan. Shall test all of that tonight.This car resulted in this picture, it makes dealing with constant issues easier.
PBR? Did Andy buy something from you?
lol, nope! That's Mikes beer of choice.
pbr is pretty good for cheap light beer. better than lite or bud or other terrible domestic light beers.
on topic - i'm sure you know how to bleed one of these cars, but what process are you going through exactly?
i just bled my e30 before winter and it took probably 4 cycles of: start car - warms up - massage radiator hoses - starts to creep past 1/2 - shut it off - let it cool - open the cap - more coolant - repeat.
