    Well you're welcome=P
      Turns out the wire harness and pin outs for the window regulators is different. Anyone have some info on this? I think its pretty straight forward as I can see the larger gauge wire in either ends of the harness that power the regulators isn't aligned. But I hope all the switches for the one touch operation is the same. Ughhh why, just why, would BMW switch this from different models / years?
      Just found the answer to my own question, man google is such an awesome guy. Turns out there is different switches for one touch, heated mirrors, and speaker options. great.
      In other more exciting news, I was able to pick up a Corbeau Forza for $30! Now I just have to find / make brackets.
        I have some VAC floor mounts that I could lend you if you'd like to attempt to copy them.
          I need to find a seat that cheap to make an office desk chair out of
            That might be very helpful. I already cut the brackets from the old seat as a template. I'm not sure if I plan on welding something, or just machining it out of aluminum and adding it to the list of other items I need to mill out.
            Yes! I have wanted to do that for a long time. I had a set of RSX seats that I was going to use, but they proved to be more work than it was worth. there are a ton of cheap reclinable ones on craigslist quite often though.
              Using this as a mental note*
              Things to build in SolidWorks to machine out of aluminum:
              • -Shifter
              • -Hydro brake lever
              • -Power steering bracket
              • -Wing uprights
              • -Seat brackets
                Had some free time today so I did a quick rendering of the front of the car. (Sorry @Earl I promise I will get to yours!)
                Give me some feedback, I am always open for more ideas, but for now, this is what I am shooting for. IDK about the Lightbar, but yeah.
                  i like the rendering. the light bar looks like an afterthought, though. maybe a roof scoop with a small LED bar inside the opening, or some small LED fixtures going down the a-piller?
                  or a few of these on each side
                    Yesss!!! I agree. The light bar sucks.  You got me thinking WRX hood scoop with lights inside mounted to the moonroof?
                    I also forgot to add the white lettering on the tires before
                      Makes me think of a hood mounted led bar indicator tach, like a firebird 301 turbo boost indicator, just with modern led bars
                        yeah that looks right. run it all the way back and tie it into your rear window louvers for bonus points
                          Very late 80's. I dig it!
                            Pontiac was way ahead of the curve with that one. That car was produced from 80-81 lol. I had a friend with one in high school. So damn slow.
                              little inspiration for you 😁
                                LOL that's awesome @Bassboy3313
                                I haven't done a whole lot lately, as I have wayyy to many projects going on at once, but there have been some small things that I have been chipping away at. I got the red halos for $8 on ebay, and mocked them up. really surprised at the quality for $8.
                                I also started CAD modeling all the aluminum parts I need to make:
                                • X-Hydro lever
                                • Shift level
                                • Seat brackets
                                • Wing uprights
                                So far I have the Hydro level done
                                • johnprusinskiJ
                                  johnprusinskiJ
                                  johnprusinski
                                  This is dope im excited to see the end product.
                                    Thanks!! Me too.
                                    So I happened to watch the movie Elysium last night. Mostly because I found this video of the Elysium Liberty Walk GTR on Facebook and felt inspired. I have watched the movie in the past but that was prior to owning something of similar nature.
                                    I really really like the bars on the windows, but I also think the large plugs and wires on the hood are successful. Maybe I could use some larger 1/4" audio jacks or some 3 phase plugs. Now I know some of you are going to be like " I thought this was more "phuturistic" and less "mad max" which I want it to be, but there is a fine line between the two so I might cross territories here and there. The car is pretty rough so my intentions were something more along mad max, but I wanted it to look like it was born to roam the apocalyptic streets of New York vs. the dirt roads of Nevada like Elysium. Use your imagination at your own risk here and feel free to fill my mind with ideas. 😄
                                    Image result for Elysium Liberty Walk GTR
                                    Image result for switchboard
                                      Bars on the windows!? I can barely see shit as is lolol
                                        The added touch of the graffiti tag on the side is awesome imo
                                          i've got the long battery cables from an e34 I would donate for your madness.
