'88 E30
Acorns in my fuggin subframe
Ready for reinforcements
Still need to clean up the diff and rear trailing arms.
Anyone have recommendations for coils? I've been leaning towards CAtuned & have spoken with Collin about his... Anything else I should look at? Goals are not stants low, but will want it to be adjustable & stiffer than the crap I have. I figured coils over hr/billies because I could get different rates for the extra weight up front. I'll be running stock sway bars as well
BC Racing, CaTuned, or Fortune 500's
These are the ones I was kicking around.
Might go with CAtuned for the whole core exchange thing/come welded/new wheel bearings
acorns, lol. stupid squirrels just hide those f'ers everywhere because they forget where half of them are.
Kill em! Kill all dem squirrels with fire!
maybe the squirrel was trying to acorner balance the car for you?
Finally got the axles out of the hubs thanks to an impact
Long story short the bearings are going to be replaced
Just need to get the hub pressed out now
For coilovers i have Ksport Coilovers. They offer a setup for e30's that include "true rear" coilovers in the rear that i really enjoy in my drift e30.
Will look into them as well
I got the harbor freight being puller kit. Haven't used it yet but I think it would work
Going to a friends shop tomorrow to use a press. If for whatever reason that falls through, what kit did you go with?
Long story short the bearings are going to be replacedJust need to get the hub pressed out now
I got the harbor freight being puller kit. Haven't used it yet but I think it would workSent from my SM-G900V using Tapatalk
It cost around $100 from HF. Not sure exactly which one
Long story short the bearings are going to be replaced Just need to get the hub pressed out nowI got the harbor freight being puller kit. Haven't used it yet but I think it would workSent from my SM-G900V using Tapatalk
I think I know which one you're talking about
I have that kit too. Worked amazing for doing my coupe bearings=)
Didn't you use a slide hammer?
