    I forgot it was a rear you had done=P
      I have had front control arms powder coated and they used some special greenish clear tape to mask the ID where the ball joint presses in.
        Hang some plastic sheeting to seal it and crank a propane heater. No excuses.
          That was what I was thinking=)
            Ive done the plastic wrap for heating a garage before and it works really well. I used a convection propane heater that looks like this and it was way better than a torpedo:
            Image result for propane convection heater
              The hot chode?!? Oh I see, its chaud, gotcha!
                Either way, I bet they are both hot and salty if you lick them.
                  I think you mean calienté my spicy amigo
                  Donde esta el CHODE
                    in Far Cry 4, the game devs programmed enemies and civilians to use 'chode' quite often, its pretty hilariously.
                      Lol "mother chode"
                        Still chugging along slowly but surely.
                        This afternoon I will be dropping my brake line fittings off for plating so I should be able to get the front brake setup all done shortly after I get them back.
                        In other news I picked up a part I have been wanting for quite some time.
                        I apologize for the potato quality lighting (and for not replacing my damaged HVAC panel before showing this haha)
                        In an effort to make things as simple and clean as possible (most aesthetically) I removed the head unit in favor of controlling the speaker system in a different way. More on that once I actually start the wiring.
                        Speaking of wiring, can someone help me find the amp wiring diagram for a premium sound compact? It looks like all other e36's use a similar but slightly different amp.
                          @Earl that's a 10 speaker system right?
                            Yup=)   (tweeter and speaker in each door, speaker in each foot well, and then two small speakers with two larger ones in the back)
                              I have a wiring diagram I just need to figure out how to get it from it's secured form to something I can send you that's readable.
                                That's awesome! Thank you Pat
                                Also, screw purchasing from Panjo. I bought a set of brand new oem grilles that a guy had sitting and he hasn't responded to anything since I bought them over a week ago. I also emailed Panjo to get a hold of him and they haven't even responded to me. Such a joke
                                  Damn it @Earl, respond to my text.
                                    I was in a meeting haha. My apologies
                                      Fiddled with a few things on Saturday. Not much to post pictures of as I was mocking up my actuator for my push button hatch release system and some other small things.
                                      Some comparisons between old and new
                                        When this thing is done you will have touched every single individual part on this car.
                                          It seems that way. I will have to read back through and see what I didn't touch so I can go loosen up those bolts and retighten them lol
