  4. 1999 M3 daily driver running log
264 Posts 28 Posters 5.0k Views 4 Watching
    The factory specs on the e36 rear are horrible.  You'll get a lot of premature tire wear on the stock alignment with it.  It may not be the RTAB's.
    That is definitely possible... I recall my last e36 wearing the rears much faster than the fronts, I just didn't remember it being this fast. It does feel a little loose in the rear around turns so I guess changing them wouldn't hurt either way
      are the rear tires worn evenly, or on the inner edges?
      worn evenly = just you having too much fun.
      Worn evenly, I guess I'm just having too much fun haha. I don't really drive aggressively, it's mostly highway miles so I was surprised I'm burning through them as quickly as I am.
        my dad always complained about his e36 m3 eating rear tires and he drove like a grandpa. don't think that car ever saw much more than 4k rpms with him at the helm.
          From my understanding the combo of toe in and negative camber causes quick wear but zero toe and some negative camber will help the tires last better.  You may have to tell an alignment shop how to make the rear adjustments because most would probably assume there are no adjustments.  Eccentric bolt in the BBQ tong lower control arm for camber and the RTAB mount has slotted holes for toe adjustment.
            122.5k:  Replaced my door handle gaskets with a set from "shogun" over on Bimmerforums. They fit perfectly and are a really great deal compared to buying new gaskets and trim pieces from BMW.
            Old:
            New:
              Thanks for the tip! I'll have to grab some of those for the e34's.
                Had to make a stop at the hardware store for some new wiper blades halfway home from work on Friday, couldn't see a damn thing. The cracked windshield really rips apart wipers. Anyone have any good recommendations for a windshield replacement? It's about time I did that...
                Also, went cruising around in the storm for a solid 2.5 hours last night, this car is unbelievably fun in the snow. Got some pictures last night too, really like these two:
                  Great shots!
                    I'd recommend Glass Pro for the windshield. They've done a couple of my personal cars and probably over a hundred for me at work. Great guys and prices are really good. Also, they won't put shitty Chinese glass in your car. I'd expect it to be right around $200.
                      Not Novus glass if they have one nearby, the Platteville location removed my cracked window from my truck by kicking it out from the inside and vacuuming up the glass... I could have done that...
                        I'm surprised they can do that legally lol. Imagine if they kicked the dash that hard
                          Right, and then they told me about it...  I guess they don't know how to replace an old school window that has a rubber gasket instead of glue.
                            wow cool pictures, I wish I would have thought to go down to 3rd ward. next snow hit me up and we'll do some syncro tokyo drifto or at least get some video of shenanigans
                              Thanks! And that sounds like a great idea, it should definitely happen
                                Gave Glass Pro a call, got a quote for $250 installed which is pretty good compared to other places I called, seemed like a nice guy on the phone too. I'll be making an appointment after the holidays to get this thing sorted. Thanks for the recommendation!
                                  Thats cheap! I should inquire about the e21 to get rid of the wiper arm scratch across it from the doofus PO.
                                    Completed my tool kit! It was missing almost everything when I bought the car...
                                      124.5k: Oil change with 5w40 synthetic, a few more metal particles on the drain plug than the last two changes but I stretched (aka neglected) my normal interval from 3k to 5k miles, so I'm not too worried about it.
                                      Went to Pegasus over the weekend with Dan, that place is awesome. Got a proper helmet and I think that is all I need to start getting this car and my e30 out to some events. Hopefully the ice rally-x is rescheduled to a weekend that works! I was pretty concerned about how I would fit in the car with a helmet on, but I can actually make it work while still being fairly comfortable which was a nice surprise.
                                        I once saw a helmet sticking up through an open sunroof at an autocross.
                                          Got a deal on some clear tails, liking how it looks! Eventually I'll get some clear side markers and front signals
