726 Posts 28 Posters 9.6k Views 2 Watching
    Good stuff
    I imagine the water pump is pretty quick and easy with the hardware situation straightened out
      I hope to God you opted to order that with the hardware...
      Nope! Living life on the edge on this one. Lag bolts will be fine.
      Good stuff
      Yeah. I tapped all 27 holes on the front of the block and got new hardware where needed. This biggest problem is that 5 or so of the bolts went through the water pump then through the timing cover and threaded into the block. So I had to pull the timing cover and harmonic balancer off. But this was okay because I was able to replace the front main seal and the timing cover gasket which was slightly leaking as well.
        I meant hardware for the fittings. I have the same one and went without. It was a PITA finding stuff
          Why? What size were your fittings? Also, mine wasn't the same as the one pictured above, but it's similar.
            Don't remember, it was a while ago. Pegasus should have some. I ended up getting mine from John Prusinski as he had one leftover
              Good to know. I bought it off of ebay so im sure it will be a fun time finding what I need.
                So I got the whole water pump deal back into the car for the second time, only to realize that it was still leaking from somewhere. It turns out that if you own a Ford you have to get really use to taking things apart more than once. So what happened is there is a second set of holes in the timing cover for an older style waterpump. SBF's have been around and in production for a longggg time. Apparently my understanding is that I have a reverse rotating timing cover which is common for older carb'd 302's and mine is a newer fuel injected motor and I am using a regular rotating water pump.
                Nice.
                So I can run this timing cover but I will need to thread some type of plugs into the bolt holes that the coolant is leaking out of. Ughh.
                On the more aesthetic side of things, I have come to the conclusion that I am going to add some red accents to the car to make it seem more, uh demonic or devilish? I ordered red window tint and plan on adding some red halos and red leds here and there like so:
                  I think that red tint will actually look pretty awesome on this car. Nice idea!
                    I'm greatly enjoying this thread.
                    It's amusing having two active threads of cars that we don't truly care about!
                    The red tint should be interesting, that's for sure!
                    Any plans of throwing a huge wing on the back of the car?
                      evil to your wallet AND to your eyes.
                        Thanks everyone! I am glad to hear everyone likes the red tint idea. I was slightly skeptical at first but now I am fully devoted since I have some supporters.
                        I do have plans to toss a massive rear wing on the car. But I am also trying really hard to keep everything low budget. I want to be able to smash this thing into a wall and not worry about how my wallets feels after the fact. I was thinking it might be cheaper to just make a duckbill spoiler vs buying a wing. If anyone has an idea on where I can find a big, dumb, idiotic, monstrosity of a wing for a good price, please share.
                        I will be making a splittter, and a rear diffuser for the car as I already have the materials, I just need the time and a plan. So far I was looksing at some of the following:
                        11881783904065033010307224974352n.jpg122246941523556801297859648433461n.jpgZfHFbn7.jpgBmw-E36-Rear-Boot-Ducktail-Drift-Spoiler-57.jpg168646226279a4de75009o.jpg
                          I don't know why it does it for me, but the back of that red e36 is gorgeous.
                          I have wanted to do some crap like that to my e30 for awhile now...
                          The downside is that they are indeed expensive!
                          A friend used plexi, a couple of hinges, and turnbuckles to put an adjustable plexiglass duckbill on the back of his e30.
                            Ive seen it done many times for pennies. But big wangs are just awesome. Best deal i have found so far was $180 and thats without uprights.
                              I'm sure you can snag one from the southside off of the back of a few cars
                                Same place I can get extra low offset wheels and clear taillights from too I presume?
                                  can i have some of what you guys are smoking?
                                  to me it looks like the car is missing its bumper and someone was to cheap to replace it.
                                    Amen brother!!!!!
                                      I would say too lazy to cut slits into the bumper to fit around the uprights instead of too cheap
                                        I would dare to call it a hack job piece of shit, but I guess that's how most "builds" are these days. I won't even bring up the term "taste"...
                                          Amen
