  4. chit chat thread
chit chat thread
    Awesome! Is that from the render of my car?
      Very well could be, lol
        Eurowerks ¡¡
        • Ryan...R
          Ryan...R
          Ryan...
          The eff is this, and more importantly, does it actually work:
          http://www.ebay.com/itm/400383206757?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
            Ha.  Do they work?  Well....what is your definition of working?
            There are 4 high strength springs in between the 2 metal plates.  You slide it in the diff then remove the little plates on the ends that are holding it together.  This allows the large metal plates to press against the faces of the gears, this pressure stops a bit of the slipping when the torque causes the other wheel to spin in an open diff.
            Does it work?  Technically.  How well they actually work is up to the user.  In my opinion they don't work very well, the amount of force on the face of the gear will not be enough to keep the diff locked, or even limit the slip to any noticeable degree, the key word, 'noticeable' it does technically do what it says, just not in a noticeable way.  What they do do well is keep the diff tight and less chance of sudden explosion.  They are far from an LSD though.
            • JeffJ
              JeffJ
              Jeff
              Earl?
              1976 530i e12
              1990 325ix e30
              1992 325i e36
              1995 740il e38
              2001 330xi e46
              ^More to come :)
              • Ryan...R
                Ryan...R
                Ryan...
                Makes sense, I didn't understand how these things were supposed to work in the first place.. Guess I'll have to get an LSD the ol' fashioned way; spending cash money.
                  I've heard of similar things being done with a carefully machine block between the spider gears, but never seen one with springs in it.
                  Wouldn't expect it to work well or last long. Metal against metal doesn't make a great friction surface, and you'll end up with shavings floating around in the lube...
                    It was weird seeing a large group of WIBimmers people at the show yesterday.
                    That is all.
                      In a good way or a bad way?
                        Most definitely a bad way
                        • Ryan...R
                          Ryan...R
                          Ryan...
                          Anyone wanna come help me pull a motor/trans out of a wrecked 325is next week? Located in Darlington WI, I'll provide drinks/lunch, gas money, and it should be on a 2 post lift with the front pulled off.
                            Find Mark Kirksey or Mike Ramsey on facespace. Might be able to help if they aren't working. Both live nearby.
                              I'm around Monday, Tuesday and Wednesday.
                              • Ryan...R
                                Ryan...R
                                Ryan...
                                Sweeeet..
                                I'm trying to figure out exactly how to tell what kind of cams it has without completely removing everything. If it doesn't actually have the M camshafts I'd probably pass..
                                Sent from my SM-G900R4 using Tapatalk
                                  If you can get something in there to measure lift you can tell. I think 9mm lift for m50/52 cams and 10.2mm for s50/52. Obd2 cams are thicker in the shaft of the casting for less vibration but the same profile. The obd2 ones need the obd2 trays and lifters as well for clearance of the thicker camshaft.
                                    The difference between the round area and the max diameter area is the lift. You should be able to check it with a caliper.
                                      Dat camber tho!
                                        I made a deposit for work to get started on my barn/shop.  It is 32x42', you can't see in this picture but one side of the roof is way beyond repair the arch is sagged the wrong way on the majority of the North side, left in the picture.
                                        IMAG0835zpscrhehajv.jpg[/URL]
                                        When finished it will have a 12'6" ceiling downstairs and a good sized upstairs.  It will look like the Amish barns which are plentiful around here.  An Amish crew is doing the work.  Pretty excited for a real shop.  The structure will be done and sealed up before winter.
                                          ^Very cool!  Where at?  Going to put a driveway to it?
