  4. 91 318 Nostalgia
91 318 Nostalgia
seriously anoth
89 Posts 16 Posters 1.6k Views 1 Watching
    $1,300 for an s52 with a lot of mileage and a rod knock?!
      Nice find. That sounds way more exciting to drive than the mazda.
      • i_love_carsI
        i_love_carsI
        i_love_cars
        sounds like it was a legit deal. I saw the listing and secretly wished I was in the market for a streetable E30 as the history and price seemed pretty good
        2007 Z4MR
        2003 E39 M5
        2002 E46 M3
        2021 X5 40i
          Buy more bmws
            I brought this home on Saturday. List of things I have done so far.
            Took part of the tan sport seat apart to find out what's broken.
            Tried to take out the rear bumper bolts (one came out...)
            Yup
              Stiiiilll haven't touched this.
              I did notice that the PO put a "new" radiator and bleed screw in it. The radiator appears to have been from a car with some cooling system issues. The expansion tank is bulged out quite far, even with the cap off.
              His "new bleed screw" was some sort of torx head fastener from some interior area. No wonder it is sucking air into the cooling system.
              Some people I tell ya
                It's amazing what people will do to "save" on a sub two dollar part.
                  I finally started digging into the mechanical side of this thing since buying it. I had been working on getting things painted and just cleaned up in general on it.
                  Did all trim in black, replaced rear bumper trim, painted the mirrors and grills black, fixed the drivers seat so I could have one interior color, and other things like that.
                  First thing I did was evacuate the transmission of it's far too thick oil. The car didn't like shifting and I can tell why, someone used the same oil for the diff as the trans.
                  I put the car up in the air to get started underneath it and found some stuff. The underside of this thing is staggeringly clean, and the worst areas actually show in the pictures below, which is primarily just a bit of surface rust.
                  Someone must have decided steering couplings were dumb.
                  The amount of road grime underneath this thing is amazing. I will probably drop 20lbs just by scraping it all off!
                  IMG20170107161412218IMG20170107161205848
                  Do these motor mounts look collapsed? Drivers side looks collapsed for sure.
                  Someone decided to just cut the reverse switch wires and leave them dangle instead of doing anything else with them...
                  The subframe and rear trailing arm bushings are clearly in need of replacement.
                  The most peculiar one of them all. I wanted to check the diff to see if it was an LSD or open, and had the rear of the car in the air. I spun one wheel forward and watched to see what the other side did. It did nothing. I went to the other side and spun it and I got the same result. So either this thing has a broken open diff (seems odd) or an EXTREMELY worn out LSD. More digging on that later!
                    Put it in gear so the driveshaft doesn't spin, then spin a wheel.  Either a wheel and the driveshaft turns or if the driveshaft is held both wheels will spin.
                      I've never needed to do that before, and if you have a diff on the workbench it will still spin all inputs/outputs without any being held.
                      I will for curiosity though.
                        It always seems like a good weekend of fixing all the little stuff is the most rewarding. Those motor mounts are certainly shot, how are the trans mounts?
                          well its an open now, in either scenario.
                          i am also curious as to why...i found that scenario all over the internet, but no one seems to have an answer for whats going on.
                            The driveshaft apparently has less static friction than the opposing wheel, despite being geared up... My guess would be that the brakes (or parking brake) is dragging slightly. CV joints full of mud/tar? Can't really think of any other logical reasons... CV joint joint friction might make sense, since the suspension is at full droop, whereas the driveshaft is in a straight(ish) line.
                              Yea it just depends where there is more friction.  While we are on the discussion of differentials, I have an open and an LSD for my e36, the open spins very easily but the LSD is much stiffer to turn.  Is this an indicator that something is wrong or is that just how and LSD is?  I have never had one before.  I haven't used it in my car yet but it came from a crashed m3 with low miles so I assumed it was ok.
                                The fluids could be different viscosities.
                                  The 4.10 LSD I have for my e30 is also very stiff to turn by hand, I figured that was normal since it spins smoothly, haven't had the back cover off yet to inspect. No idea on mileage and condition though as I got it with my M3 suspension.
                                    Good to know.  They are much more different in resistance to turning than fluid would cause.  More like 2 hands to turn the input shaft on the LSD while the open turns easily with one hand.
                                      There are so many variables that could cause different feel and resistance. Most clutch types will have wear in the clutches and or different fluid viscosity that two of the exact same 4.10's could feel completely different.
                                        The e28 LSD I will be throwing in the e21 has a somewhat notchy feel to it when turning by hand with no fluid in it. Not sure what that's about.
                                          While we are playing head gasket games across all 3 of my e30's we may as well check this one.
                                          I think it's leaking, as there is air entering the system from somewhere and the car slowly overheats at idle, and won't stay at 1/2 temp ever.
                                           Going to do the coolant gas test tonight and confirm or deny it.
                                          Yay
