  4. 1991 318is M62B44 Build
268 Posts 27 Posters 4.3k Views 1 Watching
  • CMartC
    CMartC
    CMart
    Yep, that is the plan for tonight. If that doesn't work check the inside of the booster for fluid as I believe that is where it could be leaking?
    My brakes are turning into a project of their own. I am waiting to install my coils to install the BBK and I want to clean up some of the plumbing. I am hoping to get it running as is, then take it down for a weekend or over winter and get everything how I want it.
    Excursion 7.3
    E30 LS1
    • CMartC
      CMartC
      CMart
      Also, I need to make sure all my return springs are there and linked where they should be. I have one in place, not sure if there is supposed to be another.
      Excursion 7.3
      E30 LS1
        Is this a hydroboost setup?  sorry, I didnt search through the thread/couldnt remember
        • CMartC
          CMartC
          CMart
          Remote booster setup. E34 v8 I believe.
          Also, sent for the plates today. Went with "V 80 30"
          Excursion 7.3
          E30 LS1
            Clever=)
              i can take pictures of mine if you need them for comparison.
              • CMartC
                CMartC
                CMart
                I meant E30. I'm confident my remote linkage is there. Without being hooked up to hydraulics it all works.
                Excursion 7.3
                E30 LS1
                • CMartC
                  CMartC
                  CMart
                  Excursion 7.3
                  E30 LS1
                    Hell yes. Nice work!
                    • CMartC
                      CMartC
                      CMart
                      Thanks. Not sure why the potato quality happened. Need to go pick up a go pro I guess.
                      Excursion 7.3
                      E30 LS1
                        Go Pro's cost nearly the same as a set of rear tires....priorities haha
                          Great work!!!!!
                          Stoked to see this thing
                          • CMartC
                            CMartC
                            CMart
                            Need one eventually. Might as well be now.
                            Great work!!!!! Stoked to see this thing
                            Thanks! Don't think I am going to make it tomorrow. It was fun for a short drive, but still far from steetable. I'm happy its running well. Going to rip it all apart again and get the coilovers, BBK, weld in reinforcements, and hopefully a cage in there.
                            Excursion 7.3
                            E30 LS1
                            • CMartC
                              CMartC
                              CMart
                              Picked this up as a just in case motor. Then I thought, why not throw some nitrous at the current. Then after getting it on the stand I couldn't help but think, why not build some turbo manifolds?
                              Not sure what to do yet, but I'm sure it will be fun.
                              Excursion 7.3
                              E30 LS1
                                have fun.....
                                Drivers%20Side%20Header%201zps0albl53h.
                                • CMartC
                                  CMartC
                                  CMart
                                  I was thinking something much simpler. Log style.
                                  I will more likely than not go nitrous for simplicity sake.
                                  Excursion 7.3
                                  E30 LS1
                                  • CMartC
                                    CMartC
                                    CMart
                                    Got the coils off the other car today.
                                    Need to wait for the BBK adapter to show up before I try to install on the coupe, but already curious how I am going to get these dialed in between height and spring rate.
                                    Excursion 7.3
                                    E30 LS1
                                      Put them on. Let car settle. Adjust. Repeat as necessary
                                        Are you swapping stuff from the coupe back to the vert? (suspension wise)
                                        • CMartC
                                          CMartC
                                          CMart
                                          Yeah. I had a nice koni/bilstein/H&R setup for the coupe so I sold that and the vert is getting the oem stuff.
                                          Excursion 7.3
                                          E30 LS1
                                          With your input, this post could be even better đŸ’—
