  4. '88 E30
'88 E30
savebigmoney
    1c4225a2a30b7135c62c56153b6c81b5.jpg23c40103e3a53f36b8930f1b28a71726.jpgc072d33802e09654b6a2e70d956f241c.jpg
    Rolled it into the garage and I'm leaving it there until spring.
      Haven't torn into it but I'm 99.99% sure it's the drivers side axle, If anyone has an axle in not destroyed condition I'll pay you for it
        @GunMetalGrey mentioned having one.
          Same here! lol. Except I have a lot of body work to get done over winter.
            It was nice seeing you for a minute before the cruise 😂
              http://www.driveshaftshop.com/import-axles/bmw/bmw-e30-1986-92-direct-bolt-in-axles
                B)
                I'd rather pound my nuts flat with a mallet then spend $1700 on axles
                  I bet you won't!
                    http://www.catuned.com/e30-bmw-325i318i-m3-custom-4340-chromolly-axles
                    I don't think these are necessary for your application, but many people use them.
                    Edit: Just realized that they no longer sell them.
                      I bet you won't!
                        Not quite flat but... i'll give you that one.  Well played.
                          I remember talking to you about rage drifting 2-3 years ago and how i didnt condone of your clutch kick lifestyle. This is why we dont clutch kick :P
                            I remember talking to you about rage drifting 2-3 years ago and how i didnt condone of your clutch kick lifestyle. This is why we dont clutch kick [emoji14]
                            I believe RA autocross sealed the deal with like 12 hard launches. Snap was the straw that broke the camels back. So many highs and lows were had in .2 seconds
                              This is how i got my name, it was just 7 years in the making
                                10/18/16 <--- i was there when snap got his name.
                                on another note, I will stay away from sticky tires and hard launches.
                                on a 3rd note,
                                  Well. It's definitely the drivers side axle. It blew up to the point of separating the cv boot and spewing grease everywhere. d2abf455270c7e97afc4d6f319745917.jpg
                                  Pic kinda sucks, but there are broken parts everywhere inside the rubber boot.
                                  I'm not sure if it was so much "sticky tires and more hp" I think that definitely helped break it - but these things have 240k on them & lots of hard launches from autox.
                                  Car has LSD, jacked it up from diff, in gear and this was the result (the axle was not moving) hopefully the video posted
                                  https://vimeo.com/187926931
                                  Dickered indeed
                                    That's not curb rash btw. That's farm and fleet tire lube stuff
                                      Also, rusty calipers/rotors. I blame it being parked outside in the rain for a night.
                                        So I haven't touched the axle at all because I suck, but I started cleaning up the power steering stuff I'll be installing. 9bca9652169c12c92a2bec40c6682310.jpg
                                        a1b54d18dee22c70ad893fe2ec307625.jpg ended up being a LUK pump, so I'm thinking it was maybe replaced on the parts car I got if from at one point? (Thought they were all ZF, I could be mistaken)
                                        Other than the 4 inches of grime I scrapped off, the pump is in pretty good shape, just need to order some new lines and then wait for it to leak 5 minutes after installing.
                                        It'll be interesting to see if my current de-powered rack will leak.
                                        Besides fixing the axle never, this winter I want to put a Stewart water pump in and replace the "new last year" $49 graff. I also may go to a lower thermostat as opposed to the 92c I currently have in the car for science purposes.
                                        Also want to install an actual temp gauge as opposed to the stupid e30 gauge that varies by how hard I hit the dash. (Open to recommendations here)
                                        I'll probably end up using the port on the head where the coolant for the throttle body goes as I already have this looped.
                                        Either way this winter should be decent because it's all little piddly shit
                                        Also if anyone wants a rack you can have it, or I'll just make an ATF soaked lamp out of it
                                          ce95bef30f0fe1b77135991cac5dfb3c402688c5
