    That is a lot more than I expected to the wheels, nice job!
    • The Full BananaT
      The Full BananaT
      The Full Banana
      Thanks! It's pretty fun extracting power out of these old tractor motors. I'm pretty conservative with this one, but it's impressive what sort of abuse they will take at high mileage.
        Looks good!
        Where did you get the genuine MHI rebuild kit from? I picked up a junkyard 16t that I'm planning on putting on an m42...
        • The Full BananaT
          The Full BananaT
          The Full Banana
          I got it from Kinugawa turbo. It was definitely nicer than previous rebuild kits I've used.
            I dig the integral WG + integral BOV turbos kinugawa makes. About half the price of the Borg Warners. They have a couple other hard-ish to find odds and ends too like a bolt-on AN fitting for the oil return.
            Nice torque curve for a single cam!
            Are you toying with the idea of a bmw i6 swap?
            • The Full BananaT
              The Full BananaT
              The Full Banana
              I dig the integral WG + integral BOV turbos kinugawa makes. About half the price of the Borg Warners. They have a couple other hard-ish to find odds and ends too like a bolt-on AN fitting for the oil return. Nice torque curve for a single cam! Are you toying with the idea of a bmw i6 swap?
              Integral WG & BOV/CBV is so convenient for packaging. They do offer quite a bit of interesting stuff, but I'd have a hard time trusting their turbos themselves. That's actually why I only bought the compressor housing and compressor wheel from them, and used my original Mitubishi cartridge.
              I've been toying with either a m52b28 or a volvo T6 (b6284t) swap. At the moment I'm leaning toward the volvo T6 just for the weird factor (and I have a friend who designed some mounts for that block to fit in my chassis). That said, it'll probably be a year or two until I do anything... getting too excited here.
              • The Full BananaT
                The Full BananaT
                The Full Banana
                I've been busy. Putting a 5 cyl volvo engine into my 242.
                Here's what's going on.
                  What's the hp gain? Nice job on the fabrication.
                    Some awesome work you're doing!!
                      don't know crap about volvo 5 cyl engines, but what kind of HP can it handle? based on what you are replacing you must be shooting for 400+?
                      • The Full BananaT
                        The Full BananaT
                        The Full Banana
                        Thanks. Power will all depend on how much boost, from what turbo, I run. Stock against stock, the b230ft 4 cylinder I was running was rated at 160hp from the factory, and the b5234t 5 cylinder I'm using now was rated at 240hp from the factory... although all of that is more or less irrelevant at this point of modification. Some claim that the 4 cylinders can hold more power, but it really comes down to preference. I wanted a newer, modern, smooth running engine, without getting too heavy.
                        I'm not a fan of compromising driveability for an arbitrary number that makes my car internetcool, BUT I'd like to see 380-420whp with very little lag and rather wide powerband. I plan to sell my soul for a Garrett GTX3067r, which is going to be the secret to a good amount of power with great response.
                        Thanks Dave. I really owe you a ride... we'll have to coordinate a day this summer when both of our cars are out and the sun is shining.
                        I wouldn't be worried about running this up to 500whp as it sits. The factory rods are the weak point, and I replaced those with forged h-beam units. The 5 cylinder is nice because it's such a nice tidy package. I chose it for a few reasons...
                        1. Internals for Volvo engines are cheaper than BMW engines
                        2. I got the majority of the parts needed for a massive discount because I know others who are 5 cyl afficionados
                        3. buying 5 of everything is a lot cheaper than buying 6 of everything.
                        4. this 5 cylinder is lighter, keeps the weight lower and farther back toward the center of the car.
                        • The Full BananaT
                          The Full BananaT
                          The Full Banana
                          More.
                          I've been a bit lazy lately--I just want the garage to be warm already!
                          The head, waterpump, and pan are on now. I did a quick test fit of the alternator and power steering pump. Now that I know that all works, I can pull it back off and send some things out for blasting & finishing.
                          I just got the valve cover back with two 10an bungs welded on (with baffles). I need to decide on a color for powdercoating the cam cover, and once that is done I can put the cams in and install the cam cover for good.
                          Here's the same transmission I used with the 4 cyl--a getrag 265 from a '85 e28 535i. I intend to use this with the 5 cyl as well. I love the way it feels and seeing how all of the other incidentals are already in place, might as well keep using it. I'm in the process of drawing up a bellhousing adapter plate that will mate the getrag to a Volvo 960 bellhousing that I also have around. Can't wait to get that done... this is a bit of a learning process.
                          Another step coming up shortly is to modify the waterpipe. I have a Volvo 960 pipe ready to be modified as needed, but I'm going to wait to do anything with it until I have the turbo in hand. I *think* I want to do a GTX3067R and make use of the external wastegate flange already on the manifold. Admittedly, I'm a bit anxious about making that decision.
                            Those are such "busy" looking castings. It makes the engine look very industrial and cyborg-like.
                            I dont think im making sense.
                            • The Full BananaT
                              The Full BananaT
                              The Full Banana
                              They really are. Complete nightmare to clean.
                              I'll toss camgears on soon to give it a bit more johnny 5/cyborg look.
                                would make a great coffee table engine, especially with a big fat turbo bolted to it.
                                • The Full BananaT
                                  The Full BananaT
                                  The Full Banana
                                  Yeah, a friend in Chicago is doing that with one of his spare engines of this type.
                                  • The Full BananaT
                                    The Full BananaT
                                    The Full Banana
                                    Now onto one of the harder parts of this swap: making a transmission work with this engine
                                    And after lots of measuring, I drew up the bellhousing adapter this morning.
                                    Bellhousing side
                                    Transmission side
                                      I love seeing self-designed parts on peoples builds. Are you going to send the 3D file to a machine shop or are you going to give them a dimensioned print? If machining it from a block of alum is too pricey then I would have it quoted as 2 separate laser burnouts (plate) that get welded together and ground flat.
                                      • JeffJ
                                        JeffJ
                                        Jeff
                                        Custom parts are awsome!
                                        If you are looking for a place to make it let me know. Send me a file and I'll send you a price
                                        1976 530i e12
                                        1990 325ix e30
                                        1992 325i e36
                                        1995 740il e38
                                        2001 330xi e46
                                        ^More to come :)
                                        • The Full BananaT
                                          The Full BananaT
                                          The Full Banana
                                          Yeah, this was fun to do. Definitely the most complex/crucial part I've designed before. The thought is to send the 3D file, but if that doesn't work I can supply dimensioned drawings. I'm planning on having it machined out of one chunk. Material isn't cheap, but that's why eBay exists 😎
                                          Thanks, I'll send you a message! I don't yet have a plan for getting this machined.
