1.8k Posts 58 Posters 0 Views 1 Watching
  • andyhundleyA
    andyhundleyA
    andyhundley
    I was holding that off until I get the engine in and the harness snuck through the firewall to meet the fusebox. I should also wire up all of my air ride components so I can easily run the wire/cables.
    Well, what are you waiting for?
      I need to do front brake lines first and I need to solve my master cylinder issue to be able to do that.
        Do it earl
          Been working on things here and there.
          Brand new quarter glass is in:
          I then cleaned and reinstalled the B and C pillar trims, as well as a clean set of rear speaker trays (no pictures).
          I replaced all of the latch strikers as well since they looked a little dingy. New-Left  Old-Right
            #showcarproblems
            looks good!
              lol at the new thread title again
                Glad to see your commitment to perfection and attention to detail are still alive and well.
                Most people dont know it but at the E30 picnic and Concours I inspect peoples door latch strikers. I have a running list of cars I would and would not buy if I ever saw them for sale.
                • JeffJ
                  JeffJ
                  Jeff
                  Earl! I can believe you still working on the car. Keeps looking better and better
                  1976 530i e12
                  1990 325ix e30
                  1992 325i e36
                  1995 740il e38
                  2001 330xi e46
                  ^More to come :)
                    Pulled my steering column yesterday to rebuild it. Just waiting on my parts to arrive so I can put it back in all freshened up=)
                    I also finally sourced a master cylinder to use and have ordered all of the brake line that I need to plumb the rest of my brakes. I got bored at work today and shaved off all of the casting marks. I will be painting it to match my engine block when I get home.
                      Rebuilding a steering column. Never would have thought to do that
                        It's Earl. Expect the unthinkable.
                          They get squeaky and loose on e36's=) However this one felt fine before but doing it while the dash is out only made sense. The one in the coupe is starting to squeak and will probably need to be rebuilt in the future as well.
                          • andyhundleyA
                            andyhundleyA
                            andyhundley
                            Let it squeak!
                                Peculiar crack pipe
                                  I pulled the fuel lines and rear brake line that ran up to the engine bay on Friday. I have decided to refresh all gas lines while I am at it. More on that later in this update.
                                  Installed all of the new parts on the steering column Sunday:
                                  Yesterday I pulled the gas tank....yes I have officially lost my mind
                                  I will be cleaning the tank up, replacing all of the fuel lines, and cleaning up the underside of the car where the tank has been. I had a few fasteners snap under the car which has me quick frustrated. One of them was the stud for bolting the fuel filter to the car. I am trying to figure out how to remedy that situation currently. The other fasteners were the screws holding in the three mounts that ran the fuel and brake lines forward. Those will also be tricky to sort out.
                                    If you don't have access to the back side of where they snapped, drill out the base of the snapped studs, pop in some nutserts and some stainless steel bolts!
                                      I'm assuming the other side of that sheet is my floor lol
                                        Oops, didn't even think of that part haha
                                          Yeah it has me stumped=/
