  4. '88 E30
'88 E30
savebigmoney
    Well, pretty much got everything back together last night. Coilovers in, stud conversion, front brake caliper/rotor etc etc.
    had to fill up the reservoir about 3/4 times before we even started to bleed
    Starting at the passenger rear I had Brooke pump the brakes. This is when i noticed fluid seeping from the bleeder screw, I quickly just reached for it with my hand &and turned (thinking it was just loose from shipment). Turns out I could over tighten it by hand and the threads are cooked in the casting themselves. It must've been put together cross threaded so it felt snug when they sent it, but was all dicked when I tried to actually use it
    I sent blunt an email about it last night so we wil see what he has to say
    I cannot tell you how frustrating it is being almost done and wanting to finish on your 3 day weekend but you can't because "new" parts (remanufactured) aren't up to par.
    Silver lining is that it happened to the first caliper, so it's not like I had the entire system bled or anything
    e5147cb740bb2617e7ebdde2f4a94b82.jpg8aa38c06986986e2682fe7321d0e610c.jpgab43abc9758b956e0ec625b1f85158ae.jpg
      Why no strut tower brace?
        That sucks to hear about the caliper, I thought the WBR's I received from Blunt were pretty good quality. I'm sure he'll get it sorted for you though. I'd definitely paint the calipers if you want them to keep looking nice as they are just raw metal, I didn't have time to do mine and now they are completely covered in surface rust.
          Going back on after I get the coilovers adjusted
            I emailed him immediately last night.
            Just so I can get this thing going I ordered one this morning and it's getting here at 12:30
            I just want this stuff to be done at this point.
            Unfortunately I didnt paint them because I was lazy about it. I thought they were media blasted then painted in something already..?
              That's what I thought too, the finish looked really nice but I'm like 99% sure they were just raw steel with an oil coating. Once the oil washed off mine rusted in about two or three weeks, but keep in mind this was the middle of winter with super salty roads and driving like 40+ miles a day so yours may go way longer before showing anything. I was planning on giving mine a coat of paint this summer if I ever get around to it.
                Picking up a caliper after work today. Then gonna go home, remove all my calipers and put some paint on them. No reason to not do this right the first time.
                  Picked up the caliper. Thought about painting them all, then decided not to because I am a lame person and just want to drive this stupid thing. If/when they start to rust and look shitty I will remove them, think about painting, then probably just upgrade the brakes anyways.
                  The caliper still leaked out of the threads where the line gets attached, hooray. Found that out while bleeding. Removed the line from the caliper, cleaned crap as best as I could, reinserted and tightened it back up, no leaks during bleeding process or when brakes were being stomped to check for hissing/crap like that.
                  My buddy came over, we had some beers. Then decided to finish the car. It's 4:31AM and I'm tired but it's back on all fours
                  Still need to get the endlinks on and mess with front ride height/preload. The rears are basically where I want them, they will settle a tad yet. The front is a touch high yet. Still haven't touched the camber plates either.
                  Goodnight/good morning (?)
                    88 E30?
                    More like 88 MPH
                      Pls don't write off my car because I didn't paint the calipers lololol. I taped one off and it drained all of my patience and desire to work on this turd
                        Adjusted the ride height again today, slapped in the endlinks, moved some brake lines to betterish spots and yeah...just have to install the exhaust tomorrow as well as the strut bar. Fired it up today, I left the battery disconnected in the car since October outside in the garage, car still immediately popped off. Open headers sounds terrible, even for the 15 seconds it was running.
                        I pretty much rechecked every bolt I had removed for proper torque. I really hope everything goes smoothly on the test drive tomorrow...
                        pic of ride height, compare with above photo. I may need to bring the fronts up a touch8f3123b81e0b6fae870c534a36273b6e.jpg
                        Endlinks from AKG
                          Dont you go around increasing the market value of e34 oil pans now, ya hear?
                            Trust me I'm not going for "the lows" I'm still learning how adjusting the coilover changes the ride height (how much movement on the threads change it) it's also on 15s so it seems like it's nose diving. And I also have a monster skidplate that hopefully helps protect the hard to find e34 pan
                              AHHHHH ITS WORKING
                                Doorman
                                Looks fantastic!
                                  Nice work!
                                    Thanks dudes!! I need an alignment in the worst way but holy crap it's a million times better to drive.
                                    Only thing I'll have to get use to is a constant noise from the rtabs. Like a popping/cracking (?) sound as the suspension travels
                                      Did you grease them? What kind are they? I have poly rtabs on my e36 and they squeak.
                                        They are solid delrin
                                        No grease on them besides some Antiseize from the bolts.
                                        I'm okay with the noise, I'd just like to know where it's coming From.
                                        The poly bushings in the subframe I robbed some grease from the sway bar poly bushings (came with a few packets) Could it be the sways with adjustable endlinks? Only happens when car is traversing uneven surfaces or hitting decent bumps in the road. I can try and mount my GoPro up there and see what I can hear
                                          After sending multiple videos to snapsby he confirmed it is most likely the fact that I have aluminum cans for suspension. Actually it's the rtabs.
