  4. 1991 318is M62B44 Build
268 Posts 27 Posters 0 Views 1 Watching
    Great work!!!!!
    Stoked to see this thing
    • CMartC
      CMartC
      CMart
      wasnt m3 said:
      Go Pro's cost nearly the same as a set of rear tires....priorities haha
      Need one eventually. Might as well be now.
      Great work!!!!! Stoked to see this thing
      Thanks! Don't think I am going to make it tomorrow. It was fun for a short drive, but still far from steetable. I'm happy its running well. Going to rip it all apart again and get the coilovers, BBK, weld in reinforcements, and hopefully a cage in there.
      Excursion 7.3
      E30 LS1
      • CMartC
        CMartC
        CMart
        Picked this up as a just in case motor. Then I thought, why not throw some nitrous at the current. Then after getting it on the stand I couldn't help but think, why not build some turbo manifolds?
        Not sure what to do yet, but I'm sure it will be fun.
        Excursion 7.3
        E30 LS1
          have fun.....
          Drivers%20Side%20Header%201zps0albl53h.
          • CMartC
            CMartC
            CMart
            I was thinking something much simpler. Log style.
            I will more likely than not go nitrous for simplicity sake.
            Excursion 7.3
            E30 LS1
            • CMartC
              CMartC
              CMart
              Got the coils off the other car today.
              Need to wait for the BBK adapter to show up before I try to install on the coupe, but already curious how I am going to get these dialed in between height and spring rate.
              Excursion 7.3
              E30 LS1
                Put them on. Let car settle. Adjust. Repeat as necessary
                  Are you swapping stuff from the coupe back to the vert? (suspension wise)
                  • CMartC
                    CMartC
                    CMart
                    Yeah. I had a nice koni/bilstein/H&R setup for the coupe so I sold that and the vert is getting the oem stuff.
                    Excursion 7.3
                    E30 LS1
                      turbo m60 is a tough gig, but has been done. the compression of the motors make it hard to run high boost, fyi. but the stock motor can handle the low boost no problems. forged crank!  don't think it is even possible to due twin turbo, though.
                      • CMartC
                        CMartC
                        CMart
                        Twin and single are both doable.
                        Just took the car out for what will most likely be the last ride of the year before dismantling.
                        Excursion 7.3
                        E30 LS1
                          Were many burnouts had?
                          • CMartC
                            CMartC
                            CMart
                            Still a little wet so many traction was nowhere to be found. May take it out in the morning with a buddy who is in town and get better pictures/videos.
                            Excursion 7.3
                            E30 LS1
                            • CMartC
                              CMartC
                              CMart
                              I never thought I would say this... But this car is for sale. I plan on actually selling it in the spring after I rebuild it this winter so it is turn key for the next owner. Not sure on pricing yet as I need to do some research. There was an M60 car that was junk that sold for 10 will be asking North of that.
                              Why you may ask?
                              Excursion 7.3
                              E30 LS1
                                You bought an M3???
                                  Story time! Accident car? Just guessing cause of the fender but sweet!
                                    Yea, this deserves some kind of explanation!
                                    • CMartC
                                      CMartC
                                      CMart
                                      Yep, bought an 88 M3. Was in an accident in 05, but not totaled or anything and has been properly repaired. Fenders are white because they are evo3 fenders that haven't been painted yet.
                                      Previous owner did a lot of work to this car to get it where it is. I'm excited to pick up where he left off and show this car some track days next year.
                                      Excursion 7.3
                                      E30 LS1
                                        Congrats! Just curious what the entry price was for yours given that e30 m3 in good shape are going for $25-35k
                                        • CMartC
                                          CMartC
                                          CMart
                                          This car is a non-running project at this point. The work that has been done to it is top notch, but still needs some mechanical/wiring/paint. I think the seller and I both walked away happy.
                                          Excursion 7.3
                                          E30 LS1
