  3. Local Scene
  4. E30 Suspension Guru's / Welders?
29 Posts 7 Posters 497 Views 1 Watching
    I recommend getting at least a toe correction kit too for the rear subframe. Otherwise you'll eat tires like a monster. It's like $74 on rev.
      alexw said:
      I picked up a set of German Engineering coilovers, which are much like the Ground Control "kit".
      Does anyone have experience with shortening strut housings? Any good welders here?
      I'm diving into this head first with no flipping clue as to what to do. From what I've read on r3vlimited, I don't HAVE to modify anything. But running shortened housings and shorter (iX) struts/shocks I'd be able to go lower...
      If you want to respect the roll centers of the car then I would suggest not slamming it. If you do, the springs and sway bars will need to be stiffer than they would normally need to be in order to keep body roll in control. I am going to go weigh my car again soon and calculate the roll-centers and try to determine exactly what is too low (at least for my car). At least with coilovers you have the option to slam it for looks then bring it to a more proper height for performance sake
      • I
        I
        industrialsized
        i can probably give you a hand with the lowz
        • M20_feverM
          M20_feverM
          M20_fever
          Here is a nice little write up o e if our members on e3p made: http://www.e30performance.info/viewtopic.php?f=23&t=1408
          2012 MCSCC class champ C Prepared
          2012 NSSCC class champ C Prepared
          HSAX Instructor
          • alexwA
            alexwA
            alexw
            I should have clarified, I'm not looking for a slammed look.
            This guy on R3v has pretty much the setup I'd like:
            thebutcher37 said:
            Finally posting.
            • Car is 1991 318is m42 motor
            • GE coils 450f 6"/650r 4.5"
            • I.E. Race front camber plates
            • Bilstein sport strut/shock
            • Rolled/pulled fenders
            • on 16x9 wheels et10
            • Front is all the way down
            • Currently need to lower the rear a bit more
            http://desmond.imageshack.us/Himg525/scaled.php?server=525&filename=screenshot20120424at115.png&res=landing
            http://desmond.imageshack.us/Himg718/scaled.php?server=718&filename=screenshot20120424at112.png&res=landing
            P.S.
            Sig below: wheels are poked with 20mm spacers. making wheels et -10 and rear is lower about an inch.
            He didn't modify anything besides cutting the spring perches. I'm not sure that I have bilsteins sports though. I have to look. The other option is chop 2 inches off of the strut housings and run iX bilsteins which a member has for sale here...
            alexw
            332ti - Work in Progress
              ^That's a great height=)
              • alexwA
                alexwA
                alexw
                I'm going to be running 16 inch wheels so that should be about right.
                But I think I'll have to cut the housings and just run the adjusters at a higher setting. And of course run the iX bilsteins...
                I just need someone with some expertise and tools lol.
                alexw
                  You had two e30 tourings? Never knew this
                  • alexwA
                    alexwA
                    alexw
                    Doesn't come up in conversation very often...
                    This was when I was living in Germany. I have photos somewhere, I'll post later.
                    alexw
                    • Ryan...R
                      Ryan...R
                      Ryan...
                      WTF two e30 tourings??
                      As for the welding aspect, isn't that something any competent machine shop could handle? I wouldn't trust just anyone with cutting/welding on my suspension... The pics you posted have perfect height too.
                        wish i had a welder, i'd do it for ya.
                        if you need a shop
                        milwaukee: pat kummrow @ kummrow automotive
                        kenosha: steve tredup @ autosport (if he does fab, not sure)
                        • alexwA
                          alexwA
                          alexw
                          I don't know that I want to waste money on having a shop do it. Maybe I'll have them modify the strut housings but nothing else.
                          The guy who's car I posted, said all he did was cut off the spring perches, he's still running stock (well bilstein sport) struts and shocks.
                          I'm not sure what I have for suspension right now, but it's definitely stock or oem replacement. I'm not looking to spend a ton.
                          FullBannana has iX strut/shocks for me, but I'd have to do the cutting....
                          Idk....
                          alexw
                            Why can't you do exactly what the other man has done?
                            • alexwA
                              alexwA
                              alexw
                              I'm not sure I have bilstein struts/shocks. I have to look. The concern is I may have some cheap stuff and it won't mate well with the camber plates. And won't be decent ride with the shorter springs.
                              I could be wrong...
                              alexw
                              • alexwA
                                alexwA
                                alexw
                                I think I'm going to bite the bullet and do it the "right way" and shorten the strut housings. Anyone have any experience with that? Coilovers will be here tomorrow, just need the iX bilsteins from FullBanana.
                                alexw
                                • alexwA
                                  alexwA
                                  alexw
                                  And for good measure, photo of my WIFE'S E30 touring:
                                  (previous owners photos)
                                  It was a 94 318i, he did an M42 swap. It had a chip and a few other goodies.
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  Posted Image
                                  alexw
                                  • Ryan...R
                                    Ryan...R
                                    Ryan...
                                    Ok, I'm jelly... That looks super clean, and very tastefully done!
                                    • alexwA
                                      alexwA
                                      alexw
                                      And my 318... An 88 that I got for $400
                                      Posted Image Posted Image
                                      They both had euro weaves mounted at one point, I never really kept up with the mod list on these cars. We maintained them to some extent and then they both crapped out on us and were junked because we couldn't sell them before we left. Inspections were required prior to a sale of a car, so it was really a pain in the ass for sellers of subpar cars... No "as is" sales without a lot of BS to wade through.
                                      alexw
                                        Why you no bring that back with you? You met your wife in Germany?
                                        • alexwA
                                          alexwA
                                          alexw
                                          Dude, I'm sure you've looked into it at some point. The cars have to be a certain age (typically 20-25) the best conditioned one was a 94... So-
                                          Add the months of customs bullshit. Add that it had to be converted. Add the fact that they're rusty fucking cars (not just all e30's, but the touring's hatch is notorious for rust).... Add up the shipping cost ($1000+)... I could go on.
                                          It's not worth shipping a car from overseas. And I'm sure you haven't already forgot... I had an E30 M3, that was a little more exciting than a 80's station wagon.
                                          alexw
