e34 Touring
I've got 2 spacers if you are interested.
size/price/extended lugs?
Look to be about 3/8", come with extended lugs, ECS Tuning brand.
I typed in the part number on the side and get this: https://www.ecstuning.com/Search/SiteSearch/10mm_Spacer/ES2550806/
Half off fair? They could probably use some cleaning.
thanks, going to pass. I need something more like 15mm/20mm to fill things out.
beautiful foggy night tonight. tried not to get murdered while out in the industrial back lots for a picture or two.
also, i struggled a bit taking good shots in the fog, I need more practice!
Your headlights r garbage.
I have Finding Nemo flashlights that r better than that
But really, im interested in there being a WIBIMMERS 2017 calendar or something and we should put your photography to use at some of these meets.
I would help with a calendar, sure.
another update towards the car becoming the Ultimate Daily-ing Machine
Installed a Curt Class I hitch. Was going to be building a teardrop camper to tow, but sadly that won't happen. Next plan is maybe a small boat and using a trailer to pickup bigger engines.
it bolts to the underside of the bumper, and in these three places under the body. its rated to 150lbs tongue weight, but i stood on it and bounced and i'm a well overweight at 2 1/4 and nothing broke so i have confidence in it.
still finishing up the wiring, but the cool part is i can hide the plug behind the tow hook cover to keep it pretty protected from dirt/rain/snow.
wiring done. labeled it for anyone else who is thinking of doing this. because the e34 has the light check system, the wiring adapter you need is the kind that takes its power from the car's battery, and the splice wires to the lights only give the adapter the signal for which lights to turn on. that way the voltage drop/raise is so low the system doesn't throw a check light.
mounted it inside the passenger side panel since I don't really use this side for storage.
factory sound insulation fits right over the top of it so i can still put stuff in here if i want to with damaging anything.
don't mind the brown burned-looking crap on the ground wire. there was mystery goo on the bottom of the insulation that i didnt notice till it was too late.
Looks great! I've been considering adding a hitch to my e46 wagon.
Thanks!
did some touring things with the touring today. i custom built the tandem rack by re purposing a set of two regular bike holders. new tandem racks cost $300-400, I did this one for $15 in hardware (i found the racks on the side of the road)
Amazing!!
Ride a tandem bike by yourself from the rear seat
thanks guys.
like this?
Use the front pedals tho
Looks awesome. Love the Alpinas?
BMW Style 32's, Alpina's have more spokes.
yup. 90% of the style for 25% of the cost = 100% worth it.
