'88 E30
Pull the cluster and tighten the nut on the back of the temp gauge. Not a real gauge like you want but it will improve the reading in the meantime.
Your carnage got me thinking of adding to my spares. Ive been talking to a r3v seller parting a set of axles from his car. Waiting for pics but what I know so far is that they are 200k originals with torn boots on the passenger and worn but not torn on the drivers. Splines supposedly in good shape. We'll see.
Best route from assorted forum chatter seems to be either rebuild the factory axles if the boots are shot (cheap but time and a mess of a job) or pick up GKN Loebro axles (substitute money for time in the high $200s per axle), and avoid the cheaper cardone reman and esp the dirt cheap AZ AAP axles. Anyone have any experience here?
As far as the nut goes on the cluster, part of me just wants to replace the OEM gauge with an aftermarket temp gauge such as this
As far as GKN blunttech has them at $259 each.
It also seems as though reman is hit or miss, but usually miss.
Honestly with these lasting 240k miles, I wouldn't hesitate to put one in from a parts car. They are easy enough to replace (albeit annoying)
Once I get the motivation back, I am quite interested to see the carnage & will share pics
Ok. So after work I found some motivation. All in all it took like an hour and a half. So.
Step1:
Beat the axle lock plate off, then removed the axle nut.
Step2:
Jacked the car up
Step3:
Removed exhaust
Step 4:
Forgot that I needed a way to stop the axles from turning.
Step4.5:
Step5:
3/8 ratchet was not enough leverage to remove the axle bolts
Step6:
Grabbed breaker bar with 1/2-3/8
Step7:
Driveshaft was still spinning a bit while trying to loosen
Step 8:
Put in gear
Step8.5:
Added 18mm wrench on flex disc
Step9:
Yes my exhaust was safety wired up
Step9.5:
Don't judge me
Step10:
Remove every axle bolt
Step 11:
Slide axle out
Step12:
Carnage
It blew the boot and the clamp off
I was literally able to pull this apart one handed
^ballz
^hopes and dreams
It literally deformed from the carnage
(Ignore the fibery stuff, from a rag)
Step13:
Anybody have a spare axle?
Only buy genuine BMW?
As dumb as it may sound, I might just snag a bunch off of parts cars & have spares. If these lasted 240k, I wouldn't have any reservations running other ones. They are easy enough to replace if necessary.
thanks for the carnage pics. i'm thinking a necklace of honor made from the cv bearings would be good.
They may have lasted 240k miles of normal driving, but not 240k miles of crazy launches from a higher torque engine swap. [emoji14]
Step9:
Step9.5:
Don't judge me
Whatchu know about safety wiring exhaust?!
That was an amusing evening lol -
If GKN is sold through WorldPac then you should be able to order them from Advance Auto or Carquest. Advance acquired WorldPac with their acquisition of Carquest. That could save you some shipping.
Just gonna snag some used OE ones from Nick. Perhaps regrease and reboot them.
Lowered the car off jack stands today. Then folded the mirrors in. It's stored. I've given up on finding 4x100 wheels in 15" for slapping some spare tires on for storing. I'll probably just end up putting it back on jackstands. Brooke's Miata is taking over the garage this winter for the turbo stuff. We almost have the motor out of it. I would rather own a broken e30 than a running Miata. I figured out the reason they last 250k miles with minimal maintenance is because when you do have to work on them there is zero, fuggin, room and the thing was put together so ass backwards you'd need 3.7 arms, 32 fingers and 120 vacuum fittings to do anything to it (it's not that bad, i just enjoying ranting)
In all seriousness if I can get the axles taken care of, possible source a 3.25 LSD, get an actual water temp gauge, change the t stat/waterpump, add power steering this winter I'll be happy.
If I end up liking miatas after this winter , ban the shit out of me.
forgot to post the Road America video here. for some i reason i let off before the timing light
Just picked up some axles from Nick! Will be ordering crap to reboot and regrease them.
Haven't touched the axles as the Miata is suffocating the garage right now. But I slapped on a wheel I picked up from Dan. I really like the smaller size and the way it sits a tad closer to the driver
Size comparison to stock for those interested (no idea what mm the sparco wheel is)
Might eventually get a center horn button, even though I don't have a horn
What a comprehensive review
looks purposeful next to that hydro lever!
also the yellow stripe compliments the blue ratchet strap nicely.
So haven't done anything to the car, as the Miata is still priority. But I finally hung up some lights. Already have the 2 LED bulbs in the normal sockets-but they're in non helpful spots.
Went to menards. Spent $10 per fixture thing. Bought some 6500K LED bulbs for like $8 and hung them. For under $50 I can now see what I'm ruining in the garage!
Also put it on jackstands again, hooray
Also, it's t shirt and shorts weather!!
