  4. e34 Touring
e34 Touring
269 Posts 26 Posters 4.5k Views 1 Watching
    Nice touch on the license plate
      thanks gents.
        boring update, nothing to see here, just posting for the record.
        today was f*in beautiful out, so i took advantage and did a brake job and oil change. new pads/rotors all the way around. no upgrades, just stock stuff.
        overall, these were the crustiest brakes i've ever pulled off a car. holy strange pad wear grooves.
        mmm fresh oil.
          What are you running for oil?
            10w30 for winter/spring. 5w30 also is good, if you are wondering.
              another nice saturday means another project done.
              installed my George Graves USB charging port. Great product. (you can find them on r3v)
              install instructions plus my diagrams from the ETM. you can use the ACC wire from the radio, but i didnt want to fuss with pulling the radio. when i did my 5 speed swap i ended up with the x511 connector (from the auto trans shifter) free under the shift console, so i looked up which pins might work there. Pin 1 is hot in run and start (perfect), and pin 3 was grounded. Pin 5 was possibly a ground in the ETM (i'm a little slow comprehending the ETM), but there was no wire there on the car.
              my x511 adapter harness (which has my reverse light wires at pin 6/7) and the new pin 1/3 wires added. (top right, and top middle)
              the USB port comes installed into a factory switch blank (he was nice enough to use an e34 one for me). now i have my AUX input and charger together.
                all prepped for valley pan weekend.  hopefully i can finish in one day, but its a tedious project. the entire intake manifold has to come off, along with all the motor electronics and a bunch of cooling pipes/hoses. i have a leak at the back of the pan that has gone from 'smell a little coolant' to 'dump a little pile of coolant after a drive/top off every week' in the last 6 months. i was just holding out for spring to get er done.
                of course its supposed to friggan rain all day tomorrow...so i have planned something to maybe help. probably still freeze my balls off.
                doing a bunch of 'while you're in there' items.  resealing everything i am taking apart, as well as upgrading to the b40 intake manifold and throttle body.
                box 'o' parts include, but not limited to, new ccv, new intake seals, new water pipe gaskets, new hoses, new hardware, valley pan. yes, that is one single URO part, but its just a plastic cover so i am happy to buy that crap and save 10 bucks.
                b40 intake and throttle body. it has much bigger runners, larger internal volume, and bigger throttle size, so most report a broader power band.  the b30 really falls off at 4k rpms, hoping this will help.
                new seals in place ready for install.
                  Probably too late, but I have a giant easy up canopy you could use.
                    ill actually take you up on that, would keep me way drier than the shanty town (Bum Motor Works?) setup i came up with.  shoot me your phone and when you are available.
                    • CMartC
                      CMartC
                      CMart
                      I had a bunch of those parts I wish I would have known.
                      Good luck on the job, you'll have no problem with it.
                      Excursion 7.3
                      E30 LS1
                        darn, wouldn't have thought to even ask.
                        anyways, so far today's weather is the suck.  here's how far i've gotten... thanks TJ for the canopy, it will help immensely.
                        • CMartC
                          CMartC
                          CMart
                          I could have loaned you a garage spot...
                          Excursion 7.3
                          E30 LS1
                            but would you have searched ebay to find out the going rate for said service before agreeing on a price... or is there a difference between goods and services there...?
                            Don't mind me, I'm still a bit sour about a valance I tried to buy recently, but on an (un)related note, I'm still curious what you ended up getting for that M42...
                              wrong thread?
                                wrong thread?
                                That detective, is the right question
                                  wrong thread?
                                  hold this thread
                                  as I walk away...
                                  Actually I was responding to CMart's post, so right thread, but wrong topic. I heard that the topics are all made up and the points don't matter anyway.
                                  • CMartC
                                    CMartC
                                    CMart
                                    $500 for the engine and trans.
                                    $100 for the ecu and wiring.
                                    Excursion 7.3
                                    E30 LS1
                                      aaaand done. time estimates were pretty close for a first-timer, about 12 hours. would have been less if not battling the weather.  still have to do a couple more rounds of coolant top off for the bleeding, but she fired up and no check engine light or leaks that i could find.
                                      ran into a couple issues, but nothing terrible. injectors would not come out of the manifold, they were breaking clips and coming out of the fuel rail instead, so had to deal with fuel draining/cleanup. the bolts holding onto the valley pan were corroded as hell, no way to reuse them so had to get new hardware. lots of the plastic (clips and such) was very brittle so many replacement zip ties were used.
                                      battling the wind and rain! tarp deployed to cover electrical bits from slidewayz rain. look close and you can see i anchored the center of the canopy to the roof rack and tied the hood to the canopy so it wouldnt slam on my head.
                                      once i got it there, i found it was pretty gross. coolant, oil, sludge, leaves.  not a terrible amount of carbon in the ports, though!
                                      yeah, there was not much left of the gasket. corroded to hell valley pan bolts.
                                      cleaned up the gasket surface.
                                      new pan in. i'm not earl, so the rest of the mess can stay. i replaced a lot of stuff as preventative while i was in there, but i left the old knock sensors in place: let $200 sleeping bears lie.
                                      instead of pulling the water pump, i wend the other route and pulled the rear cross-over pipe.  new o-rings and gaskets in place:
                                      new o-rings on the water pump side as well.
                                      valley pan cover, water pipes, crossover pipe back into place. theres actually quite a bit of room at the back of the motor to do the crossover pipe.
                                      new 4.0 intake manifold/throttle body in place.  injectors cleaned and ready for new o-rings.
                                      and done!
                                      report on any engine improvements tomorrow...
                                        Green?????
                                          I use green too. And isnt It so nice to use oil and coolant that you can get from places besides the dealer/internet
