  4. What (non-BMW/non-GM) V8 Would You Swap Into A BMW?
54 Posts 16 Posters 1.0k Views 2 Watching
    This is easy.  Ford Coyote 5.0.  Sounds amazing and can make ridiculous power for cheap. The only issue would be the physical size is quite large compared to an LS or even the 1uz-fe.
    The Coyote 5.0 is awesome, but how much can you get them for including other required swap parts?
    I can imagine you could score a good LS400 donor car + a manual trans from elsewhere for ~$5k-6k and you would have all the wiring, sensors, accessories, and modules required.
      About $3k from a wrecked f150.  The problem I have with the 1uz-fe is the cost to make it go fast.  It's definitely a cool engine but just doesn't scream performance.  The Volvo 4.4l V8 is also pretty awesome, please see example.
        What year did they start putting them in the F150?
        Yes, from my minimal internetting it looks like the stock guts on the 1UZ dont really like to see much more than 450hp and that number should be hit with pretty low boost with a turbo.
          There is a coyote swapped e36 floating around Wisconsin currently
            I believe it was 2011.
            You know, we can't discount the Nissan VK series.  These are high potential engines that nissan used in the GT-R and Z Super GT race cars and the VK56DE is used in the Australian V8 Supercar Altima.  (I never thought I would say Altima and Supercar in the same sentence.)
            • CMartC
              CMartC
              CMart
              I want to coyote swap a 67 fastback.
              That is my next project.
              Excursion 7.3
              E30 LS1
                Make sure its a body your not afraid to cut up.  From what I have heard the coyote won't fit between the shock towers without modification to the car.  But that'd be a kick ass car!
                • bk335B
                  bk335B
                  bk335
                  Slowest N54 in Wisconsin.
                    I just wanna rage drift
                      Ford 427 hemi.  Fun fun fun.
                        I'll give you a solid opinion on an LS in a BMW next week...1UZ doesn't make much power so I'd rule that out straight away. A Ferrari V8 out of a Maserati would be cool. You can pick one up for around $4-5k. The sound alone would be worth it.
                          Any high/quick revving v8 would be mine. E92 m3 v8 (code escapes me right now) would be awesome
                            Did you even read the title! Come on man!
                              God dammit pat.
                              Fine
                              Ford flat head with a welded 4.10 so it could barely do burnouts.
                                bk335 said:
                                The hellcat motor does nothing for me. Ho ahead, take my 'murica card.
                                  Anemic v8s ftw
                                    what?!
                                    with 18k miles because the owner didnt want to drop $20k on the 18,001 mile maintenance package?
                                    Which V8? the F355
                                      It would be interesting to see an older small block (Chevy 283 mopar 2 something or other). It needs barley any wires to run, toss heads and cams on it and be done. Not to mention they are dirt cheap to find
                                        what?!
                                        Which V8? the F355
                                        Read. Ferrari v8 out of a Maserati. There's one with 40k on ebay for $4300. You're almost as bad as sir Kaiser.
                                          you got me
                                          I've now achieved non-reading space cadet status
                                          I change my vote to ford flathead with welded 4.10s
