  4. Shop Life 2.0
Shop Life 2.0
nochristmasjazz
    No worries, I've got work to do in that area anyway.
    Just a friendly PSA. If graphic scenes of violence against strctural metal offend you, then you may want to avoid this thread for a while. It's about to get real horrorshow...
      I have a set of BNIB rear wheel bearings and seals with your name on it! Let me know.
        Mine aren't bad yet, but I've started soaking the nuts in penetrent periodically as a precautionary measure, because I know that day is coming...
        Don't you think you'll need them before I will with the offsets you're going to be running?
          I am running e21 323i rear trailing arms which have bigger bearings than the US spec 320i does. So I wont be using them.
            Finally got around to getting the pics of the suspension off my camera and made some eye-infecting visual AIDS.
            Also got some raw materials to work with now, so hopefully I can get back to work on the car this weekend. Oh, and another engine to replace the Automotive Supply enhanced unit that's currently in the car. Thanks Industrialsized!
              I approve of these lumbergifs
              Im interested to know what prep you are doing/plans you have for the spare engine
                The engine I got has a snapped cam, so I'll probably take the head off the current engine to make a stock engine to use for the summer. The effed-up block will get bored out 1mm over for some low-compression pistons 😄
                  Might I suggest Automotive Supply? I hear they do great work!
                    Wow, 6 months since the last update...
                    Well, now that my chances of success with this project are starting to look better than my chances of horrible and disasterous failure, I suppose I can let the cat out of the bag. As can be seen above, there's a limit to how much you can lower the rear of an e21 before suspension-things try to occupy the same space as frame-things. Lowering the car that much also creates camber and toe problems. I wanted my car to be lower than what was really reasonable, AND I wanted my suspension to be functional, so I decided to do what any rational person would do: cut all of the rear subframe mounting points out of the chassis, and move them up a couple of inches.
                    Still with me? Okay then. I didn't take many pictures until recently, but I can tell you that after the initial cutting the regret set in immediately and deeply. The biggest hurdle with this project has been getting over the psychological trauma of seeing giant holes in your car where important structural things used to be. Many months were lost staring at the nothing that was left, wondering how I would ever close the wounds. Somehow, I just kept moving, hoping that my efforts would somehow reclaim my car from the scrap-heap, for which I thought it was surely destined.
                    I've still got a lot of work to do, but I think I'll have a running, driving car again someday...
                      I cant relate, but i understand completely
                        Glad to finally see pictures!
                          Looking good!
                              Gonna roll the car outside and wash the dust off it today.
                                Much better.
                                Feels like I own an e21 again, instead of a big lump of metal that does nothing but sit around on jackstands collecting dust.
                                  Isn't that what owning a e21 is like though????
                                    Daggerty said:
                                    Isn't that what owning a car and being part of wibimmers is about though????
                                    Fixed that for ya
                                      Hoggin out some parts at the shop away from shop (work 😕 ). Woo! Friday night!
                                      Damn, I need to get a life...
                                        I cant think of what the brackets are for. Give me a hint!
                                          Are they trailing arm brackets for the subframe instead of welding on tabs to the existing ones?
